Question about Refrigerators
Whirlpool fridge hello, I have a fridge that doesn't get cold enough but freezer is fine. Any ideas?
  • 410 Answers
Most likely you have defrost problem look for snowy type ice build up on rear wall of freezer side. if its frosted up manually defrost the freezer either by turnog unit off and leaving doors open for several hours or you can remove the freezer cover and defrost the coil with a blow dryer.
the most common part to fail in the defrost system is the defrost thermostat.
good luck
Posted on Dec 20, 2007
Fridge not freezing meats
I was writing a big note here before then hit the wrong button, it was just a bunch of jargon anyway. Yes it is the condenser fan motor causing your problems. Doesn't cool the refrigerant properly than nothing works. I would change the fan before it causes any damage to the compressor.
Sep 04, 2012 | Whirlpool Refrigerators
Tip
Whirlpool Fridge
I am having trouble with my Whirlpool Fridge single door fridge. The top freezer is getting too cold and freezing the food too much and the bottom of the fridge is not cold enough, changing the settings on the fridge only makes it worse.
I have just recently chenged the fan, so what could be the proplem and how can I fix it.
on Feb 11, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
Freezer is cold enough but refrigerator doesn't get to temp. Any ideas?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 12, 2011 | Danby DFF8802 Top Freezer Refrigerator
Whirlpool fridge is fine but freezer not
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again.
Also check to see if anything is blocking any airflow at the vents.
Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 17, 2010 | Freezers
Freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Feb 12, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer fine /After power went out twice fridge not cold enough
In back of the refrigerator is a removable panel behind which is the compressor. Listen for a hum and a click. If you hear those sounds the compressor may have failed. Behind that same panel is a condenser where heat is removed from the refrigerating system. Make sure it is clean and check that the fan operates when the compressor runs.
Jun 07, 2008 | GE Â 17.9 Cu. Ft. Top-Freezer...
Refrigerators Logo
116 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
