Question about KitchenAid KGRA806PSS Gas Kitchen Range
On clean cycle, power went out, when power came back on there was no display and the door is still locked
  • craig_smi231 Sep 30, 2009
    Is there a fuse in the range, or just the circuit breaker on the house panel?
    President:
  • 1,462 Answers
This is the common problem with this thermador model...
Mostly,It was due to open circuit on L110C Thermostat behind rear panel part Number: 8300802..
First, check the fuse, if your fuse is perfect, then the issue is with this Thermostat..
Usually it happens with Kitchenaid range during cleaning, you have to change those parts to make it right..
Pleae leave me comment,if you need further assistance
RNJ VINODKUMAR
Posted on Sep 30, 2009
  • Vinod Kumar
    Vinod Kumar Sep 30, 2009
    Fuse i mentioned first is circuit breaker on the house panel, check whether its perfect
    Here is exactly what you should do:
    • unscrew the back panel (lots of screws) and just replace the thermo fusse (part Number: 8300802).
    • You can get this part at a store that sells applicance parts for probably under $15.00 and put it in yourself.
    • Apparently, KitchenAid gas stoves have this problem all of the time because the heat is too extensive for the part and it shortcircuts
    RNJ VINODKUMAR
I checked my circuit breaker + the stove top works so I know power going to stove...
Quick Clean cost ..12/25 ..dinner no oven ..I will call for service tomorrow as you stated the fuse in the stove ..hopefully thank you
Posted on Dec 26, 2009
5 Suggested Answers
philbran
  • 242 Answers
SOURCE: After using the self-clean cycle, display panel went black and oven door stayed locked.
Happens alot dont feel bad , self clean mode runs the elements at 500 deg. to cook off everything possible , what happens is the cabinet gets to hot and heats saftey temp. fuses until they go out and they are not resetable. they are always located in different areas of ranges but usaully in the back. you can ohm them out to check them if you have a meter.let me know if you have any other questions.
Phil
Posted on Apr 14, 2009
  • 8 Answers
SOURCE: ge xl44 after self clean cycle the door won't open
It will stay locked until it cools to at least 300 degrees
Posted on Dec 10, 2009
SOURCE: Ran Self Cleaning - Display went blank & Oven Door stayed locked
Solution #3 was very helpful. Took off the back panel and found the small black fuse. Removed the fuse and joined the two black wires, oven now turns on and oven door opens. Don't think it would be to safe to leave like this but going to get the part and put the fuse back in myself. Very easy to fix (just a million screws) so save yourself the expensive service charge!!!!
Posted on Apr 14, 2010
  • 9 Answers
SOURCE: The oven door cannot open. The self cleaning
Sounds like my problem two days ago. I have a Kitchen Aid free standing gas oven/range model
KGRI801PWH00. I read online that the thermo-fuse might've blown. I found the thermo-fuse after removing the rear panel. It was at the top/center. Mine is T-O-D (brand) 60F24; Westinghouse #8300802. I ordered mine from appliancepartspros.com for only $34.75; arrived in 36 hrs with regular shipping!! Easy to fix, sure beats several hundred $$ to repairman.
Don't bother to call Kitchen Aid - they'll just blow you off just like the hundreds of complaints said that I found online.
Posted on Jan 28, 2011
How to unlock a Maytag double oven
Hi Mary,If the door locked after you started the oven!
Press Cancel/Off key to start a latch reset, wait 20-30 seconds and open door, or turn the power off at the circuit breaker or fuse box for one minute, then turn the power back on.
If the oven has a manual latch handle!
Allow the oven to cool, approximately 30-90 minutes, move the latch arm to the left to unlock the door.
If the latch arm will not move after cooling to room temperature, or is stuck in between full right and full left positions, schedule service.
Is the oven door locked due to power failure during Self-Clean? If the oven door locked due to a power failure during a self cleaning cycle!
Select the "Self Clean" option, then select "Cancel". Wait a couple of minutes then try to start the cycle again.
If you started the oven clean cycle by mistake!
Press Cancel/Off key. The oven will need to cool to approximately 200F(95C) before the oven door will open.
Was there an error message!
Follow directions in the display, and refer to the Error Code Symptom, or:
Reset power to the oven!
  • Power the oven down by turning off the circuit breaker(s) or fuse(s) or if you can, unplug the oven for one (1) minute.
  • Turn the power back on turning on the circuit breaker(s) or fuse(s) or plugging it back in.
  • Monitor the oven for one (1) minute to ensure the error code does not display again.
  • Verify the ovens operation.
Kind regards
David
Dec 04, 2017 | Maytag Kitchen Ranges
JGBP35 "LOCKED DOOR" light will not turn off
Try below link for the manual. Hope this helps... http://products.geappliances.com/ApplProducts/images/t07/0000017/r17643v-1.pdf
Sep 06, 2007 | GE Spectra JGBP35 Gas Kitchen Range
Get message F9 on the display, I went to clean the oven in the self cleaning mode, heard the door latch trying to close, then it started beeping and flashing the F9 on the display. I turned off power for...
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 17, 2010 | Kenmore 95592 / 95594 / 95595 / 95599...
Whirlpool Oven Died During Cleaning Cycle No Display Now Locked
Had same problem with my KitchenAid. 10 years old. Ran self cleaning cycle, oven died!!!! Called repair. Appears to be thermal fuse. Part on order. Microcomputer had some brown spots on it. Tey wanted us to replace it too. But will wait to see if fuse is problem. Repair - $150 vs. $570. If it's the higher price, we'll buy a new oven before putting that kind of money into it. Will NEVER run a clean cycle again even if I have to buy a new oven.
Jul 16, 2009 | Whirlpool RBS275PD Electric Single Oven
Phil
Apr 14, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Feb 22, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
How do use self clean service?
CAUTION: SHOULD AN OVEN FIRE OCCUR,
CLOSE THE OVEN DOOR AND TURN OFF THE
OVEN. IF THE FIRE CONTINUES, USE A FIRE
EXTINGUISHER. DO NOT PUT WATER OR FLOUR
ON THE FIRE. FLOUR MAY BE EXPLOSIVE.
To set the controls for a self-clean cycle:
For satisfactory results use a 2 hour self-clean cycle for
light soils and a 3 hour cycle for average to heavy
soils.
1. Be sure the clock shows the correct time of day.
2. Press Clean. "— — —" appears in the display.
3. Press the Up Arrow until "3:00" appears in the
display for a 3 hour cycle, or press the Down Arrow
until "2:00" appears in the display for a 2 hour cycle.
4. As soon as the Up Arrow or Down Arrow is
released, "CLN" appears in the display.
5. As soon as the controls are set, the motor driven
lock will begin to close automatically and the "LOCK"
indicator light will flash. DO NOT open the door while
the light is flashing (it takes about 15 seconds for the
oven door to lock).
6. The "LOCK" light will glow until the cleaning cycle is
completed or cancelled, and the oven
temperature has cooled.
When the self-clean cycle is completed:
1. The time of day or “END” will appear in the display
window and the “Clean” and "LOCK" light will continue
to glow.
2. Once the oven has cooled down for about 1 HOUR
and the "LOCK" light has gone out, the oven door can
be opened.
3. If “END” is in the display and the “Clean” indicator
remains on, press Clear/Off. The time of day will
appear in the display.
NOTE: When the oven is cool, wipe away any residue
or powdered ash with a damp cloth or paper towel.
Stopping or interrupting a self-cleaning cycle:
If it becomes necessary to stop or interrupt a selfcleaning
cycle.
1. Press Clear/Off.
be opened.
3. Restart the self-clean cycle once all conditions have
been corrected.
How the ES 200 operates:
CAUTION: NEVER ATTEMPT TO REMOVE EITHER
THE BAKE OR BROIL ELEMENT WITHOUT DISCONNECTING
ELECTRICAL POWER FROM THE
RANGE. ELECTRICAL POWER IS CONNECTED
TO THE ELEMENTS WHENEVER ELECTRICAL
POWER IS CONNECTED TO THE RANGE.
The ES 200 electronic oven control system is made up
of three parts that control the bake and broil elements,
and the locking of the door in the self-clean cycle.
1. Electronic oven control.
2. Oven temperature sensor.
3. Oven door lock mechanism.
Dec 06, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Oven door won't unlock
I had the same problem on my Kenmore Electric Range. Door would not unlock. Tried pressing "Off" for multiple seconds, but still would not unlock. No error codes. Clock was displaying normally. Finally decided to try running it thru the self cleaning operation to get it to cycle thru locking and unlocking the door. When I started self clean, the door automatically went thru the auto lock and "locked" appeared in the display. I then hit "Off" to clear it and stop the cleaning cycle. The door then unlocked as normal!
Feb 16, 2008 | Kitchen Ranges
Door Keeps Locking and Unlocking after Power Outage
Located the switch - resetting fixed my stove as well.
Dec 17, 2007 | GE Profile JTP18 Electric Single Oven
GE Profile XL44 Spectra gas oven
My Spectra XL44 suddenly refuses to ignite the baking portion of the oven - broiler and top work just fine. The day before it was working fine. Wondered if it was an electrical egnition problem - gas feed or what??? Help!! Mregressor@aol.com
Nov 13, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
KitchenAid KGRA806PSS Gas Kitchen Range Logo
139 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
