Question about Smart Parts Shocker NXT Paintball Gun
My SP1 paintball gun is leaking out of the regulator, It's a little above where the snap ring is and below the front grip. The part that sort of swivels around if you unscrew the ASA.Sorry about the wrong product but I couldn't find the SP1
Most likely you have a small piece of debrie in the regulator. You may need a new set of orings also. They last more than 5-10 games. please. Dow 33 on the bolt every month.
www.theoringstore.com
Posted on Oct 08, 2009
  • 85 Answers
Check your O rings, they degrade over time and only really last maybe 5-10 games. You should lube your orings after every play and replace when needed. Kits are available to take with you.
Posted on Oct 03, 2009
When i hook the air tank up air comes out the barrle
**** the gun before you attach the tank.
If it's still leaking it cold be bad "O" rings on the bolt.
Check all your "O" rings
Feb 24, 2011 | Paintball Tippmann U.S Army Alpha Tactical...
Inconsistent velocity, and my velocity adjuster doesn't seem to be working
This is caused when a gun needs cleaning and-or O-rings are worn.
Tear down the gun and clean the lube with the special paintball gun oils
and reassemble. See if it is better. CO2 is terrible for paintball guns.
Go with HPA (High Pressure Air, aka Nitrogen) and this will help.
Feb 16, 2011 | Tippmann 98 Custom Act Paintball Gun
I got a co2 leak
The A5 standard is a pretty compact gun depending on the place of the leak I could assist you better. In any case you best chance is to check for leaks in the o-rings at the CO2 bottle, at the regulator.
Jan 12, 2011 | Tippmann A 5 Standard Paintball Gun
When i screw my tank on the CO2 goes right through the gun and out the barrel
**** it and that should stop.
If that persists make sure you have cleaned the marker and used a good paintball oil to lubricate the internals.
At the next level you could have a o-ring that's old, brittle, broken and now is leaking by. Your local airsmith should be able to provide the necessary part(s) or fix it in short order for you.
Play hard, play safe, play with honor!
8^)
Nov 07, 2010 | Tippmann 98 Custom Act Paintball Gun
Co2 leaks from Tippmann 98 custom barrel all of the time.
If you **** it you may find that that stops. Or **** it and then screw in your tank. Make sure you have plenty of air in the tank too, low pressure can sometimes not engage the valve enough to close.
My first suggestion is to pull out the internals and clean/lube them with a good oil made for paintball.
It's possible it could be an o-ring, but I'd try the above first. If it's been a while since you've had any o-rings replaced it might be a good time for a tuneup. Get a kit and change 'em all and you know everything is good to go rather than waiting for something to fail.. and if one fails it's probably only a matter of time before another one gives.
8^)
Sep 08, 2010 | Tippmann 98 Custom Act Paintball Gun
I have a semi auto alpha black. When im firing on semi auto sometime the gun switches quickly to fully auto and releases lots of CO2 without really shooting any paintballs
Does this only happen when you're low on air? Also, make sure you're using a good paintball oil for lubrication and make sure the marker is clean. It's possible for an o-ring to leak, or once it gets cold to leak, so make sure you use the proper o-ring for the proper location (lots of them look alike so keep them labeled and bagged separately).
8^)
Aug 19, 2010 | Paintball Tippmann U.S Army Alpha Tactical...
I **** the marker. screw in hpa. so far so good. no leaks. fire it a few time and there is a leak coming from inside. i can hear air from barrel and the oval cocking handle hole. i have taken apart the...
Replace all of the o-rings within the gun make sure that the striker pin is free to move. The striker pin is the one that the big striker hits, it is on the inside of the pressure tube.
Apr 08, 2010 | Tippmann 98 Custom Act Paintball Gun
As soon as I screw on the CO2 supply cylinder, I hear air leaking internally. The last time I used it, it worked perfectly. Any ideas?
O-ring. If it is leaking near the tank, it is the o-ring on the tank. Otherwise, it could be one of many o-rings inside the marker. I would take it to a gunsmith and get all the o-rings swapped out.
Mar 01, 2010 | Tippmann 98 Custom Act Paintball Gun
My regulator leaks.
When I get a gun that leaks, I start as close to the bottle as I can, and start replacing o-rings, one at a time. Or you can just do them all. There is only one or 2 that are special cold air rings, and the last time I rebuilt one, I didn't even bother with the special rings, just put in the same as the rest. Worked fine. There are about 20 of them in a gun, all the same size. You can a lot of parts on ebay.
Feb 18, 2010 | Smart Parts Shocker NXT Paintball Gun
Paintball gun is rapid firing when trigger is pressed. CO2bottle is full and i have tried other bottles but stillth same.
Tippmanns are known for their reliability and are very simple markers making them very easy to repair. you need oil from a local paintball shop or regular sewing machine oil will do.
On one side of the marker there is a little "handle" for cocking the gun, pull that handle as far back as you can and you will see 1 o-ring. put 2 drops of oil on it and fire it a couple times without paintballs to test it. This solves the problem 9/10 for tippmanns, if not..
Sometimes paintballs can break inside your gun. Look and feel inside your breech (where the paintballs go into the gun) and check for paint. If its dirty this can be causing your problem, strip it down and clean it (refer to your manual if you have difficulty)
on one side of the marker there is a little "handle" for cocking the gun, pull that handle as far back as you can and you will see 1 o-ring. put 2 drops of oil on it and fire it a couple times without paintballs to test it. This solves the problem 9/10 for tippmanns
Jan 08, 2010 | Tippmann 98 Custom Act Paintball Gun
Smart Parts Shocker NXT Paintball Gun Logo
174 people viewed this question
Top Smart Parts Sport & Outdoor - Others Experts
Are you a Smart Parts Sport and Outdoor - Other Expert? Answer questions, earn points and help others
