Question about GE Dryers
Makes loud noise when running
Makes loud screeching noise when running. Sometimes thumps also.
  • 73 Answers
Bad berring that the drum rides in
Posted on Oct 02, 2009
It is makeing a lot of noise
Hello. You didn't provide a brand/model number or the type of noise the unit is making. If the dryer is making a screeching noise, it's probably the idler pulley(spring-loaded tensioner pulley that keeps the drum belt tight so the electric motor can turn the drum properly) being worn out or binding up due to lint build-up in the dryer. However, if the dryer is "thumping" loudly, most likely it's a worn out support roller either on the front or rear bulkhead. They're made of hard rubber and can become malformed due to wear/age causing a rough movement of the drum as it spins.
Aug 18, 2015 | Dryers
Screeching noise upon start only.. Not sure what it could be
Check ur fan belts/ serpent belt .open hood you stand in front of car have someone start it and see if make noises
Jul 16, 2014 | Cars & Trucks
My car makes loud screeching noise when starting.
could be your serpentine belt. usually when they get worn they will start to either slip or cause a very high pitched screeching noise. to verify that is the cause get some water or brake clean in a spray bottle and spray it on to the belt while the vehicle is running. if the noise goes away for a moment you found your cause. if not then its something else. Hope this helps
May 29, 2014 | 2009 Hyundai Sonata
Making loud screeching noise
I would have the disc brake pads checked as there is a spring tab that runs on the disc rotor when the pads as too far worn.
Oct 08, 2013 | Volkswagen Cars & Trucks
Thumping/Screeching sound, MD:LDE8616ACE. Rollers? Idler Pulley?
Your description sounds like one or both of the rear drum supports (rollers) is bad. A quiet thumping is almost always present as the weld in the drum comes in contact with the drum supports. A binding support will squeal, and the thumping could be worse at that time. After running the dryer until the noises are present, once disassembled, you can tell if a support is bunding or rolling normally by spinning it by hand. The same goes for the idler pulley. Make sure power is disconnected from the unit befor attempting any repairs.
While the unit is disassembled for repair, make sure your your old cat is not inside.
Sep 11, 2009 | Maytag PYE2300AY Electric Dryer
Screeching noise
If your C/V joint is going bad it will make a nasty clicking sound and get louder the longer you leave it unattended.If this noise went away it could have been something stuck it the moving area of your wheel and just worked itself out.Keep an ear out for the noise to return,it it dosen't come back be happy.
Jul 23, 2009 | 1996 Honda Civic
Bernina deco noise
See if drive belt is not running against the plastic body on right side.!
Nov 17, 2008 | Bernina Bernette Deco 600
Audio noise while car is on no prob in past
I've had that same problem before. What was happening is one of my amps safety cut off usually a built in surge protector basically, was coming on thus the loud thump. Most of the time when it comes on the amp goes off. Could be a power issue as well. Have your alternator checked too. Once your car is started it is run by your altenator so it could not being supply enough power. I fixed my problem by adding two 1 fared capacitor, one for each amp I was running.
May 20, 2008 | Car Audio & Video
Noise
When the freezer goes into defrost mode, some thumping/popping noises can sometimes be heard as the defrost heater melts the ice built up on the evaporator. Quite normal.
Nov 01, 2007 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Dryers Logo
112 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
