Question about Philips Magnavox 51MP392H Rear Projection Television
My tv doesn't turn on - Philips Magnavox 51MP392H Rear Projection Television
Blinking green lite tv wont turn on
Posted on Sep 30, 2009
Turns on but doesn't do anything else. Screen doesn't come on. Can hear a clicking sounds like a turn signal sound.
looks like a( DLP) tv digital light proccessor . aka projection. most likely the bulb is burned out . if so cost is $65-125 bucks. aftermarket bulbs are available online but some dont work or burn out prematurely. if you decide to fix it or buy a new tv ,invest in a surge protector. it will save your tv from problems like this . good luck.
Feb 11, 2013 | Televison & Video
SRP4004/27
Let's try to sort this out. You have a universal remote control which you want to use with your RCA TV. You turn on the TV, press and release the TV button on your remote, and enter an RCA TV code. You then press the ON-OFF (or POWER) button and the TV turns off. If not, you repeat the process with other codes until you find one that turns the TV off. If you are successful, you should be able to turn on the TV and channel up or down through all available channels in your area. If I am missing something, post a reply
Nov 16, 2012 | Televison & Video
Turn on but remote doesn't work
I would try new batteries first. If that doesn't help then replace the remote with a universal unit that you can program to work with your TV.
Nov 13, 2012 | LG 42LC2D 42 in. LCD HDTV
TV doesn't turn on.
Seek tech support
Jun 02, 2012 | RCA 27V520T 27" TV
THE T V WILL NOT POWER ON
plug the cord into the outlet. If the wall outlet doesn't work find a different one. If the tv doesn't turn on with the remote take the plastic off of the batteries in the remote. if this all doesn't work, then there's something wrong with the tv and you should return it and get a new one.
May 16, 2011 | Tatung LD30HL Television
When I turn on my set, light turns green, then after 30 seconds turns red won't come on
Sounds like there is a problem with the power supply. Try unplugging the T.V. and hold the power button for 30 seconds. Plug the T.V. back in and see if that helps. If it doesn't try switching to another outlet, and if that doesn't work then you may need to replace the power supply which would probably cost anywhere from 140 to 200 for one.
May 05, 2011 | Fujitsu PlasmaVision P50XHA40US 50 in....
Sanyo television doesn't turn off either by using the remote or by turning it off at the tv.All other fuctions work using the remote or directly on the set.Even using the sleep timer doesn't turn...
Unplug the set and hold the power button for 30 seconds. Plug it back in and see if that fixes it. If it doesn't then it sounds like there is a problem on the board underneath the power button. Something isn't allowing the circuit to be cut.
May 05, 2011 | Televison & Video
Remote doesn' turn n tv or chane channels
try changing the batterys. If its a universal remote reprogram it again.
Oct 04, 2009 | Symphonic ST420FF 20" TV
The receiver doesn´t work. When i switch on,
the solution: Fount of energy broken and 50€ less in the pocket...lolo
Aug 14, 2009 | Philips E-Box FTR9965 DTV Receiver
Philips Magnavox 51MP392H Rear Projection Television Logo
99 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
