Question about Dryers
Only blowing dry air.
Hey! my dryer is only blowing out cold air (even on high settings). the lint collector is all nice and clean. doesn't seem that there are any vents/houses out of whack. any suggestions?
  • yadayada
    yadayada May 11, 2010
    model and make
  • 73 Answers
Heating coils probably bad or could be a safety switch.
Posted on Oct 02, 2009
Where is the lint collector on LG 7.5g model WD 1049C Front Loader washing machine.
The combo washer/dryer doesn't have a lint collector. Air is circulated through a condensate tube and is washed down during each drying cycle.
Jun 16, 2011 | Washing Machines
Dryer cuts off after 10 minutes
Agree with you. Make sure the lint collector is clean and ditto for the vent. If it goes up to roof have to check it there also to make sure there are no obstructions whatsoever in vent line. Unit is turning off because it is overheating. If lint collector and vent is squeaky clean and unit blows out like crazy then the temp switch is opening up prematurely and might need replacement or jumping - your call. If you want to check for part go here Search Over 2 1 Million Appliance Parts
Sep 06, 2017 | Whirlpool LER4634J Electric Dryer
Why is lint collecting inside my Duet dryer? It is outside the drum and between the housing. The lint collector has little or no lint after drying. I have checked and cleaned the hose from the dryer to the...
take the lint filter out and put your hand in it,turn the dryer on,you should feel a stoung air flow sucking in,if not your still have a clogg somewhere
Feb 05, 2010 | Dryers
Whirlpool modle number LER7646AWO serial number MD1848149 dryer blows out cold air only it started by taking to long to dry clothing then it started to only blow cold air. Eveything else seems to work fine
if it was taking to long to dry that's a sign that you need a clean out on your dryer,you should have this done once a year so you don't have a fire.there is a thermal fuse that will pop if the dryer runs to hot probably from a lint buildup in the vent line or the lint filter duct,when was the last time you cleaned out the dryer?alot of people don't even know they should have the dryer cleaned out,unplug the dryer,take out the lint filter and remove the 2 screws on top where you pulled the filter out.now remove the vent line from the back of dryer and take off the back panel.on the left side you'll see the duct that the lint filter slides into,take the four screws out that hold the duct in place,on some dryers you can remove the duct to clean it and some you can pull it out from the bottom and move it to the right enough to get a vac nozzle into it,if the lint is packed in the bottom use a screw driver to scrape and lossen the pile and remove the big stuff by hand and then vac the rest,also vac the grate on the wall of the dryer half way up the duct and if you have a dryer brush stick it down where the filter goes to clean the duct out good,put the duct back and to the right of it and like 4 inches up from the floor you'll see the white thermal fuse part 3392519,check that with your meter to make sure that's the problem and most of the time it is this,if that's good read out the heater and the termostats to see what part is bad and make sure you have 240 volts going to heater if parts check good,if it was the thermal fuse take the front panel off of dryer by popping the top up with a screw driver and remove the 2 5/16 screws on the inside front panel,disconnect your door switch wires and pull the front panel up to remove it,vac out the inside of dryer,if you have a shop vac put it on blow and blow the lint off the motor and blow the lint from the back forwards so you don't have to pull the drum,put that back together,now if you have a long vent line blow it out with a leaf blower,sart the dryer,go outside and make sure the flapper is blowing open all the way and you should be all set,clean it out once a year so this doesn't happen again
Jan 10, 2010 | Whirlpool Dryers
Blows cold air , it still spins, but doesnt heat up.
Is this a condenser dryer or vented?
On the condensers, if the water collector is full it will only blow cold air. Sometimes the water pumps that bring the water to the collector bottles can go and it makes the dryer think that the bottle is full, therefore it will blow cold air.
Hope this helps!
Aug 13, 2009 | Maytag Dryers
My dryer leaves my clothes linty when they're dried.
Check your vent hose for blockage and the vent housing for outside.If air doesn't flow through it to outside it cant remove the lint.
Nov 30, 2008 | Dryers
Fisher and Paykel electric top load dryer
Dd you try to unscrew the larger lint trap underneath the lint cup collector. My serivce person showed me how to do this and after a year I cleaned it out and was surprised how much lint was caught in there. My dryer was not heating and drying quickly, this helped the problem.
Sep 11, 2008 | Fisher DEIX2 Dryer
Kenmore Dyer blowing cold air
Try cleaning out the the vent tube. Sometimes lint gets caught up in there over time. Hope this helps.
Mar 12, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
42 people viewed this question
Top Dryers Experts
