Question about Linksys Wireless-G Broadband Router
How do i set a security code in my router ? I need to be the only person using it .
  • 62 Answers
Directly link your router to your computer with the eathernet cable. than in an internet explorer window in the adress bar type 192.168.1.245. that will give you acces to set up a wired equivalent password. or wep key. there is also a specific set of instructions on linksys web page
Posted on Sep 30, 2009
Want a secure line
kb19073-001_en.png NOTE: Image may vary depending on the type of router and computer you are using.
To setup your router's wireless security settings:
i. Accessing the web-based setup page
ii. Setting-Up the Wireless Security
Step 1:
Access the router's web-based setup page by opening a web browser. On the Address bar, enter your router's local IP address then press [Enter].
NOTE: The default IP Address of Linksys routers is "192.168.1.1". For instructions on accessing the web-based setup page using a Mac computer, click here.
Step 2:
When the login prompt appears, enter your router's Username and Password.
NOTE: The default password is "admin" and the Username field is left blank. If you have set a password before but forgot it, you need to reset the device. For instructions on how to reset a Linksys router, click here.
Step 3:
On the Setup page, click the Wireless > Wireless Security.
NOTE: If some of the tabs are missing in the web-based setup page, upgrade the firmware of your router. For instructions, click here. You can also set the wireless security of your Linksys E-Series routers with Cisco Connect. To learn how, click here.
On the Wireless Security sub-tab, there are various wireless security options that you can choose from.
However, as mentioned earlier, the three most commonly used security modes are WEP, WPA Personal (or WPA Pre-Shared Key), and WPA2 Personal. The instructions below will show you how to set up the following security modes. On the other hand, the WPA2/WPA Enterprise Mixed Mode, WPA Enterprise, WPA2 Enterprise, and RADIUS security modes will only work if the router is connected to a RADIUS server.
Wired Equivalent Privacy (WEP)
WEP can be a 64-bit key with 10 hexadecimal digits or a 128-bit key with 26 hexadecimal digits. This encryption will prevent other users from connecting to your wireless network. It will also protect your wireless transmissions from being accessed by other users.
NOTE: In case the screen on your router's web-based setup page looks different, click here.
Step 1:
On Security Mode, select WEP.
Step 2:
Under WEP Encryption, select 40 / 64-bit (10 hex digits) and enter a unique word in the Passphrase field.
NOTE: The 128-bit key uses a higher level of encryption compared to the 64 bit WEP. It uses a 104 bit (26 Hex Character).
Step 3:
Click the Generate button and copy the string of letters and numbers displayed in the space provided for Key 1. The Key 1 contains the wireless password.
NOTE: You can also create your own Wireless Password (Key 1) given that it is in hexadecimal format. The hexadecimal system consists of the characters 0,1,2,3,4,5,6,7,8,9,A,B,C,D,E, and F. You can only choose 10 characters (in any given order) from that set.
Step 4:
Click kb19073-007_en.png.
Wi-Fi Protected Access (WPA)
Wi-Fi Protected Access (WPA) is a Wi-Fi standard designed to improve the security features of WEP. WPA is stronger than WEP encryption. PSK and PSK2, the two types of WPA, give you a choice between two encryption methods: the Temporal Key Integrity Protocol (TKIP), which incorporates Message Integrity Code (MIC) to provide protection against hackers, and Advanced Encryption System (AES), which utilizes a symmetric 128-Bit block data encryption.
NOTE: For older versions of Linksys routers, WPA Personal is also referred to as WPA Pre-Shared Key. Refer to the image below for an example.
To set up WPA Personal on a Linksys router, follow the steps below:
Step 1:
On Security Mode, select WPA Personal.
NOTE: If you are unable to find the WPA Personal or WPA2 Personal in the list of choices for the Security Mode then you might need to upgrade the firmware of your router to its latest version. Upgrading the firmware can fix the bugs of the previous version and update its other features.
Step 2:
Enter your Passphrase.
NOTE: The Passphrase must consist of at least eight characters and is case-sensitive.
Step 3:
Click kb19073-011_en.png.
Sep 19, 2011 | Linksys Wireless-G WRT54G Router
A dell inspiron 6400 with windows vista will not allow the d-link to connect. It asks for a security code
Welcome to Fixya.
If you need you Security Key (Network Key) on your router you need to access the Wireless Settings Page. To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.0.1, the Default username is admin and the password is blank. Go to the Wireless Settings and under Security Mode you'll find the Network Key or Passphrase. You can alsoThen Personalize you Network Key or Passphrase so that you can easily remember it.
Don't Forget to say Thanks. Thanks for using Fixya.
