Question about Dell Computers & Internet
How do I overclock my cpu - Dell Computers & Internet
  • 6,831 Answers
Hello
Some CPU's overclock with diffirent methods, so, you do not specify which you are using, so, i googled step by step guide to overclock CPU. I found detailed instructions on how to overclock different systems. Hope this can help you.
Best regards.
Posted on Sep 30, 2009
Overclocking
There are many issues to consider when overclocking and the first is to be sure that you have extra cooling for your processor. On this motherboard I do not recommend overclocking but since ASUS says that it can be done I will try to give you some places to get information on your A7V880 system. If you do not have your user's manual, you can go to the link below and download one.
http://www.asus.com/Motherboards/AMD_Socket_A/A7V880/#download . Leave the OVER_VOLT1 jumper on the motherboard on the default of pins 1 & 2. Refer then to section 2.4.5 on pages 2-21,22 of the User's Manual for Jumper Free configuration overclocking settings. In BIOS Setup I suggest a CPU Multiple of 10 or less. If you choose to use the AI Overclock Tuner instead, a setting of [Overclock 20%] or less would be best. The VCORE Voltage setting will depend on the specs for the CPU that you are using. If you don't know leave it at Auto. As I said before, overheating of the CPU is a problem in overclocking and you can monitor the temperature via the Hardware Monitor. Refer to section 2.5.6 on page 2-26 of the manual. Modern cpu overclocking normally does not exceed 20% safely unless you are willing to spend a lot of money on liquid cooling and frequent replacement of damaged processors. I would be interested in hearing whether you decide to overclock or continuing with your present settings.
Nov 27, 2011 | ASUS A7V880 Motherboard
Tip
MAKING YOUR COMPUTER OPERATE VERY FAST & SECURED THROUGH CPU OVERCLOCKING
NOTE: OVERCLOCKING COMPUTER CPU MAKES IT PERFORM FASTER ABOVE THE FACTORY SET LEVEL, BEFORE OVERCLOCKING, READ THE GUIDE BELOW, AND VIEW THE SOFTWARE APPROACH HERE OPEN
drbrightirem.jpgOverclocking a processor means enabling it to operate above the manufacturer's specified frequency. Many internet sites provide instructions for overclocking. Processor manufacturers and many computer experts believe the slight gain in performance (only perceivable on CPU-intensive software) isn't worth the expense or considerable risk.
  • Get whatever tools you need: screwdriver, needle-nose pliers, motherboard manual, cooling hardware, etc.
  • 2 Find out whether your motherboard can be adjusted in the BIOS setup, with jumpers or not at all.
  • 3 Find out clock-speed limitations of the motherboard.
  • 4 Run all Windows and any third-party diagnostic applications you have. Fix all system problems.
  • 5 Make a complete backup of your system, documents and applications you don't have on CD-ROM. Do not overwrite these copies.
  • 6 If you have a BIOS-adjustable motherboard, make changes according to your motherboard manual, and skip to Step 15.
  • 7 Shut down computer.
  • 8 Leave computer plugged in to surge suppressor.
  • 9 Disconnect all peripherals from computer.
  • 10 Remove cover of chassis.
  • 11 Ground yourself to computer with any professional grounding equipment you have. Otherwise, ground yourself by touching a metal part of the chassis.
  • 12 If your motherboard has adjustable jumpers, locate the jumpers that control the CPU speed.
  • 13 Use needle-nose pliers to change jumper settings. Move jumpers to positions indicated in your motherboard manual for the clock speed you want. Check the internet for recommendations.
  • 14 Install a CPU heat sink, heat-sink compound, and a specialty cooling fan, if appropriate and possible.
  • 15 Put system back together, and reboot.
  • 16 If computer does not boot, and CPU still works, try lowering the clock speed. If that doesn't work, restore the original configuration.
  • 17 Check all functions, and run a CPU-intensive program.
