Question about Lexmark X83 All-In-One InkJet Printer
Lexmark x83 does not pull paper through; what do I do?
  • Lexmark Expert
  • 228 Answers
One common cause of paper feed issues is a build up of dust on the printer's rear paper feed roller. This roller consists of a plastic axle with one rubber roller on each side. This is located in the automatic sheet feeder and is referred to as the "Pick Roller." As dust builds up on the rubber rollers, they become less tacky and therefore unable to grab a single sheet of paper.
To prevent and/or cure this type of paper feed problem, these rubber rollers should be cleaned.
Unplug the printer's power cord and remove the paper from the automatic sheet feeder. Locate the pick roller and clean the rubber wheels on the left and right with a cloth dampened with warm water (be sure there is no excess water on the cloth as it may drip into the machine). After these are free of any dust or ink build up, reload the paper and plug the power cord back in. The paper should then feed normally.
Next, follow the steps given below to perform the self-test:
1. Press the "Menu" button 10 times. It should then read "Maintenance" on the printer's display screen.
2. Press the "Select" button once. You should then see "Cartridges" displayed on the printer screen.
3. Press the "Right Arrow" button 3 times, which then brings you to the "Self-Test" option.
4. Press the "Select" button once. It should print out a sheet of paper with horizontal color and black lines and smaller vertical lines.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues and we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Posted on Oct 01, 2009
My lexmark x83 is making a clicking noise and will not pull paper through.
hello, the problem with your machine is a gear that drives the paper feed section, not the paper feed roller but the platen roller, well its cracked, unless you have an identical machine, you will not be able to repair this printer, i have tried. so, this machine has performed for you extremely well, but now it time to look for another one. sorry
Oct 07, 2010 | Lexmark X83 All-In-One InkJet Printer
How do I remove the cover of my lexmark X83? The paper will only feed part of the way then I get a paper jam message.
there is a cover there at the back of your printer, pull it down then remove the paper hang on their, then after you remove , check if there is another paper to hang, after that try to print
Jul 01, 2009 | Lexmark X83 All-In-One InkJet Printer
Lexmark x83 paper feed problem
If your not qualified to do this I would not sugges you do it, tho here is a solution for you. See if its snapped in place instead of being bolted down. you can also access underneath the unit hope this helps.
Apr 22, 2009 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83 has system error A04.
Try to do the following:
  1. Reseat both cartridges in the printer and unplug the power cable for 30 seconds.
  2. Plug the power cable back in.
If you still experience issues please let me know.
-Serge
Mar 30, 2009 | Lexmark X83 All-In-One InkJet Printer
Paper keeps jaming
problemwith the roller or with the gear which is attached to themotor
Jan 10, 2009 | Lexmark X83 All-In-One InkJet Printer
MULTIFUNCTION JET PRINTER MODEL LEXMARK X83
You will find the solution for this on this site
Choose the Location
then type the mode number
there is a page with the solution available for this problem
http://support.lexmark.com
Dec 16, 2008 | Lexmark X1150 All-In-One InkJet Printer
Paper won't feed in my Lexmar X83
insert sandpaper into printer tray. begin print. hold the sheet tightly and DO NOT let the printer feed it in. it worked with my lexmark z611.
Jul 23, 2008 | Lexmark X83 All-In-One InkJet Printer
Lexmark x83
Sounds like there is something like a part of a sticky address label, or a piece of other paper stuck inside.
Take a heavy piece of card stock and feed it through the paper path. Chances are, when you get the card stock all the way through, it will push out the offending object that is hung in the paper path.
May 19, 2008 | Lexmark X83 All-In-One InkJet Printer
LEXMARK X83 PRINTER 1) A few times papers jammed too far back to pull out from the front so i pulled them out the back. Now when the paper feeds there is a clicking noise and the papers feed only...
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Oct 10, 2007 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83 all-in-one printer
Hi gerby, need to eliminate a few issues to get to the cause. First, check for a jam. Paper jams can be so tiny you can barely notice them. Use a torch and check thoroughly down back of unit in paper feeder, open cover, let cartridge carriage roll left and settle. Now look inside thoroughly too. If no jam, check rollers are even and look same on each side. Post back if no good.
Sep 01, 2007 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83 All-In-One InkJet Printer Logo
473 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
