Question about Epson Stylus R265 InkJet Photo Printer
Cant reset the counter
Im getting the message below pop up when i try to print anything, i have tried to use ssc programme but it deosnt support the r265
"Parts inside your printer are near the end of their service life. See your printer documentation."
any ideas?
  • terrier33 Nov 17, 2008
    I have same problem
Email me at isney2006@hotmail.com i will send you the fix to this problem.
Posted on Dec 22, 2007
Resetter r230x
1. Make sure the printer is turned on and terkonek with a computer (printer driver already installed)
2. Install SSC Service Utility and run the program
3. Model of printer configuration settings. Select the Epson Stylus Photo R230. After the play closed
windows.
4. In the lower right corner of the taskbar (near the clock) right click the icon SSC Service Utility, select
" Protection Counter" click "Reset protection counter" select Yes on the pop up that asks
"Have you Replace waste ink pad"
5. Restart the printer, the printer is ok
That's the steps I described to my friend, so she does not go back and forth to the printer lift handyman service to reset Epson R230. May be useful.
Download SSC Service Utility
Dec 10, 2013 | Epson STYLUS R230 InkJet Photo Printer
My pictures are printing out red
What you mentioned could be an ink clog if your Epson has not been used for a while?
If so you may need to get a print head cleaning Kit like Magic Inkjet Flush which you can find on (Ebay)
But it could be resolved with a nifty little chip reset / cleaning programme which also has a facility to reset the waste counter and you can easily do it yourself.
This Free Chip Resetting Programme link comes with every Magic Inkjet Flush Kit and the Magic Inkjet Flush Kit is great if you ever need to UNCLOG an Epson or other inkjet printer.
But here's the FREE link
1. Click Here to download http://tinyurl.com/6cow8
2. Once downloaded
3. Install the programme
4. Then click on the SSC Service Utility icon
5. A window will be displayed with three options:
Choose Resetter and follow instructions...
It can also be used "Waste counter reset"
See my example below
Ink Monitor
Configuration
Resetter
6. Choose Configuration
7. Then select your printer from drop down list showing available Epson printers.
8. Now close the window.
9. A new icon will appear on your task bar (botton right of your monitor to left of clock.)
10. RIGHT Click on icon (a mini printer)
11. A new 9 line drop down will appear.
12. Make sure your printer is connected then
13. Choose 4th option
14. A new 3 option drop down will appear choose 2nd option = Reset protection counter.
15. You will now be asked HAVE You Replaced Waste Ink Pad ?
16. Choose YES
17. A new Information box will appear stating "Waste counter reset"
Thats it!
Rememember you may need to replace the absorbing pads later once they are full !
Good Luck!
Tinteiros (Ebay)
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Oct 29, 2009 | Epson Stylus C86 InkJet Printer
The message says parts inside the printer are nearing the end of their service life. What should I do?
This message means that the printer thinks the waste ink pads are full and so
> it refuses to print until the pads are replaced and the waste ink (protection)
> counter is reset.
> In practice the pads will not be full if this is the first time you have
> received the message so all that needs to be done is to reset the counter. Next
> time you must replace or clean the pads.
> Go to http://www.ssclg.com/epsone.shtml and download the utility.
> Install it, run it and exit it from the main window, now go to the icon in the
> system tray and right click on it. Select waste ink or protection counter and
> select reset. If this gives trouble then uninstall the Epson status monitor and
> try again (you can install the status monitir again afterwards).
> The irony is that the more you use an Epson printer the more reliable it will
> be (due to the heads being kept in good condition) but the people that use
> their printer most will get this message earlier than others. Some people never
> see this message. It is a good printer and well worth the effort of doing this
> at no cost.
> Tony
> MS MVP Printing/Imaging
The SSC service utility won't reset the R1800 counter.
The Epson service program is needed and can be downloaded from:
http://www.2manuals.com/
The R1800/2400 service manual can be downloaded from that site.
If you want to have a go at replacing the pads, then instructions are in
the manual.
Oct 09, 2009 | Epson Stylus Photo R1800 InkJet Printer
Printer won't printer as message says parts are
Part are end life cycle : waste ink pad full. Need to reset waste ink counter. SSc ver 4.3 support RX 620 and 640. U can try using printer model RX 640. Menu Protection Counter, Show current value for checking. Reset protection counter. Or Try to find RX630 adjusment at indoreset,blogspot.com. Don't forget to replace or wash the pad. Or extend outlet waste ink pipe to outside.
Jun 28, 2009 | Epson RX620 All-In-One InkJet Photo...
R230 Epson Printer
I cant print coz of my printer (R230 Epson Printer) blinking 2 red light. Printer dosnt ready. It say-Service required. how can I release this problem. Plz tell me.
Apr 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
Reset waste ink in Epson 10600
Hi there you can download this from my website.
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Download Free
Click Link = http://www.4all2sell.com/reset-tools/sscserve.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 13, 2008 | Epson Stylus Pro 10600 InkJet Printer
Epson R230 ink & Paper Lamp Blinking
my epson stylus photo R230 Printer problems always
two red light blinking
please help me
thank you
Sep 29, 2008 | Epson Stylus Photo R200 InkJet Printer
"parts inside your printer are near end of serviceable life"
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Jun 01, 2008 | Epson Stylus Photo R1800 InkJet Printer
Resetting ink counters on epson c42ux
You can try the other software you can use to reset the counter.
http://www.coldreset.com/modules.php?name=News&file=article&sid=95
Also make sure that on the ssc software, you have selected the correct printer model.
http://www.ianwillis.co.uk/c42/
Mar 24, 2008 | Epson Stylus C42UX InkJet Printer
Epson stylus c45
you need to download the resetter program the counter will have reached its limit and needs to be reset, it is fairly simple.
Dec 15, 2007 | Epson Stylus C46 InkJet Printer
Epson Stylus R265 InkJet Photo Printer Logo
151 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