  • NOTE: OVERCLOCKING COMPUTER CPU MAKES IT PERFORM FASTER ABOVE THE FACTORY SET LEVEL, BEFORE OVERCLOCKING, READ THE GUIDE BELOW, AND VIEW THE SOFTWARE APPROACH HERE OPEN Tips & Warnings
    • CPUs have rated and maximum speeds. Exceeding the maximum speed is far more likely to cause problems than more conservative adjustments.
    • Overclocking an Intel processor explicitly voids its warranty. Other manufacturers have similar exclusions. Intel prevents overclocking of some CPUs by disabling higher multiplier settings.
    • Expect a shorter life for an overclocked processor, including the possibility of its immediate failure.
    • Prepare to deal with seemingly unrelated problems that can be caused by overclocking: destruction of other internal components, lost data, system and application crashes, and an inability to boot the system. Such problems can occur randomly or materialize well after you have altered your motherboard
    on Dec 06, 2010 | Computers & Internet
    How to overlock my e5500 2.80ghz to 4.5ghz???? or the highest overlock that can e5500 dual core
    Hi there, your first going to need better cooling for your cpu like a aftermarket cooler and then go into the bios and raise the cpu multiplier and cpu voltage bit by bit
    Mar 03, 2011 | Intel Pentium DualCore E5500 28GHz 800MHz...
    System failed due to cpu overclocking. Not setup for overclocking in the bios.
    Reboot, and enter BIOS SETUP mode.
    Choose "Load Default Settings".
    This will "undo" any overclocking of your motherboard and of your CPU.
    Sep 20, 2010 | ASUS P4P800-E Deluxe Motherboard
    Overclocking
    Overclocking is set from the BIOS configuration. Not all BIOS allows overclocking, it may need a BIOS upgrade.
    Check the ASUS WEB site for your model motherboard.
    Overclocking the CPU (ie running at a higher clock speed) and increasing Frontside bus speed will give better performance BUT there is a downside too, if you overclock too high you could overheat the CPU and it could fail.
    Sep 01, 2009 | ASUS P5GC-MX/1333 Motherboard
    Overclocking t-mobile wing
    [WARNING - Overclocking your CPU will at least reduce the life of your processor but may fry it at worst - USE CAUTION]
    There are a couple of apps you can use to do this:
    OmapClock
    BatteryStatus
    I prefer Battery Status because it remembers your CPU overclock whereas OmapClock requires you to reset your CPU on wakeup. Also, BS has a "CPU Scaler" function (UNDERclocks your phone when it is not in use, then OVERclocks it when you wake it up...Pretty cool)
    Anyway you will get instructions on the site on how to use each one specifically. They are really easy to use.
    Jun 23, 2009 | T-Mobile Wing™ Smartphone
    Overclock an Intel E6300 on a GA-8I945GZME-RH motherboard
    You need to check your BIOS. If you can overclock you will see a selection for CPU and speed in BIOS. If not there then your motherboard does not allow you to overclock your CPU.
    Rate this solution.
    Jan 09, 2009 | Intel Core 2 Duo E6300 / 1.86 GHz...
    Cant overclock my cpu
    Overclocking is not reliable.
    Jun 13, 2017 | Computers & Internet
    Overclocking
    try in the bios first. it will be under something like 'cpu pnp options' then select overclocking, ENABLE. then under it it may have something like a bus frequency setting. it should be at the stock setting. to overclock, set the # higher. hope that helps you, cause that's what i did. BE SURE TO HAVE ENOUGH COOLING FIRST!!!
    download speedfan to check the cpu temperature. (Free)
    May 21, 2008 | Computers & Internet
    Overclocking failed
    Hi, If you have overclocked: 1. CPU or motherboard not up to it - run at default speed; or 2. Memory - try using other memory; or 3. Video Card - see if you can run the Video card at default speed and not with overclock speed; or 4. You may need to up the CPU B+ a bit. If not overclocked: a. Set BIOS/CMOS to default settings; or b. Disable any overclocking feature (even if not used); or c. Lower you CAS latency. Hope this be of some help/idea. ood luck and kind regards.
    Sep 01, 2007 | ASUS P5RD1-VM Motherboard
    Computers & Internet Logo
    298 people viewed this question
    Alun Cox
