Question about Panasonic PT-56WX53 53" Rear Projection HDTV-Ready Television
I have a panasonic model#PT-56WX33,when I power on tv NO PICTURE,NO SOUND,nothing.Only the red power light on tv panel lights up and blinks 5 times ovr-n-ovr.
    President:
  • 788 Answers
Your symptoms sounds like a damaged convergence IC.
This is a common failure for this particular television. You should have a red blinking power light on the front of your set that will blink 5 times and this is your solution to your problem.
There are two and large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110, and they are located on the signal board (on the left as you look into the back of the set).
What happens in the Panasonic set is that the convergence IC’s will short and cause the power supply to shut down from the overload of current. Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
There are also two resistors on the front of the board located in the middle that are fusible link resistors, these should be checked for opens and replaced if they are found so.
I would suggest that you contact a service center in your area for a complete diagnosis and repair, as this type of repair can get a little tricky. But if you want to repair the set yourself, just remember to be careful. The capacitors and CRT’s can hold a charge and may shock you.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
Posted on Oct 01, 2009
2 Suggested Answers
smarthome2
  • 1114 Answers
SOURCE: Panasonic PT-56WX33/red light blinks 3 times ovr-n-ovr
It's one of two things, a bad chipset, or bad lamp. 200-250 repair. Hope this helps
Posted on Jul 07, 2009
Problem with Panasonic PT-60LCX64 Television My tv which is a PT-60LCX64 will not turn on. It blink green several times and will not show a picture then it turn red blinking light.I tried unplugging and...
Sounds like an internal power issue. Usually a red blinking light is a fatal error, such as bulb or capacitor.
Follow this link and scroll to page 100 to begin the troubleshooting steps.
http://service.us.panasonic.com/OPERMANPDF/PT43LCX64.PDF
You will need adobe reader.
Adobe Adobe Reader free PDF viewer download
Apr 10, 2014 | Panasonic PT-60LCX64 Television
Hello, I have a 53-inch Panasonic PT-53WX42F TV, and it refuses to turn on. No picture, no sound. All it does is the tiny red power light blinks 3 times repeatedly. Can I fix this myself? What parts do I...
Thats a convergence failure when the led blinks 3 times. Your model uses the PT47WX42 convergence repair kit available from www.tvrepairworld.com the kit contains the parts and the CD with instructions for the repair.
Jul 16, 2010 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic T.V. model number PT-47WX42F no picture or sound
R800 open on power board next to the relay.the resistor value is1.5 ohms 10 watt resistor.
Jul 15, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Jul 07, 2009 | Panasonic PT-56WX53 53" Rear Projection...
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Dec 14, 2008 | Panasonic PT-44LCX65 Television
Panasonic Rear Projection TV PT-47WXC43
I have a Panasonic PT-47WXC43 47 in Rear Projection. It went off, on picture, no sound.
Jul 13, 2008 | Panasonic PT-47WXC43 47" Rear Projection...
Panasonic pt53wx42f
WHEN POWER IS FIRST TURNED ON I HAVE A SOLID RED LIGHT BUT NO PICTURE. THEN YOU HEAR THE TV CLICK OFF. THEN RED LIGHT STARTS TO BLINK IN SET OF (3) TIMES.
Jun 25, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-56WX53 53" Rear Projection HDTV-Ready Television Logo
228 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
