Question about Black & Decker 6.0 Volt Cordless Shrubber
My b&d 6.0 trimmer not working. probably the battery?
  • j_herget Sep 30, 2009
    I have checked that the charger is sending currant to the batterery. I have opened the battery case It looks ok. but don't know if it is malfunctioning. I have oiled the blades to be sure they are not stuck. I'm not too into electric motors to check windings, but am open to trying.
    President:
  • 1,723 Answers
It could be the battery, or the motor brushes. How do you feel about taking it apart to some degree to check things out?
Posted on Sep 30, 2009
  • Craig Butler
    Craig Butler Sep 30, 2009
    Do you have any way to test voltage?
  • Craig Butler
    I'd like to check the voltage at the switch and the battery voltage. The switch could be the problem, give it a look. Can you remove the two little black caps on the motor to look at the brushes?
My Juki dln-5410-6 is not cutting the thread
http://www.supsew.com/KnowledgeBaseArtefacts/images/Juki%20DLN-5410N-6,%20-5410N-H-6.pdf
Aug 27, 2015 | Juki Sewing Machines
I used it yesterday and today it will not start. Battery is full charge. Button key is in place.
I would first take a meter and test that the battery actually charged. If that tests out fine ( should read at about 12.8 to 13.5 Vdc), I would then check all the wired connections to make sure they did not come loose.
Jul 19, 2015 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Ni Cd Batteries for ER203 Panasonic
I have purchased ER203 6 Years back now its not working i found battery end life, can i use this battery AA 1.2V 1300mAH for this trimmer, can i charge above battery as it is like ER203, Please suggest
Aug 12, 2013 | Panasonic ER 203 Beard Trimmer
Phillips norelco nose and ear hair trimmer
If it is battery powered then the battery is probably flat. If the batteries are rechargeable then check the charger and if alkaline then get new one/s
Jul 18, 2013 | Philips Norelco NT9105 Nose and Ear Hair...
Troubleshoot/Repair Remington MB-1000 Beard Trimmer
If you leave the batteries in the charger with the mains power turned off then the batteries are probably being drained by the charger. Get new batteries and when flat (only flat not just used or part flat) recharge fully then remove from the charger unit. Rechargeable batteries have a habit of developing a memory as if you recharge a part charged battery then it will only recharge to that flat point
May 30, 2013 | Remington MB-1000 Professional Beard and...
Black & Decker battery operated weed eater/edger not working at all.
you probably need to take the base apart ,mine had a loose wire on the motor on the end of the shaft,about ten phillips head screws ,there is one screw on the gaurd,good luck
May 31, 2012 | Black & Decker Grasshog 12 Inch 18 Volt...
Spectra lawn trimmer Model 60-2230-6 Serial W041197 .Line 0.06 need spool
I am looking for batteries for a Spectra Tools Grass Trimmer, 12V, model #60-2230-6, Serial # W041197. I can't find who makes this product anymore and need to know where to get the batteries in Canada.
May 16, 2011 | Garden
My 22inch Hedge Hog trimmer (model cht500) 14.4v blades are moving very slowly. Purchased another charger but that did not help the situation. Any thoughts -battery need replacing?
possably the cells in the batt r warn out, take the battery appart nd charge nd c if they r holding charge, if they are you can buy them from a shop on ebay which is really cheap, there probably 1.2 volts, 1400 mha which is tiny. ive got 6800 mha batts in my hedge hog
Mar 12, 2011 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Black & Decker 6.0 Volt Cordless Shrubber Logo
62 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
