Question about Cell Phones
My phone keeps freezing
I have a nokia and I'm with 3 but my phone keeps freezing when I start it up, what can I do to fix this?
My Nokia C3-01 keeps freezing, can't log in to get
This solution should help fix the issue. I advise you use the Nokia PC Suite to backup your phone data prior to doing this reset. Also, you should download and install Nokia Software Updater and use this to update your phones firmware and software in the future.
  1. Enter *#7370# code from the keypad. and press the Dial button.
  2. Type unlock code 12345 press continue.
  3. Restart your phone.
  4. You should check for updates on the phone at this time Enter *#0000# from the keypad and press the dial button
  5. Select "Options" and then select "Check for updates".
Remember to backup your phone before performing these functions.
May 15, 2011 | Nokia Cell Phones
How can i fix my nokia n70 when i turn it on only the white screen show but sometimes it works but its freezing...
just switch of your phone and remove your memory card and press hold * 3 and call button and on the phone it will work and dont move your finger from the * 3 and call button up to when phone dosent start
Dec 26, 2010 | Nokia N70 Cellular Phone
Nokia n70 dont boot , it always freeze and stop when it start to boot ,  what's solution  to fix that problem?
try this way:
Switch-off your phone.
1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone.
Remember, do not let go the 3 press and hold keys until you see a formatting word screen show!
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Nov 05, 2009 | Nokia N70 Cellular Phone
Nokia n97 screen freeze
Upgrade your firmware to 11.0.021 and restore your device to factory settings. also dont install apps in phone memory. keep phone memory free.
Aug 06, 2009 | Nokia N97 Cell Phone
When switch on,only "NOKIA" logo display then freeze.
Power off the phone.
Press and hold Green, * and 3.
Keep them held while Phone is powering on and for a few seconds after that.
It will Format your phone compleatly and bring it back to the Factory Setting.(But the data which is on memory card will not delete)
I am sure this is going to work
Apr 23, 2009 | Nokia 3230
My nokia n95 keeps freezing alot keep freezing while using the GPS or sometime w/o any sw running
When you run apps and use web especially when watching online videos, ram of your n95 quickly start ending.When the ram completely finishes, your phone freezes and reboot.So you should continuously clear private data while browsing and don't run more than one software at a time so you can save the ram.
Mar 31, 2009 | Nokia N95 Cellular Phone
How to format nokia 6600
format code of nokia 6600 is
*#7370#
*#7780#
Mar 21, 2009 | Nokia 6600
Nokia 6265i only play the nokia and telus welcome and hung
Try *#7780# for a reset, you may have to try it several times.
Jan 18, 2009 | Nokia 1100
Nokia N95 8GB - Freezing up.
Hi greystar,
All I can say is a HARD RESET will solve your problems(and eventually all your problems)!
First backup the important stuff like the contacts, messages, apps, etc. using the Nokia Content Copier available from the Nokia PC Suite.
Then switch off your phone.
Now, press and hold the ' * - Star', '3', & 'Call - The Green key that you use to recieve a call' together and switch on your phone. Keep the above mentioned keys pressed till you see the "Select Region" screen.
Hope that helped! :-)
Regards,
Sam
Nov 30, 2008 | Nokia N95 Cellular Phone
Cell Phones Logo
41 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
