Question about Microsoft Windows XP Professional
Autorun.inf worm & some cookies.dat hook
I'm on Win XP, SP3 and am pretty sure I have a autorun.inf type worm. In addition to that, there's something that's disabled task manager, regedit, CCLeaner, Avast and worst of all MMC.exe so I can't see my Event logs. Process Explorer tells me every available .exe is either loading or holding onto the "USER\Cookies\Cookies.dat" file as well as a few files in \temp and "Local Settings\Temporary Internet files" which keeps getting repopulated even though I'm not connected to the internet. Hijackthis and ProcExp do not show any strange .exes running but it's definitely residing in memory.
Everytime I insert a protected USB drive, any of the running .exes will generate an error that they could not write to the disk. Also, a lot of applications have started giving R6002 floating point error. Safe mode restarts lead to a blue screen with a chkdsk or a 0x0000007B stop.
  • pinhuman Sep 30, 2009
    I tried restoring from 1 to 7 days before I discovered the infection. Apparently what entered the system entered before then. And, I can't restart in Safemode anymore. It either shows me a bsod with a CHKDSK recommendation or a 0x0000007B stop error.
    Scholar:
  • 89 Answers
Try combofix. Highly rated and reviewed. I use it on a daily basis on my customers computers. Never had it not work unless OS wouldnt load. Runs in windows and is dos based so no risk of executing GUI worms. And its free! Highly, Highly, Highly recommend you try this. In my experience and tech help, I would never recommend anything I wouldnt use myself. One thing though, do not use it on Vista! New version will be out soon for Vista.
Download Here: http://www.combofix.org/
Posted on Oct 01, 2009
Testimonial: "Thanks, I did try combofix but not after disabling system restore. I'll give it another go."
  • 202 Answers
Have you tried restoring to an earlier date? To do that, start the laptop in Safe Mode and let it boot. When the warning screen comes up, click no and you will go into the system restore mode. Go back to a date prior to when you noticed the suspect activity. If that does not help, let me know and we can try something else.
~ Spoem
Posted on Sep 30, 2009
  • 700 Answers
Slave scan your hard drive unto another computer with good installed anti virus and antimalware or spyware. Better for an enclosure.
And take note what infection that hits you. For in the future you can get use the info to properly purge out that kind of infection.
If that is an autorun driver. Most probably you get that on a removable drive like flash drive.
Worm.win32.autorun.blw virus appear in my system i already use kesper sky, but not solved. please advise a solution. thanx
When the executable is run on the victim's machine, the worm copies itself to the following locations:
  • %Application Data%\remove.exe (Copy of itself)
  • %Application Data%\autorun.inf
Where %Application Data% = c:\Documents and Settings\All Users\Application Data
Autorun.inf has following command
Exp: [autorun]
shellExecute=remove.exe
The worm adds a Run entry in registry so that it executes itself at every startup:
  • HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
    "(Default)" = "%Application Data%\remove.exe"
Symptoms -
  • Presence of above mentioned files.
  • Presence of registry entries mentioned above.
Method of Infection Method of Infection - This worm spreads by using autorun.inf on shared drives and removable devices.
Removal - A combination of the latest DATs and the Engine will be able to detect and remove this threat. AVERT recommends users not to trust seemingly familiar or safe file icons, particularly when received via P2P clients, IRC, email or other media where users can share files.
Thanks for using fixya..
Sep 14, 2009 | Computers & Internet
Tip
Windows Cannot Find "Copy.exe"
When i installed AVG Free last time it removed few virus including "copy.exe". so whenever i go to "My Computer" (win key + E) and double click on any hard drive then i find an error stating that (Windows cannot find "Copy.exe").
Solution:
Well the solution for this "copy.exe" conundrum is to get rid of a file called autorun.inf in each of the infected hard drives. here's the solution for the problem......
Make sure you or the virus scanner is run through the infected hard drives/flash drives. to make sure the virus files is gone.
Now, some forums said you could just select "Show Hidden Files" from the option and this would enable you to see "autorun.inf" file.
