Question about Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13 In
Need a new trigger for te14 - Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13 In
  • 2,176 Answers
The switch part number is 71798 and you can call them at 1-800-879-8000 to purchase this.
Posted on Oct 01, 2009
Finding parts to complete it
Sorry but this site sells no parts nor has any way to look them up.
Jan 19, 2017 | ACE Computers & Internet
Variable speed trigger not working gos from 0 to full on wxi70,1
that trigger can be swapped out
you need to chase up a
speed drill parts list for the model
see if that variable speed trigger can be supplied new
or discontinued or superseded
ebay ?
or you need to sourced a used unit in better condition !
or a new one
Oct 28, 2016 | Speed Drills
I have a Bostich coil roofing nailer #RN46-1 leaking air at trigger area when depressed. Replaced trigger assy but same results. Anything else it could be?
Sounds like your gun needs servicing. normally strip, clean and usually fit new O rings to head valve assy, piston & usually sleeve.
Mar 29, 2014 | Stanley Bostitch Rn461 Gun Coil Roofing...
Marlin 70 trigger install
very little to do if mechanically inclined
Mar 08, 2013 | Air Tools & Compressors
My new porter cable RN175B nail gun won't discharge a nail
If the trigger is set to single fire, you will need to place the gun against the work then pull trigger as you have done. Try setting the trigger to bump fire and try again. If hear a thump inside the gun, remove the head and check that the head valve in not stuck from lack of lubrication. Easy test, remove the nails, remove trigger pin, remove trigger and manually push trigger firing valve. If the gun fires then suspect faulty trigger or safety arm not lifting enought to activate the trigger valve. Good luck
Nov 21, 2012 | Air Tools & Compressors
Hilti TE14. It rotates slowly and i'm getting a burning smell from the area around the armiture?
I would bet the armature is shot for sure and possibly the field. When an armature shorts out it usually gives off excessive sparking from the brush area. When a field fails it will usually run very slow if at all.
May 17, 2012 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Porter Cable FN250c wont shoot with every trigger pull. sometimes it shoots correctly (10% of the time), other times it just pops (no nail) and other times it shoots two nails at once. Also when it...
Worn trigger and or worn firing valve. Remove the trigger and look for wear on contact surfaces (worn pin that holds trigger, worn inner lever inside trigger, worn or loose firing pin in valve ). Easy test for worn trigger. Remove the nails, remove trigger, fire the gun against wood with finger to test for proper action. If it works better without trigger, consider replacing trigger with new (I would also order the oring repair kit that includes the firing valve )
Jul 26, 2011 | Porter Cable-Cable FN250C 1-inch...
Let go of wand trigger pressure will not come back
spill valve is stuck and needs to be cleaned and greased common problem....also check all connections for blockage in line
Jul 21, 2010 | Karcher 2500 PSI Pressure Washer
Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13 In Logo
142 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
