Question about Apple iPhone Smartphone
My iphone wont turn on
Little amount of water went threw my earpiece and ended up on my screen. after seeing the water in under my screen i suddenly turned off my iphone. after turning it off, it continued turning on off and going to airplane mode. now my iphone will not turn on at all. what should i do?
    Guru:
  • 1,049 Answers
If you have not fried it already there is a good chance that if you remove the battery immediately and let it dry out completely that it will begin to function normally.
Do not hook it to a charger until you know the internal components are dry. this will almost assuredly fry the device as the voltage is much higher from the wall.
If there is standing water inside the device, you may want to try and find a way to drain it so that the internal components don't corrode before they can dry out.
Posted on Sep 30, 2009
Not working buttons
The home button do tend to break, the iphone 3 or 3gs are straight forward to replace the home button. Remove 2 screws from the end of your phone, 1 on either side of your charging socket. Lift the screen from the home button end as there are ribbon cables on the earpiece end of the screen. You then have access to replacing the home button but the iphone 4 and newer model are alot more difficult as the last thing to be removed is the screen and you have to remove the screen for access to the home button. It is a very cheap fix but if you don't know what your doing when taking apart your phone you could cause alot more damage. Have a look at a internet iphone repair video to see if you would be confident of doing the repair yourself. Before you start to take apart your phone make sure it is not under warranty as taking it apart will void any warranty.
Dec 29, 2013 | Apple iPhone Smartphone
My IPhone will not turn on. It suddenly went off, like it powered down, but wont turn back on after a 20 minute charge...even when still plugged into charger.
Try to connect it with you PC via usb cabal...and if your PC shows that he founds device (Iphone), you will see on Iphone screen that he is start charging...after that you can put it to electicity charging, with regular adapter and charge it for 1 hour and then turn it on and it will work :) That happens when battery lose her voltage (need to be 3,7V)...Otherwise if you PC, when you connect it does not show nothing, than you have some hardware failure and you need to take you Iphone to some mobile service to fix it..
Best Regards!
Sep 05, 2013 | Cell Phones
My iphone 3G
1) First of all, check your charging cable. It won't supply a sufficient amount of energy to start the IPhone if it is bent or punctured. If it is try buying or using an alternative charger 2). If it still won't turn on, press and hold the home button for 30-60 seconds. If it still won't work, contact your local phone or apple store to get the problem sorted.
May 12, 2013 | Apple iPhone Smartphone
Iphone wont power on
You may need to press and hold the sleep button. If not try to treat it like an ipod. Hold the center button at the bottom and the top one at the same time. Should reboot.
Aug 30, 2009 | Apple iPhone Smartphone
My iPhone 3G does not discover my Motorola H500.
Try this link. It solved my issue www.scribd.com/doc/280088/motorola-h500-bluetooth-earpiece-manual. Basically what you need to do is power the earpiece off. Make sure that your IPhone is not currently attempting to discover bluetooth devices (i.e. Bluetooth is OFF). Hold the On button on your earpiece (it has the symbol of a phone on it) for 6-10 seconds. The light on the earpiece remains lit. Now your earpiece is in discovery mode. On your IPhone, go to Settings, General, Bluetooth. Turn Bluetooth ON. Now your phone and your earpiece are both in discovery mode. When you see "Headset" listed, select it and enter the password "0000". Your IPhone is now paired with your H500 headset.
Mar 24, 2009 | Motorola Mobility H500 Wireless Headset
Non responsive touch screen on iphone
i guess ull jus have to replace the screen
Dec 08, 2008 | Apple iPhone Smartphone
My Iphone never turned on after little water spills on it.
try keeping the phone in a dry warm place for a number of days even weeks and then see what happens.
Oct 27, 2008 | Apple iPhone Smartphone
Iphone Ear Piece not working
hahahaha there is only one way of this u must havent removed the plastic cover frm the earpiece that is the only reason else it is a manufacturing defect ..... take it 2 apple service center and if u have a bill theyll replace free else they will charge
enjoy
May 27, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
101 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