Also, some entries in the "autorun.inf"may be legitimate. so to check the file (even when you can't see the file) do this: Type in the infected hard drive label followed by autorun.inf for example f:\autorun.inf
This will load autorun.inf file in notepad.if the only entry is that incriminating copy.exe then this is what i did. i tried to overwrite the file with the same name autorun.inf. that din't work because autorun file was readonly. so i saved that blank file on the desktop and simply cut it and pasted it into the drive, then selecting the overwrite option. that should stop that annoying windows cannot find "copy.exe" message every time you double click into a drive. this will solve the problem!
Read more: http://comsguru.blogspot.com/2009/12/windows-cannot-find-copyexe.html#ixzz0nMpOFGpo
on May 08, 2010 | Computers & Internet
Error : em8tqm.cmd
may be it cause virus praveen
go to start button and click run
and type cmd
then type
cd\ and press enter
then type
attrib -r space -h space -s space autorun.inf then enter
ex: 1. attrib -r -h -s autorun.inf enter
2. del autorun,inf enter
after that go to d: and press enter
Apr 08, 2009 | Microsoft Windows XP Professional for PC
Autorun.inf virus prob.
go to start button and press run option type cmd type cd\  2. type c: and press enter
3. type attrib -r -h -s autorun.inf
4. type del autorun.inf
Apr 01, 2009 | Microsoft Windows XP Home Edition
Cannot access anti-virus websites
Download STINGER antivirus and scan with this tool.
Variants Can Detect:
BackDoor-ALI,BackDoor-AQJ,BackDoor-AQJ.b,BackDoor-CEB,BackDoor-CEB!bat,BackDoor-CEB!hosts,BackDoor-CEB.b,BackDoor-CEB.c,BackDoor-CEB.d,BackDoor-CEB.dll,BackDoor-CEB.dr,BackDoor-CEB.e,BackDoor-CEB.f,BackDoor-CEB.sys,BackDoor-CFB,BackDoor-JZ,BackDoor-JZ.dam,BackDoor-JZ.dr,BackDoor-JZ.gen,BackDoor-JZ.gen.b,Bat/Mumu.worm,Cleanup,CoreFlood,Coreflood!psexec,Coreflood.dldr,CoreFlood.dll,CoreFlood.dr,Danmec,Downloader-DN.a,Downloader-DN.b,Downloader-UA,Exploit-DcomRpc,Exploit-DcomRpc.b,Exploit-DcomRpc.dll,Exploit-Lsass,Exploit-Lsass.dll,Exploit-MS04-011,Exploit-MS04-011.gen,Exploit-MSExcel.k,Exploit-MSExcel.l,Exploit-MSExcel.m,Exploit-MSExcel.n,Exploit-MSExcel.o,Exploit-MSExcel.p,Exploit-MSExcel.q,Exploit-MSExcel.r,Exploit-PDF.b,Exploit-PDF.c,Exploit-PDF.d,Exploit-PDF.e,Exploit-PDF.f,Exploit-PDF.g,Exploit-PDF.h,Exploit-XMLhttp.d,Exploit-XMLhttp.d.gen,Exploit-XMLhttp.d.gen.b,Exploit-XMLhttpd.d,FakeAlert,FakeAlert-AA,FakeAlert-AB,FakeAlert-AB!htm,FakeAlert-AB.dldr,FakeAlert-AB.dr,FakeAlert-AC,FakeAlert-AD,FakeAlert-AE,FakeAlert-AF,FakeAlert-AG,FakeAlert-AG.gen.b,FakeAlert-AG.gen.c,FakeAlert-AH,FakeAlert-AI,FakeAlert-AJ,FakeAlert-AK,FakeAlert-AL,FakeAlert-AM,FakeAlert-AN,FakeAlert-AntiVirusPro,FakeAlert-AntiVirusXP,FakeAlert-AO,FakeAlert-AP,FakeAlert-AQ,FakeAlert-AR,FakeAlert-AS,FakeAlert-AT,FakeAlert-AU,FakeAlert-av360,FakeAlert-AW,FakeAlert-AZ,FakeAlert-AZ!htm,FakeAlert-B,FakeAlert-B.dldr,FakeAlert-B.dr,FakeAlert-BA,FakeAlert-BB,FakeAlert-BC,FakeAlert-BD,FakeAlert-BE,FakeAlert-BE.gen,FakeAlert-BF,FakeAlert-BG.dldr,FakeAlert-BH.dldr,FakeAlert-BI,FakeAlert-BJ,FakeAlert-BK,FakeAlert-BL,FakeAlert-BM,FakeAlert-BN,FakeAlert-BO,FakeAlert-BO.dldr,FakeAlert-BP,FakeAlert-BQ,FakeAlert-BR,FakeAlert-BS,FakeAlert-C,FakeAlert-C.dr,FakeAlert-C.gen,FakeAlert-D,FakeAlert-E,FakeAlert-F,FakeAlert-G,FakeAlert-H,FakeAlert-I,FakeAlert-J,FakeAlert-K,FakeAlert-L,FakeAlert-LastDefender,FakeAlert-M,FakeAlert-N,FakeAlert-N.dldr,FakeAlert-O,FakeAlert-P,FakeAlert-Q,FakeAlert-R,FakeAlert-S,FakeAlert-S.dll,FakeAlert-SpyKiller,FakeAlert-SpywareGuard,FakeAlert-T,FakeAlert-U,FakeAlert-V,FakeAlert-W,FakeAlert-WinwebSecurity,FakeAlert-X,FakeAlert-XPAntivirus,FakeAlert-XPSecCenter,FakeAlert-Y,FakeAlert-Y.dr,FakeAlert-Z,Fribet,Generic FakeAlert,Generic FakeAlert.d,Generic FakeAlert.e,Generic!atr,HideWindow,HideWindow.dll,HTool-T2W,IPCScan,IRC/Flood.ap,IRC/Flood.ap.bat,IRC/Flood.ap.dr,IRC/Flood.bi,IRC/Flood.bi.dr,IRC/Flood.cd,JS/Autorun.worm.ci,JS/Downloader-AUE,JS/FakeAlert,JS/FakeAlert-AB.dldr,NTServiceLoader,ProcKill,Proxy-Agent.af,Proxy-Agent.af.dr,PWS-Banker.dldr,PWS-FireMing,PWS-FireMing.dll,PWS-FireMing.dr,PWS-Gamania.gen.a,PWS-Narod,PWS-Narod.dll,PWS-Narod.gen,PWS-Sincom,PWS-Sincom.dll,PWS-Sincom.dr,rootkit,VBS/Autorun.bj,VBS/Autorun.worm.au,VBS/Autorun.worm.ay,VBS/Autorun.worm.bi,VBS/Autorun.worm.bj,VBS/Autorun.worm.bs,VBS/Autorun.worm.by,VBS/Autorun.worm.ca,VBS/Autorun.worm.cy,VBS/Autorun.worm.dm,VBS/Autorun.worm.dn,VBS/Autorun.worm.dn!atr,VBS/Autorun.worm.dn!txt,VBS/Autorun.worm.dv,VBS/Autorun.worm.dz,VBS/Autorun.worm.en,VBS/Autorun.worm.k,VBS/Autorun.worm.k!bat,VBS/Autorun.worm.zd,VBS/Autorun.worm.ze,VBS/Autorun.worm.zl,VBS/Autorun.worm.zn,VBS/FakeAlert-AB,VBS/IE-Title,Vundo,Vundo.dldr,Vundo.dr,Vundo.gen.h,Vundo.gen.i,Vundo.gen.j,Vundo.gen.k,Vundo.gen.l,Vundo.gen.m,Vundo.gen.n,Vundo.gen.o,Vundo.gen.p,Vundo.gen.r,Vundo.gen.s,Vundo.gen.t,Vundo.gen.u,W32/Anig.worm,W32/Anig.worm.dll,W32/Autorun.worm,W32/Autorun.worm!inf,W32/Autorun.worm!ini,W32/Autorun.worm.a,W32/Autorun.worm.aa,W32/Autorun.worm.ab,w32/autorun.worm.ac,W32/Autorun.worm.ad,W32/Autorun.worm.ae