Question about Gateway FPD2275W LCD Monitor
Videoseven 19 I have just purchased a V7 19" widescreen monitor, and I have hooked it up to my analog vga port (I have an Intel 845G integrated video card on my Compaq d510 SFF computer) but the colors are seriously washed out and the whites are way too bright. So,  I have tried using my dvi add on card (sil 164) but I get a lot of running and blinking pixels like Christmas lights on a tree in some of my images. Any ideas?
  • Anonymous Dec 21, 2007
    We have the same problem... Really washed out and whites are WAY too bright... We've tried downloading drivers, but nothing has worked.
  • 383 Answers
MS-DOS color command Examples. Color 0A = Creates a Black background with light bright green text, similar to many of the FTP, telnet, and old BBS console screens.
Good Luck, Please dont for get to Vote/Thank You
Posted on Dec 20, 2007
Hi i am looking for vga cable 9 Pin Female to 15 Pin Female thanks
The 9-pin port on your PC tower is NOT a video port, it is a serial data port. All VGA connectors are 15-pin. Hooking up to the 9-pin port will not get you a picture. There should be a VGA port on the PC, or else a DVI an/or HDMI port. You can get DVI-to-VGA adapters that work, but only if the DVI port is an analog DVI, not if it is a digital DVI (DVI-D or DVI-DD).
Feb 02, 2016 | LG Computers & Internet
Hi, I have a V7 L19WA - 19" widescreen monitor.
The fact that you can see a faint picture indicates that the monitor is working but the backlight circuit has a problem. The typical failures are blown transistors or bad capacitors. This can be troubleshot if you know how to unsolder and check the components with a meter. Don't know how technical you are, but if you are not, you could take to to an electronic repair service to fix. Hope this helps you.
Jan 24, 2011 | Videoseven L19WA 19" LCD Monitor
Screen is blak, has power
That either means it is not getting the signal from the PC or there is a problem in the monitor. You should try this monitor on another PC first, also check or try another VGA cable. Just need to narrow down the problem to either PC or the Monitor.
Apr 01, 2010 | Videoseven V7 R19WPS 19" LCD Monitor
Pixels only goes to 640X480
When you cannot increase the screen resolution nor a higher color bit, this usually means the video driver has defaulted to standard VGA driver and 8 or 16 bit color.
Install or re-install the latest video driver for your model video card.
When the correct video driver is installed you will be able to change the screen resolution and 32 color bit.
Dec 31, 2009 | Videoseven V7 E17PS 17" LCD Monitor
Cannot change to digital from analogue
Make sure you are using the proper connections.
VGA is analog and DVI is digital.
If you are using DVI and still having the same problem, then it may be a graphics card signal issue.
Oct 19, 2009 | Videoseven V7 L19PS 19" LCD Monitor
Monitor boots ok, then "Analog" appears/monitor shuts off
Does it have a digital port being used? If you are using the DVI port, it is probably digital. Try using the menu to selct the port. If it doesn't work, not sure from here. What is the model number?
Aug 01, 2009 | E-Machines 19" Widescreen Flat Panel TFT...
I cant able to install my SAmsung 19'Monitor Wide.Its gresults VGA card failure
It sounds like you are having a problem with your VGA Card (Video Graphics Adapter) and not with your monitor. Most monitors do not need to be "installed"
Go into your Device Manager and see if there are any items that have exclamation marks next to them. If there are, those are problem areas. Under Display Adapters there should be a specific item (Intel 845G, nVidia GeForce 9800 GT, Radeon 4850, etc.) and under Monitor should be "plug and play monitor".
Dec 08, 2008 | Samsung SyncMaster 920N 19" LCD Monitor
Monitor black out
try to adjust the setting of your video and refresh rate
Mar 12, 2008 | Videoseven V7 R19WPS 19" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
412 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
