Question about Car Audio & Video
Mac-505 amp my amp seems to run , all the gauges light up but no power goes to my subs, on the back there are 2 lites that light up- one red and says protect and another that says power and is green. the protect light is on but the power light is not. help me please, hud
  • 631 Answers
Disconnect all speaker wires and signal cables from the amp. If it powers up normally (no protect light), the wiring needs to be checked. If it still goes into protect, the amp likely has blown output transistors.
Posted on Dec 21, 2007
I have a kicker zx750.1 in my truck. I have 2 kicker Cvts at 2 ohms. And my amp shuts down on most low notes. My trucks batter bar drops rapidly and the amp shuts off. I don't know if it's my...
If the truck is running and this occurs, it means either the alternator is not able to provide enough current or the battery itself is failing. If the truck is not running when this occurs, it is most likely the battery failing.
Jun 29, 2017 | Car Audio & Video
2 12" subs + 600W amp. Turn on, goes boom once, then red light
Is your gain all the way up? If it done this before, sounds like your over working the amp. Make sure your subs ohm load is capable with the amp load to. If they are 1 ohm and your amp is only 2 ohm stable, it would beat for a lil bit then go into protection mode to. Check your wires too.
May 13, 2010 | Insignia 600W Bridgeable Amplifier with...
Amp is not operating at full potential also red portectant lite comes on kenwood kac-8104d
make sure all your wires you are using to connect the amp are 4 gauge check your ground make sure its drilled threw thick metal scuff off the paint that its grounded too and check how you have your subs wired see what ohm there wired in the you can get more power out the amp in 2 ohm then 4 ohm
Mar 31, 2010 | Kenwood KAC-8104D Car Audio Amplifier
KAC9103d been running great for a year, factory refurb. for a month been losing sub output. checked all connections again, everything good. Turned on went driving 15 minutes later lost bass ckd again red...
Could be that you have a partially roasted(blown) coil on one of your subs which will function- but will keep tripping your amp.You can check that out just by using a different set of subs to listen to and by the process of elimination if the problem goes away then you know where the problem is at.Also check your gains you might be riding the gain a little high which causes distortion which causes heat(FAST) which will cause the amp to shut down completely or some amps will decrease output in a programmed attempt to save itself.turn the bass boost down to half if you even use it at all- that too can cause massive distortion in the amp itself,meaning only that if you have the bass boost on your deck turned up and then you turn the boost up on your amp the sound signal is then WAYYY distorted which will cause a thermal shutdown too. Last thing is to make sure that your subs arent running below 2 ohms because i believe that particular amp is designed to put out about 900 watts at 2 ohms.good luck
Jan 22, 2010 | Kenwood KAC-9103D Car Audio Amplifier
Red thermal light on
well id say you have cooked your amp and or subs they can only take beatings for so long. show it no mercy it gives it back,does amp smell do subs smell borrow amp see if subs are ok if so it will be your amp.new one .keep the gain down??
Jun 11, 2009 | Rockford Fosgate Punch P550.2 2-Channel...
RED Port light on AMP?
are you sure its not PROT?
the amplifier is protecting itself from fire because of something.
Disconnect the subs. and turn on.
if it comes on normally, the subs are at fault and will need attention. If the light still stays on, you hafe probably blown an output on the amplifier and it will need repair.
Dec 24, 2008 | Sony XM-2200GTX Car Audio Amplifier
Bass sounds flat when volume is increased
probably your power is too short, increase your gauge wire, and your ground wire of the amplifier has to be shortly as possible, and the positive has to be enough to support peak power, you can also put a big capacitor on the positive wire to give some more power while the bass peak.
Apr 26, 2008 | Earthquake Sound PH-D2 Car Audio Amplifier
Kenwood kac 859 amp
hi, note that if you are not using the proper gauge b+ and gnd cable with this amp then the current available at the amp wont be sufficint to keep amp on. also try using this amp while vehicle is idling. if this doesnt work then disconnect all spks from amp and check if red lite stops flashing. if it doesnt stop flashing then amp has internal fault. if lite stays on brite then proceed to check each spk load impedance, then reconnect each spk individually. the minute red lite starts flashing it will give you a clue that the channel or spk load is faulty. cheers
Jul 27, 2007 | Kenwood KAC-859 Car Audio Amplifier
Driving in first gear
Your Amp is in protect. Disconnect your subs and turn it back on. IF the led goes back to green the you have a blown Sub and it will need to be replaced. If the amp stays in protect even with the subs removed the the amp is toast.
May 29, 2007 | MA Audio HK2000D Car Audio Amplifier
Took out my amp and sub put it back in and now it wont work
you masht seting all parameter too the midel befour selected oan by oan,step by step equalayzer
Mar 30, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Car Audio & Video Logo
409 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
