Question about Nikon COOLPIX L3 Digital Camera
Our COOLPIX L3 was dropped and the "lens error" came up. When turned off & then back on the lens extends and immediately tries to close. Will not close all the way.
5 Suggested Answers
t00nz
  • 4738 Answers
SOURCE: lens error
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 23, 2007
t00nz
  • 4738 Answers
SOURCE: dropped Nikon Coolpix L3
dlundmark
  • 797 Answers
SOURCE: camera lens will not close
Hi:
Sometimes you can try to get it unstuck by looking at the lens at is is. Then determine if it appears to be at a slight angle, if so, it may be that you can force the lens in the opposite direction. This may not work, and may damage the lens further, however, since it is not working, trying may be just what is needed.
I have had some success by forcing the lens in the opposite direction as it is turned on with pressure of my fingers pushing it. It has not always worked, but I have two which worked just fine... one was a 7.1mpxl nikon and the other was a 8mpxl Canon.
They both were off track, and jumped back by a little force.
If the lens was hit or dropped, then damage can be more than can be fixed. What can happen is that the small track parts can be broken, then there is no way to get it back on track.
Also, dirt or sand can do a number on these small parts. It is amazing how these extremely small pieces of sand can jam a lens, but I have seen it happen.
Take a hint and keep the camera away from sand and water, or risk trouble.
Posted on Jun 21, 2008
lock123
  • 6831 Answers
SOURCE: my coolpix l3 shows lens error and will not close
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Feb 09, 2011
Lens error for coolpix l3. The lens won't retract and the camera won't work. took batteries out and put new ones in. nothing is working. is there a way to reset the camera?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Sep 29, 2011 | Nikon COOLPIX L3 Digital Camera
Describe your COOLPIX L3 Digital Camera Problem I keep getting Lens Error message, what should I do?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Aug 31, 2011 | Nikon COOLPIX L3 Digital Camera
When I turn on my camera, it says lens error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Dec 18, 2010 | Nikon COOLPIX L3 Digital Camera
My Nikon coolpix L3 appeared LENS ERROR how do i solve this fault
Oct 13, 2010 | Nikon COOLPIX L3 Digital Camera
My cameras lens wont come out, its stuck. when i turn it on.. it makes noises, & tries to come out, but wont extend.after like 10 seconds of it making noises, it saays lens error. i have a NIKON...
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to auto focus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
Aug 18, 2010 | Nikon COOLPIX L3 Digital Camera
Took a picture, then camera was in bag for a moment with lens open. when I tried to take another picture it was blurry, then the lens got stuck , "Lens error", kept making noises, had to take batteries...
What you're experiencing is called a lens error. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Feb 18, 2010 | Nikon COOLPIX L3 Digital Camera
Lens error
This error... lens error.. can be the result of many abuses. If the lens is held back as it is extending, it can damage the tiny parts. If the lens is bumped while it is extended, it may damage the internal parts beyond repair. Sometimes the lens get off track as a result of a blow while extended.
If the camera is dropped, the lens mechanism can be damaged from the impact, even though it is not extended.
If you treat a digital camera with a lot of care, and put in a padded camera bag, you may extend the life of the camera.
Feb 09, 2008 | Nikon COOLPIX L3 Digital Camera
Lens error
your lens are stuck! did you drop the camera? you need to get a repair on the lens
Jan 10, 2008 | Nikon COOLPIX L3 Digital Camera
Nikon L3 lens stuck
Hi:
Lens errors like this usually happen as a result of something damaging the lens in some way.
It could have been against something to prevent the lens from moving out.
It could have been dropped when the lens was out.
If the lens is impacted when the lens is out, damage can occur.
If there is a buzzing, grinding noise as the lens extends, then the probability of damage to the small plastic gears, internal guides or other internal lens parts is high.
What can be done is, as mentioned a few times in my posts, to hold the lens back or pull on it as the camera starts.
This may cause more damage, and may not help at all, but some cases may re-align the internal parts in the lens assembly. This may be worth a try, since the camera is useless unless the lens works right.
Hope I can give some help here on these.
Oct 26, 2007 | Nikon COOLPIX L3 Digital Camera
Nikon COOLPIX L3 Digital Camera Logo
80 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
