LG Vu CU920 Cellular Phone Logo
Posted on Sep 30, 2009
Screen frozen - battery has been out ALL day - LG Vu CU920 Cellular Phone
2answers
How to Fix Kindle Paperwhite Frozen on Lock Screen?
Oops, are you troubleshooting the Kindle Paperwhite Screen Frozen problem? Have you tried all the possible ways to solve this difficulty? Not to worry, if the steps you perform don't work, we are here with some fully searched solutions that will help you to overcome Kindle Paperwhite Frozen on Lock Screen. Follow the guidelines step by step to get out of Kindle Paperwhite Screen Frozen matter easily on your own.
Steps To Solve Kindle Paperwhite Screen Frozen In Minutes
Charge The Kindle
A very common reason that leads to Kindle Paperwhite Screen frozen is the lower battery. It can be possible that you are facing screen stuck issues as of the empty or uncharged battery.
So, to let your device work properly you have to charge it first. Hopefully, charging your device will help you to overcome Screen frozen on Kindle.
Uninstall Corrupted File
If you have downloaded a wrong or corrupted file then you are definitely going through with Kindle paperwhite frozen on lock screen as well as scattering issues with Kindle.
Kindly uninstall the corrupted file as quickly as you can do, otherwise, it will cause damage to your device.
2answers
Touch screen frozen
the best solution to fix this problem is to get it repaired or replace if it is still under warranty.
I'll let you know if there is any other solution to fix this.
Nokia 5530 problem
it's probly something wrong with the batteries
3helpful
3answers
Screen is frozen on N97 - keyguard switch not unlocking keys
I have a Nokia N97 for the last 3 days. it froze twice, the only way to reset is taking out the battery.
Thank you
Ana
4helpful
My LG Viewty phone has been frozen for 4 days. The only thing I can do is answer calls and make calls to numbers in my call register. Everything seems to still work perfectly, exept for the screen. I've...
My LG KU990 viewty screen has frozen....meaning...the touch screen doesn't respond when I press it.
I can answer the phone and only call numbers i've already.
Does anyone know how I can fix this
I stupidly did not get it insured
I've turned it off and left it off for some time, taken the sim card out, but this doesn't help. Does anyone have a solution?
2helpful
2answers
Introductory frozen screen
Hi. You can perform all three steps in this page in order: (http://www.hardreset.eu/asus_mypal_a639_hard_reset_soft_reset_en.html) Hope this helps.
T5 is frozen on the "Palm Powered" screen
Remove the battery and let the palm sit for a day, reconnect the battery and do a hard reset. To remove the battery, you need a Torx T5 screwdriver. Carefully remove the cover making a note of the location of all the buttons in the case. The battery is connected by a mini 2 pin connector, just disconnect the battery by gently wiggling the connector and pulling.
1helpful
My 30 gb zune is frozen
http://www.rapidrepair.com/guides/zune/zuneassemblyguide.htm
goto step 4 only remove clip for battery wait ten seconds. It worked for me!
IPAQ H2210
yes I replaced the battery a couple of days ago.the align screen is frozen
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
