Home | Texas Instruments | TI-89 Calculator | OS failed now ins...
Texas Instruments TI-89 Calculator
Problem for Texas Instruments TI-89 Calculator
OS failed now installation screen stuck
By garland_geor on Sep 30, 2009
I downloaded a new os from TI's website. So I went to install it. Everything was going fine but when it finished the computer gave a failed notice, and the calculator is frozen on the software installation screen and says "waiting to receive"...The usb recognizes my calculator but status is not detectable SO therefore I can't reinstall the os or even restore my calculator.
Comments:
Oct 02, 2009
- here is my problem. The installation is over. Has been over for several days. But that installation screen is still stuck on my calulator. When it was installing the calculator went all the way to 99% and then stopped. I have tried taking out the batteries and all that good stuff. The main problem is I can't use TI connect to put a new OS on my calculator. Because it detects my calcualtor but its status is not detectable therefore it won't allow me to do anything throw ti connect or anything else as far as I know
Solution #1
posted on Sep 30, 2009
Not Rated)
k24674
Rank: Guru  Office Equipment  Expert
Rating: 87%, 648 votes
I suggest you interrupt the installation with [Esc] or [Diamond][QUIT]. Then download the OS on your computer and drag and drop OS on the open window of TI Connect to transfer it to calculator.
Press the [Diamond][QUIT] several times. If it refuses, all that is left for you to do is remove main batteries and restart the installation as described above.
Hope it helps.
Comments:
Nov 02, 2009
- Here is additional info from the TI kmowlege base
For the TI-89 Family, TI-92 Family, and Voyage™ 200:
Try a new set of AAA batteries (AA batteries on the TI-92 Family).
  1. Adjust the contrast by pressing and releasing the Diamond key followed by pressing and releasing the [+] key; repeat as necessary. To adjust or lighten the display, use the [-] key.
  2. Users of the TI-89 Titanium or Voyage 200 should see the following case before performing the following reset procedure to prevent the loss of valuable Apps.
    On the TI-92 family or Voyage 200, hold the [2nd] key and the [hand] key, then press and release the [ON] key. On the TI-89 family, press and hold the [2nd] key, left arrow, and right arrow; then press and release the [ON] key. This should reinitialize the operating system, in which you should see a progress bar filling on the screen.
  3. Remove one of the AAA or AA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. TI-89, 92 Plus, or Voyage 200 users should see "Press I to install code...", and should press the [9] key. The calculator should then say, "Waiting to receive...". TI-89 Titanium users should see "Waiting to receive..." or "Waiting to received OS...". You will need to restore the calculator's operating system.
Nov 04, 2009
- Here is a link to a Texas Instruments FAQ and Knowledge base article that addresses this question. Scroll down to get to the TI89 Part.
Was this helpful?
Yes
No
Popular Solutions for Texas Instruments TI-89
Questions and Unsolved Problems for Texas Instruments TI-89
Do you recommend Texas Instruments TI-89 Calculator?
Answer
Answer
If I try to make any graph besides a scatter plot, it locks up and it I haven't been able to get it... (More)
Answer
Half of the screen is black and half is well-lit. Editing the contrast results in one side of the... (More)
Answer
answer was tan-1(y)=x+@19 What does @19 mean?
Answer
when i installed the initial batteries, the calculator still had a blank screen. i adjusted the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Texas Instruments TI-89...:
Top Calculator Experts
Rank: Guru Guru
Solutions: 709
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Calculator Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
