Question about Brother IntelliFAX 2800 Laser Fax
Model #2800.\r\nthere is a white line on the left
Model #2800. there is a white line on the left side
of the paper when copying and sending
faxes. Received faxed look fine.
  • 1 more comment
  • karen_mcnich Sep 30, 2009
    I don't think it is an align problem.
    the white line is like this:
    see elow;
    abc efghi
    jklm opqr
    rstu wxyz
    123 567
    I press the copy button and it says no document....press options it says no document
    I cannot get to maintenence
  • karen_mcnich Oct 01, 2009
    went back and forth and returned to home position the corona wire on drum unit.
    cleaned glass but I don't know what they mean by clean the white bar.
    it looks like it is above the row of brush but how do you access it?
    President:
  • 3,278 Answers
Hi, Karen.
From Fixya:
Try cleaning the optics and the charge corona. If you do not have the operators manual which outlines the procedure, go to www.welcome.solutions.brother.com.
The procedure is in the CLEANING documentation. Make sure the wire cleaner is pushed all the way back to its home position. Otherwise, the white line may return if the cleaner is left in the exposure path.
Hope this helps.
Posted on Oct 01, 2009
    Brigadier General:
  • 3,614 Answers
Align your cartridges to solve print quality problems such as:
  • Characters are not properly formed or are not aligned at the left margin.
  • Vertical, straight lines are wavy.
  1. Load paper in the paper support.
  2. On the control panel, press Copy.
  3. Press Options until Maintenance appears.
  4. Press the right arrow until Align appears, and then press Select.
An alignment page prints. Once this page prints, your automatic alignment is complete.
Posted on Sep 30, 2009
  • micromaster
    micromaster Sep 30, 2009
    as i see it was not really align.. just give it a try.. you will find the problem was simple if you just try..
My fax type hp laserjet 3015 display a very big line (blanket of line) on the right hand side of the paper, and the left hand side is normal. This problem is observed in the received fax and during...
The mark is not being produced from the toner cartridge or scan mirror. The line is being produced by the Drum unit. You need to replace it.
You can purchase one online or at you local stationery retailer.
Hope this helps.
Best regards,
Dave
Please vote if this helped
Nov 26, 2010 | Brother IntelliFAX 2800 Laser Fax
Black stripe running down left side of paper when
Open the top of the fax where your documents go in. There will be a thin **** of glass where the document is read. On the end that reads "dirty" is a smudge or some white-out that needs to be cleaned. You may have to clean it with some cloth wrapped on a flat tool. Do not scrap or scratch anything, just clean enough to get the dirt off. Then make a test copy.
Apr 29, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Unwanted verticle line on fax copies
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page. If this is the cause you will also find that faxes you send to other people will also have this line (although faxes you receive are not affected by this problem with your machine).
To fix the problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 22, 2010 | Brother IntelliFAX 560 Plain Paper Fax
I get lines and can't read the right side of copies that I make with the 1270e. How do I fix this?
You have not specified why you can't read the right side of copies and I am assuming that the reason is because the 'lines' are covering the text. I can offer a solution to the lines issue.
Feb 22, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
I have a black line showing up on my faxed documents. I have opened it up, changed the film and re- set it, but the problem persists. The machine is about 5 years old.
If this is your problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 07, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
WHITE STREAK (NO TONER APPLIED) ON LEFT SIDE OF INCOMING FAXES
You did not specify if sending or RX
open the part where you insert the papers to fax out (this is also in the troubleshooting of hte manual) look at the strip of glass is there anything on it?
Open the machine, remove toner and look at the strip on bottom of machine clean.
http://safemanuals.com/index_google.php?cx=partner-pub-1682016597802119%3Axo3rw7s1srj&cof=FORID%3A10&q=brother+2800+manual#0
Jul 16, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother intelli fax 2800
It could be that your sending fax is sending paper not facing the scanner. In that case tell them to turn the paper over to send. Other than that, it could be that the telephone lines are so dirty that the fax protocl fails at the check frame signal. You will have to adjust the equalisation and line attenuation. Don't count on the telephone company to help you, they always want you to do everything 1st before they will admit to any fault on their part.
May 06, 2008 | Brother IntelliFAX 2800 Laser Fax
NOISE OR PAPER GETTING STUCK IN FAX MACHINE WHILE SENDING FAX
look in or around scanner area to see if there is any foriegn material trapped in paper handling area.
This is area where the original document feeds through
Jan 22, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother Intellifax 2800 Plain Paper "NO DOCUMENT"
no document mean that there is not paper in the paper feeding
Aug 29, 2007 | Brother IntelliFAX 2800 Laser Fax
Does not eject sheet
In the scanner unit there are 2 sets of ejection rollers. The first set (one farthest from you) there is a gear on the left hand side the probably has a worn collar on it that needs to be replaced. There is a black tab that sits in a slot on the right side of the shaft that holds the shaft in place. GENTLY move the tab away from the shaft then move the shaft to the left. The white gear on the left is the one that needs to be replaced if the collar is not perfectly square. Part #LE1196001. Hope that's it. Ed
May 15, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
46 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
