Question about RCA M4204 MP3 Player
Got wet went through the washer. I left it on a table next to our dehumidifier for 2 weeks to dry it out. Still won't work.
  • 4 Answers
Of Course it wont -.-... It went through the washer! Nothing works once it goes through the washer...Believe me i know...-.- My cell went through the washer...
Posted on Oct 01, 2009
The display cannot be seen, as the blue background light has slowly went dim.
10 years is not quick in my book 2 weeks might be and I have seen LEDs die in less than a month .
Jul 11, 2015 | Dehumidifiers
My friend has an xqg65-11 all in one that she bought used. It worked fine for a few weeks, then started to not move to the next cycle, it just stopped. She has been manually clicking it to the next cycle....
There is a lint filter right under your washer door. You push that lid open, and you will find the lint filter. I have the same machine. but min is an xqg50-11. Is that a washer/dryer combo?
Jul 20, 2011 | Haier XQG50-11 Front Load Washer / Dryer
Washer is completing all cycles, but water from wash cycle.is left.in washer and clothes are still soaking wet. No water drains out.
check the Lid safety switch, if its shorted the spin cycle won't work, so your left with wet clothes ,, you can jumper the 2 wires together to test the switch , if that makes the cycle work, Replace that switch
Jul 06, 2011 | Washing Machines
Samsung captivate got wet and now phone dosen't come on
Samsung captivate got wet and now phone dosen't turn on do not worry put out your sim card and memory card and battery put your mobile under table lamp 3 or 4 hours when the water is dry in your mobile put back battery sim and memory card back and turn it on i hope it work i think it is helpful to you please vote me thanks
Jun 28, 2011 | Cell Phones
Dryer stopped heating
this is likley to be the heat seconsers or its the heater/s burnd out if one of the elements have died on you it will only partly dry the washing,, not a hard job to fix but still a bit pricy,
Oct 24, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Goldstar dehumidifier model DH305Y6 is there an outlet on this model for a hose so can drain into sump pump?
I have a Goldstar dehumidifier, Model DH305Y6. I bought it about 5 years ago at a local Walmart. During the summer I run it in the basement, here in south-central Pa. When it was brand new it worked very well, for about 2 yrs. Then it began turning on & off very irregularly. At first I thought it was the sensor on the front of the coils. So I moved it to the lower left side of the coils, and had the same results. The other day the water heater in the basement developed a leak. About 300 gals. of water covered the floor. After sumping/wet-vac'ing down to a wet carpet, I pulled out the dehumidifier and plugged it in,(the filter was cleaned before put away last summer). It began its on/off cycling again. It runs for about 2-3 mins., then shuts off for about 5-10 mins. So, I took the On/Off switch apart and read the resistance. It read 48k, for the 50k switch. I turned the switch all the way left to all the way right and it went from 48k, down to about 8k. The two wires to the switch were attached to the #2 and #3 poles,(only 3 poles). I did some testing, then removed the wires and re-soldered them to the #1 and #3 poles. I put everything back together, and now it works. It runs constantly, but it works/runs just fine. I need to get the basement dry, so I will let it run until the job is done. In the Spring I will get a new 50k potentiometer,(on/off switch), and see if that works. I will post results if I remember to.
Sep 29, 2009 | Goldstar Dehumidifiers
Worked well, then blew the fuse.
What you should do next is stop using an extension lead. As you've already discovered, there's a risk of the connection getting wet, which is potentially very dangerous, but this is probably not the main problem. Most extension leads (the normal domestic type) are simply not capable of carrying the current needed to run your pressure washer.
Rather than using an electrical extension, use an extension high-pressure hose and work further away from the machine (which also makes it easier to keep the machine dry).
If this doesn't sort the problem, please post here again and we'll try something else.  Good luck!
Mar 10, 2009 | Karcher K2.26 Electric Power Washer
Dehumidifier
After reading comments and complaints from other frustrated Maytag owners, I just went out and bought a new LG EnergyStar dehumidifier. I'm taping the receipt inside a plastic bag, along with the user manual, to the side of the machine. Hope this one works for a LONG time! Ronnisue
Jun 15, 2008 | Maytag Dehumidifiers
Wife wash it with the week laundry
My mate washed hers thru washing machine, within 3 weeks of being left to dry out, it worked fine!
Dec 19, 2007 | Samsung SCH-u740 Cellular Phone
RCA M4204  MP3 Player Logo
66 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
