Question about Philips 46PP9302 46" Rear Projection Television
Problem with convergence. The 2 colors will not converge and I cannot correct the problem manually
  • Philips Master
  • 3,459 Answers
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Oct 18, 2009
Picture is not showing correctly. Color seems like it is going out. For example the color green does not show up as green.
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to solved the tv picture convergence problems.Try website like Tvrepairworld.com to buy a whole refurbish convergence board for the replacement.The Akai/Samsung DLP tv used the same convergence board.Or the shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | Samsung PCL541R 54" Rear Projection...
Cannot correct convergence the green line is double
The tv convergence board is dead.Any colors lines R,G,B mis alignment,have colors shadows or 3D picure look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Nov 06, 2010 | Toshiba 42H81 42" Rear Projection...
Wavy color separation, auto focus doesn't fix problem. Doesn't have a manual focus.
Ur tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board it have dead 2 STK convergence ICS and some or all it resistors.These parts,must be replaced on the tv convergence board to solved tv picture convergence.
Oct 11, 2010 | Sony KP-57WS500 57" Rear Projection...
Flash Focus does not correct convergence problem and i cannot manually adjust the red convergence to proper alignment. Red does not move laterally only vertically. Picture is offset to the right with red...
No,any colors lines mis alignments.The tv convergence board parts are dead.The 2 STK convergence ICS and some or all it resistors are dead.These parts must be replace on the tv convergence board.To solveved convergence problems.The shop,will cost u $300-350 for parts and labors.
Aug 10, 2010 | Sony KP-51HW40 51" Rear Projection...
It looks a great deal like watching a 3d movie without 3d glases. The convergence is not correct. I tried to correct with a convergence back to factory settings and a manual correction from the remote. Not...
Common convergence problems like this require the set to be repaired. Transistors are used to control convergence and they will go bad eventually and require replacement. Expect a repair cost in the 100 to 175 dollar range depending on who you can find to complete the repair.
May 04, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Cannot converge colors on screen
This happens when convergence out ICs become defective.
Replace convergence ICs on D board to get correct picture. This qualified TV tech job.
Thanks.
Sep 06, 2009 | Sony KP-51WS500 51" Rear Projection...
52"projection tv colors overlap
Your convergence is bad. If after trying the Auto Convergence option on the TV it doesn't correct itself, you can try manually adjusting the convergence Here is a link to perform a manual convergence on your set. Good luck!
Greg
http://www.ehow.com/how_2034880_perform-convergence--tv.html
May 23, 2009 | RCA Televison & Video
Green Tube Convergence Issue
Greetings abflex,
You definately came to the right place! Here is a link right here on FixYa with the directions on how to correct this problem.
http://www.fixya.com/support/p186391-jvc_av_48wp30_48_in_rear_projection/manual-17247/page-52
I hope this helps!
Thank you,
Dorothy
Go Ahead. Use Us.
Jun 25, 2008 | JVC AV-48WP30 48" Rear Projection...
RCA HDTV 52 Inch
If its only one color its the Convergence amp board that needs replacement. If its more than one color you cant control you need the Convergence power supply board. If you need parts for your model let me know and I will post a link.
Jun 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Colors are horribly misaligned... Do not have manual convergence...
Have you entered "Mute-> 1 -> 8 -> 3" to get to the remote convergence menu? There you can manipulate each color, null convergence, load last saved and make corrections. From this menu you should be able to determine if one or more convergence failures have occured.
Dec 01, 2007 | Samsung HC-P4363W 43 in. TV/DVD Combo
Philips 46PP9302 46" Rear Projection Television Logo
143 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