Mar 14, 2011 | D-Link Computers & Internet
Can not remember my network security code
Welcome to Fixya. If you need your Security Key (Passphrase) we can access the Wireless Settings Page of the router to obtain the information needed.
To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.11.1, the Default username is root password is blank
Go to wireless settings page and look for the Network Key. You can personalize the Network Key if you want.
Incase the username is not accepted you can reset the router by pressing the reset button at the back of it using a pen or paperclip for 5-10 seconds.
If you have questions just let me know. Thanks for using Fixya
Mar 13, 2011 | Buffalo Technology WHR-G54S Wireless...
What is a key code for the dir 625 D link wireless router, is it maintained in on te set up page?
Welcome to Fixya.
If you need you Security Key or Key Code (Network Key) on your router you need to access the Wireless Settings Page. To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.0.1, the Default username is admin and the password is blank. Go to the Wireless Settings and under Security Mode you'll find the Network Key or Passphrase. You can alsoThen Personalize you Network Key or Passphrase so that you can easily remember it.
Mar 05, 2011 | D-Link DIR-625 (790069292637) Wireless...
I need my security code for my cisco valet wireless router plz help
Welcome to Fixya. If you need you Security Key or Password (Network Key) on your router you need to access the Wireless Settings Page. To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.1.1, the Default username is admin and the password is admin. Go to the Wireless Settings and you'll find the Network Key or Passphrase (Security Code). You can alsoThen Personalize you Network Key or Passphrase so that you can easily remember it.
Feb 25, 2011 | Cisco -Valet Wireless Router
I have a Belkin router. Had to clear it and am trying to set and secure with new passwords. Put in http://192.168.2.1 and also .1.1 with no luck
Hi pamelaburgar,
Welcome to Fixya. If you want set a Security Code or Network Key to your network so that other people can't connect to your router you need to access your router. You need to make sure that a computer is connected to the router using ethernet cable so that it will communicate with the router.
You can reset the router first by pressing the small reset button at the back of it for 15-30 seconds while the router is on using a Pen or a Paper Clip. The lights will starts blinking it indicates that the reset was successful.
To access your router just open a Browser then type 192.168.2.1, password is blank. Click on the Security under Wireless. You can set the security type of your router to WPA or WEP to make it secure. Under that you can set the Security Code or Network Key. Personalize it so that that you can easily remember it.
Don't forget to say thanks. Thanks for using Fixya.
Feb 09, 2011 | Belkin Basic Wireless Router
I have wireless belkin 54 g how to setting security password cause all people can use my wireless thanks
Hi robidublin20,
If you want set a Security Code or Network Key to your network so that other people can't connect to your router you need to access your router.To access your router just open a Browser then type 192.168.2.1, password is blank. Click on the Security under Wireless. You can set the security type of your router to WPA or WEP to make it secure. Under that you can set the Security Code or Network Key. Personalize it so that that you can easily remember it.
Feb 07, 2011 | Belkin F5D7234-4 Router
Forgot the password
Hi brendflores,
Welcome to Fixya. Im not quite sure what password you're referring to if ti's the router password or the Network Password or Network Key. Listed below are the steps on how to obtain the Network Password and the Router Password.
For you to get you Security Code or Network Key you need to access your router.To access your router just open a Browser then type 192.168.2.1, password is blank. Click on the Security under Wireless. You can change the security type of your router to WPA, WEP or you can also Disable the security. Under that you can see the Security Code or Network Key. You can also Personalize the Passphrase or Network Key so that you can easily remember it.
You can also reset the router to its factory state but you need to keep in mind that all settings will be back to its default settings. To reset the router press and hold the small reset button at the back of the router using a Pen or a Paper Clip for 15-30 seconds.
If you think this is helpful rate me and don't forget to say thanks. Thanks for using Fixya.
Feb 06, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Where do I get my security code?
Hi Kmweidows,
If you want to get the Network Key or Security Code you need to access the Wireless Settings Page of your Router. To access your router just open a Browser then type 192.168.1.1, Username is admin password is admin. Go to the WLAN Settings Page and go to Security. Personalize the Passphrase, Network Key or Security Code so that you can easily remember it.
Rate me if this helps so I can help others. Thanks for using Fixya.
Feb 05, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Change router locaation
do factory reset of configuration settings then log in with the routers default credentials. then change settings to your liking with one exception: DO NOT USE WEP!!!!! At a minimum use WPA 1 personal (with MAC filtering if you know how.) WEP can be hacked in less than 5 minutes.
Dec 13, 2007 | NetGear WGR614 Wireless Router
Linksys Wireless-G Broadband Router Logo
212 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
