Question about Canon imageCLASS D880 All-In-One Laser Printer
Paper Jam at where the paper would exit.
We have a paper jam where the paper noramaly comes out. We have tried all ways to get it out and we can not. we have taken out the paper tray and ink cartrige and still the paper is no where to be seen exept a little piece of it where it would come out. Tried twizers and that didnt work Thanks
  • 56 Answers
You have to remove the fuser.
you need to remove the fuser in this order:
the drum unit
the left panel holding the glass
the glass
where the scanner is there is a black thin guide holding the ribbon cable...take that off.
the display panel
bottom left side panel
bottom read side panel
bottom top panel
flip over the black milar cover over the power supply.
disconect the 3 cables
move the platern about half way and you will see the holes on top of the platen aligned to the bottom so to get to the 3 screws holding the fuser unit.
undo the screws with a long star screw driver and slowly wigle the fuser out.
to put it back you do everything in the opposite order.
Good luck
Posted on Oct 09, 2009
Samsung SCX 4623F " Paper Jam Inside"
If you wish to get some details; check the site linked here. Pull up older posts.
Jul 05, 2016 | Office Equipment & Supplies
Fix paper jam 2 on a Samsung CLX-3170 printer
paper jam 2 is a jam in the fuser/exit area.
did the paper jam come out in one piece? if not reassemble the torn paper to see how much is still inside.
sometimes there will be a small fingernail size piece of paper holding open the fuser/exit sensor flag.
sometimes the sensor flag itself is dislodged and needs reassembly.
attached is video in how to dissassemble the printer if required
Sep 24, 2014 | Samsung Office Equipment & Supplies
My samsung scx-4623f always "paper jam in exit area" every time i print even though i always put out the jammed paper in the exit area.
While Samsung SCX-4623f printer always "paper jam in exit area" you get paper checks or trigger sensor paper cup
cong ty bao ve support
good luck
Jul 07, 2014 | Samsung SCX4623F Laser All-in-One Printer
Paper jam at exit
Have you set the tray to thick cardstock in the printer?
If not try that. This will let thicker paper go through more easily.
Make sure you bot have the tray as the printjob set up as the same type of paper.
How much does the paper weigh?
Also try printing from the manual feed. You're paper path is shorter that way and easier for the printer to handle.
Does it only jam on this type of paper?
Might be a fuser easy but don't think that's the case with this one.
Apr 01, 2014 | Xerox Phaser 6125 Laser Printer
C020 ON ESTUDIO 4511
There's a paper jam while the paper is trying to exit the printer. The definition of the error is saying that the leading edge of the paper has reached the exit sensor, but the other end of the paper hasn't yet. Because it's jammed...
It could just be a regular paper jam that needs to be cleared, or it could be a faulty exit sensor or a faulty registration roller, or registration sensor. I'd try clearing the jam thoroughly, and then try printing again. If it's a recurring error then you may need to call someone to replace a faulty part...
Jan 27, 2011 | Toshiba e-STUDIO 4511 Printer
My Samsung CLP 315w refuses to print a whole A4 page. Stops half way then message comes up paper jam but when I open back / front, paper not jammed and when I close it document continues printing then...
most likly hood is your exit sensor is faulty. The printer work in this way. if it does not print out all the document. it will print again. that is why you kept getting this same issue after a jam open and close door it will print again.
replace the exit sensor it will help.
Apr 16, 2010 | Samsung CLP-315W Laser Color Printer
I am trying to find a part I believe it is called the paper jam sensor. How can I confirm that this is the part I am looking for?
If you are getting paper coming part way out of the top exit and giving a jam error, you need a new exit sensor. # 0604-001393
Sep 24, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Copier canon mf4150 says it has a paper jam, but there is no paper jam.
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
Sep 16, 2008 | Office Equipment & Supplies
Canon imageCLASS D880 All-In-One Laser Printer Logo
253 people viewed this question
old marine
old marine