,W32/Autorun.worm.af,W32/Autorun.worm.ag,W32/Autorun.worm.ai,W32/Autorun.worm.aj,W32/Autorun.worm.ak,W32/Autorun.worm.al,W32/Autorun.worm.am,W32/Autorun.worm.an,W32/Autorun.worm.ao,W32/Autorun.worm.ap,W32/Autorun.worm.aq,W32/Autorun.worm.ar,W32/Autorun.worm.as,W32/Autorun.worm.at,W32/Autorun.worm.av,W32/Autorun.worm.aw,W32/Autorun.worm.ax,W32/Autorun.worm.az,W32/Autorun.worm.b,W32/Autorun.worm.b.cfg,W32/Autorun.worm.ba,W32/Autorun.worm.bb,W32/Autorun.worm.bc,W32/Autorun.worm.bd,W32/Autorun.worm.be,W32/Autorun.worm.bf,W32/Autorun.worm.bg,W32/Autorun.worm.bh,W32/Autorun.worm.bk,W32/Autorun.worm.bl,W32/Autorun.worm.bm,W32/Autorun.worm.bn,W32/Autorun.worm.bo,W32/Autorun.worm.bp,W32/Autorun.worm.bp!reg,W32/Autorun.worm.bq,W32/Autorun.worm.br,W32/Autorun.worm.bt,W32/Autorun.worm.bw,W32/Autorun.worm.bx,W32/Autorun.worm.bx!inf,W32/Autorun.worm.bx.gen,W32/Autorun.worm.bz,W32/Autorun.worm.c,W32/Autorun.worm.cb,W32/Autorun.worm.cb.dr,W32/Autorun.worm.cc,W32/Autorun.worm.cd,W32/Autorun.worm.ce,W32/Autorun.worm.cf,W32/Autorun.worm.cg,W32/Autorun.worm.ch,W32/Autorun.worm.cj,W32/Autorun.worm.ck,W32/Autorun.worm.cm,W32/Autorun.worm.cn,W32/Autorun.worm.co,W32/Autorun.worm.cp,W32/Autorun.worm.cp!bat,W32/Autorun.worm.cq,W32/Autorun.worm.cr,W32/Autorun.worm.cs,W32/Autorun.worm.ct,W32/Autorun.worm.cu,W32/Autorun.worm.cv,W32/Autorun.worm.cw,W32/Autorun.worm.cx,W32/Autorun.worm.cz,W32/Autorun.worm.d,W32/Autorun.worm.da,W32/Autorun.worm.db,W32/Autorun.worm.dc,W32/Autorun.worm.dd,W32/Autorun.worm.dd!inf,W32/Autorun.worm.de,W32/Autorun.worm.df,W32/Autorun.worm.dg,W32/Autorun.worm.dh,W32/Autorun.worm.di,W32/Autorun.worm.dj,W32/Autorun.worm.dk,W32/Autorun.worm.dl,W32/Autorun.worm.dn,W32/Autorun.worm.do,W32/Autorun.worm.dp,W32/Autorun.worm.dq,W32/Autorun.worm.ds,W32/Autorun.worm.dt,W32/Autorun.worm.du,W32/Autorun.worm.dw,W32/Autorun.worm.dx,W32/Autorun.worm.dy,W32/Autorun.worm.e,W32/Autorun.worm.ea,W32/Autorun.worm.eb,W32/Autorun.worm.ec,W32/Autorun.worm.ed,W32/Autorun.worm.ef,W32/Autorun.worm.eg,W32/Autorun.worm.ei,W32/Autorun.worm.ej,W32/Autorun.worm.ek,W32/Autorun.worm.el,W32/Autorun.worm.em,W32/Autorun.worm.eo,W32/Autorun.worm.ep,W32/Autorun.worm.eq,W32/Autorun.worm.f,W32/Autorun.worm.g,W32/Autorun.worm.gen!job,W32/Autorun.worm.gen.cl,W32/Autorun.worm.gen.za,W32/Autorun.worm.gen.zb,W32/Autorun.worm.h,W32/Autorun.worm.h!lnk,W32/Autorun.worm.i,W32/Autorun.worm.j,W32/Autorun.worm.l,W32/Autorun.worm.m,W32/Autorun.worm.n,W32/Autorun.worm.o,W32/Autorun.worm.p,W32/Autorun.worm.q,W32/Autorun.worm.r,W32/Autorun.worm.remmants,W32/Autorun.