Question about Echo Garden
Low power, somethimes it runs fine - Echo Garden
    Problem Solver:
  • 6 Answers
Try this: Check your air filter, clean if dirty. No fix? Change your gas, prime and try to start. No fix? Check Spark plug for fouling and replace if buildup is present. No fix? Pull the fuel tank and two/three (one is a vent with it's own filter, shouldn't cause the problem) fuel lines coming from the tank and inspect for cracks/holes/dry rot, re-install/replace (fuel line is around $0.75/ft at local repair shop or available at mfr. web site). Still no fix? Pull carb... it's not that big of a deal, you need a phillips screwdriver. Be careful not to let dirt fall into the intake of the motor, so blow it off with compressed air if possible before removal. Pull the top and bottom plates off carb by removing screws, one might be built into the primer cup (I do this part over a cookie sheet to avoid runaway small pieces) gently to reveal the gaskets underneath taking note of which direction they come apart. One gasket should be relatively flat with a couple of holes in it, the other might have a metal washer fastened to it against a spring and arm mechanism which is attached to the carb. Inspect these gaskets and if there is evidence of cracking, or they seem to be "mis-shaped" or brittle, order the appropriate rebuild kit (around $10) from your local small engine shop or online source as per manufacturer's part# (available at Echo's web site). Re-assemble after dousing all parts with carb-cleaner per directions on can and try again. Still no-fix? Seek professional advice, it's going to be over $10 at this point. Fixed? Great, now you have to do yard work. Happy Fall!
-JMFT
Posted on Oct 01, 2009
  • JMFT Oct 01, 2009
    Check for vacum leaks at carb to inkate gasket before removing carb by starting blower and spraying wd-40 between carb and intake at gasket and listen for change in engine rpm. You can use carb cleaner for the same effect, however be very careful not to douse it as it is EXTREMELY FLAMMABLE! Which is why I say use WD-40 as it has a lower flash point.
    -JMFT
2001 FORD TAURUS IDLES BAD
i recently had this issue with my 2001 taurus dohc engine. when you drive it seems that everything is fine. when you stop, the car will idle very low and somethimes shut off. there is a hose under the throttle body that is attached to the pcv valve. over time, this hose will collapse and eign to tear. i replace that hose (autozone for $10) and it solved my idling problem.
May 17, 2012 | 2001 Ford Taurus
I went to start my 91 s10 blazer 4.3 4x4 and I had dash lights till I went to start it then I lost all power to everything inside and outside. I checked the starter wires and battery wires are all good,...
something is completely draining your system at start-up, I believe that your starter is bad ( take it out and have it checked) or you have a real bad short or grounded wire that could possibly start a fire. A low, or almost dead battery can also cause this...take your battery cables off battery and clean anyway to insure good contact ( if aftermarket , even reassemble and clean cable to clamp connections) corrosion/resistance can be a thin film somethimes
Oct 03, 2010 | 1991 Chevrolet S-10 Blazer
Hi i recently bought an audi a3 an when driving it had a sudden loss of power in each gear having turned the ignition off then on the problem clears any ideas
My Audi A3 from 2002 has a problem with the EPC. I have been to authorised service but they could find nothing wrong. When the EPC stays on after starting the engine the authomatic accelaration - I have no control. The engine accelerates by himself and somethimes it stopps.
Jun 26, 2010 | 2004 Audi A4
Saturn vue2003 now power low rpm
yep a stop up fuel filter.will cause low power.also bad gas and if transmission fluid is low.transmission will starting slipping. causing low power.check transmission fluid if it looks black has burnt smell.change transmission fluid and filter.
Nov 21, 2009 | 2002 Saturn VUE
Blower motor runs somethimes
Could be a faulty switch, or wire connector problem, and not necessarily the blower motor. You could save yourself $600 by doing a little troubleshooting to find the problem.
Try wiggling the wire connector at the blower and the switch. If it is the blower motor, spend a few dollars for a chilton's manual or haynes, and do it yourself.
Aug 12, 2009 | 2004 Buick LeSabre
92 cherokee sport. Sometimes starts fine, somethimes startergrinds n runs down the battery.
Sounds like that starter is on it's way out the door. I suggest you change it before it leaves you somewhere.
Aug 02, 2009 | 1992 Jeep Cherokee Sport
LED on abit ST6
every motherboard should have a led light always on to indicate that there if power in it. the problem with system rebooting has to do with the ram or processor, since you said it does not recognize the hdd at times that means that the ram is working abnormally i.e it is week, u know ram means random access memory, so change the ram and make sure u get the right ram for your system
Jul 11, 2009 | Abit ST6 Motherboard
Heater in my 1998 ford taurus works intermittently
check the radiator fluid level. It sounds like you have a low fluid level . or the thermostat could be malfunctioning.
Dec 12, 2008 | 1998 Ford Taurus
Open Questions:
Garden Logo
128 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