worm.s,W32/Autorun.worm.t,W32/Autorun.worm.u,W32/Autorun.worm.v,W32/Autorun.worm.v!bat,W32/Autorun.worm.w,W32/Autorun.worm.x,W32/Autorun.worm.y,W32/Autorun.worm.z,W32/Autorun.worm.zc,W32/Autorun.worm.zf,W32/Autorun.worm.zg,W32/Autorun.worm.zh,W32/Autorun.worm.zi,W32/Autorun.worm.zj,W32/Autorun.worm.zk,W32/Autorun.worm.zm,W32/Bagle,W32/Bagle!eml.gen,W32/Bagle!pwdzip,W32/Bagle.ad!src,W32/Bagle.dldr,W32/Bagle.dll.dr,W32/Bagle.eml,W32/Bagle.fb!pwdzip,W32/Bagle.fc!pwdzip,W32/Bagle.fd!pwdzip,W32/Bagle.fe!pwdzip,W32/Bagle.fm.dldr,W32/Bagle.gen,W32/Bagle@MM!cpl,W32/Blaster.worm,W32/Blaster.worm.k,W32/Bropia.worm,W32/Bugbear,W32/Bugbear.a.dam,W32/Bugbear.b!data,W32/Bugbear.b.dam,W32/Bugbear.gen@MM,W32/Bugbear.h@MM,W32/Bugbear@MM,W32/Conficker,W32/Conficker.sys,W32/Conficker.worm,W32/Conficker.worm!inf,W32/Conficker.worm!job,W32/Conficker.worm.gen.a,W32/Conficker.worm.gen.b,W32/Deborm.worm.ah,W32/Deborm.worm.gen,W32/Doomjuice.worm,W32/Dumaru,W32/Dumaru.ad@MM,W32/Dumaru.al.dll,W32/Dumaru.dll,W32/Dumaru.eml,W32/Dumaru.gen,W32/Dumaru.gen@MM,W32/Dumaru.w.gen,W32/Elkern.cav,W32/Elkern.cav.c,W32/Elkern.cav.c.dam,W32/Fizzer,W32/Fizzer.dll,W32/Fujacks!htm,W32/FunLove,W32/FunLove.apd,W32/Gaobot.worm,W32/Harwig.worm,W32/IRCbot,W32/IRCbot.worm,W32/IRCbot.worm.dll,W32/Klez,W32/Klez.dam,W32/Klez.eml,W32/Klez.gen.b@MM,W32/Klez.rar,W32/Koobface.worm,W32/Korgo.worm,W32/Lirva,W32/Lirva.c.htm,W32/Lirva.eml,W32/Lirva.gen@MM,W32/Lirva.htm,W32/Lirva.txt,W32/Lovgate,W32/Mimail,W32/Mimail.c@MM,W32/Mimail.i!data,W32/Mimail.q@MM,W32/MoFei.worm,W32/MoFei.worm.dr,W32/Mumu.b.worm,W32/Mydoom,W32/Mydoom!bat,W32/Mydoom!ftp,W32/Mydoom.b!hosts,W32/Mydoom.dam,W32/Mydoom.t.dll,W32/Mytob,W32/Mytob.gen@MM,W32/Mytob.worm,W32/MyWife,W32/MyWife.dll,W32/MyWife@MM,W32/Nachi!tftpd,W32/Nachi.worm,W32/Netsky,W32/Netsky.af@MM,W32/Nimda,W32/Nimda.dam,W32/Nimda.eml,W32/Nimda.gen@MM,W32/Nimda.htm,W32/Nuwar,W32/Nuwar.dam,W32/Nuwar.sys,W32/Nuwar@MM,W32/Nuwar@MM!rar,W32/Pate,W32/Pate!dam,W32/Pate.dam,W32/Pate.dr,W32/Polip,W32/Polip!mem,W32/Polybot,W32/Polybot.bat,W32/Sasser.worm,W32/Sasser.worm!ftp,W32/Sdbot,W32/Sdbot!irc,W32/Sdbot.bat,W32/Sdbot.cli,W32/Sdbot.dll,W32/Sdbot.dr,W32/Sdbot.worm,W32/Sdbot.worm!ftp,W32/Sdbot.worm.bat.b,W32/Sdbot.worm.dr,W32/Sdbot.worm.gen,W32/Sdbot.worm.gen.a,W32/Sdbot.worm.gen.b,W32/Sdbot.worm.gen.c,W32/Sdbot.worm.gen.d,W32/Sdbot.worm.gen.e,W32/Sdbot.worm.gen.q,W32/Sober,W32/Sober!data,W32/Sober.dam,W32/Sober.eml,W32/Sober.f.dam,W32/Sober.g.dam,W32/Sober.q!spam,W32/Sober.r.dr,W32/Sober.r@MM,W32/Sobig,W32/Sobig.dam,W32/Sobig.eml,W32/Sobig.f.dam,W32/Sobig.gen@MM,W32/Spybot.worm,W32/SQLSlammer.worm,W32/Swen,W32/Swen@MM,W32/Virut,W32/Virut!mem,W32/Yaha.eml,W32/Yaha.gen@MM,W32/Yaha.y@MM,W32/Yaha@MM,W32/Zafi,W32/Zafi.b.dam,W32/Zindos.worm,W32/Zotob.worm,W32/Zotob.worm!hosts
Download v10.0.0.482 [2,641,920 bytes] (01/10/2009).
Hope this will be helpfull
Thanks & Regards
Nanda Kishore :)
Mar 25, 2009 | Microsoft Windows XP Professional
Unable to delete the autorun.inf
hi azhar here form Karachi it is very easy. do, the below steps
reboot ur PC in safe mode with command prompt
when u bring a dos screen just move to ur drive mostly virus stayed in d: drive got d: drive and type
d:dir/ah and press enter
if u see there any auto run.inf file there also should be another file like .exe file or .bat or any kind of unknown , file so for delete the auto run file type attrib -s -h -r autorun.inf and press enter
then type del autorun.inf and hit enter here u go u have done.
do the samr process in all drives because mostly autorun.inf file make copy in all drives
remember autorun inf is just a file which help the virus to run autometicly
Feb 12, 2009 | Microsoft Windows XP Professional With...
Can not find script file "C:\ntidr.vbs"
by alvin:
just go to command prompt, click run then type cmd..
after that type dir f:\/a/w if letter f is where your drive located..then you can see the contents of your drive ..you will see an autorun.inf...
you should delete that...in the same cmd window
type attrib -r -a -s -h f:\autorun.inf
then type del f:\autorun.inf....eject your flashdrive...goobye ntidr.vbs..
Sep 21, 2008 | Microsoft Windows XP Home Edition
Taskmanager
use virus online scanner. you have viruses
May 05, 2008 | Microsoft Windows XP Professional
Taskmanager
If you have access to a clean computer with a burner, then download Hirens Boot Disc.
The download is only around 80-90 meg and can be burnt onto a cd or dvd.
Download HERE.
Burn that program to cd and put it into the infected PC. Start the computer up and boot from the CD instead of the hard drive.
There are anti virus utilities on there that run in Dos mode without ever loading anything from your hard drive.
Taskmanger problem
HI,
Did you install sp3 just now.Or were you using it before this problem occured.Let me tell you one thing the sp3 is not yet ready fully most of the people are facing huge problems with it.I suggest you to switch back to sp2.Or you can try reinstalling ur sp3 once again.
Goodluck..
Microsoft Windows XP Professional Logo
150 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
