Question about Arris Wireless G Broadband Router (wr850g)
The router isn't conneting to the modem - Arris Wireless G Broadband Router (wr850g)
  • 404 Answers
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Posted on Oct 02, 2009
Hi! I hit " change
Are you sure that it is not the modem that is giving you the problem? Try turning off the modem (power) and then restarting after about 20 seconds. If that does not help, reset the modem and go through the set up process again. Hopefully that will settle the problem.
Jul 16, 2011 | Belkin (F6D42304) Wireless Router
D-Link wireless router has been greta, until yesterday- the Roku boxes say my router strength is excellant, but all of a sudden, the box can no loger connect to the Internet even when I select my router-...
The router most likely is not synced properly with the modem. Your computer might still have a strong connection to the router, but isn't getting an IP address. Power everything down, including the modem and restart in this order:
1. Modem - allow a minute for it to run thru its diagnostics 2. Router 3. Computer
Once you've done this, if you're ISP isn't having outages, you should have the internet working again on your computer. If this doesn't work, call your provider.
Jun 19, 2011 | D-Link DIR-615 Wireless Router
My internet is working fine. But when im trying to connect my router and the modem it stoops working. Like when I plug my internet cable to the router and then take a cable and put it in my modem its not...
unplug the modem and wait 30 seconds. Modems remember the MAC address of the last device connected to them. If it was connected to your laptop and working fine, then it has stored the MAC address of your laptop and will only communicate with the laptop. You need to connet the router and unplug the modem to clear the memory, then plug it back in so that it stores the MAC address of your router.
Mar 14, 2011 | D-Link DIR-615 Wireless Router
How do i connet to my netgear router
There should be some good instructions which came with the rotuer.
Basiclyy
1- power down the cable modem
2 - connect the router's internet port to cable modem.
3. power up the cable modem. waith 60 sec
4. power up ther the router
5. connect your computer via cable and you should be good to go.
Dec 25, 2010 | Computers & Internet
My modem is blinking green and it doesn't work
if dsl light is flashing is trying to get connetion from isp check wires from jack to modem
check for filters on phones,fax,alarm systems(not on modem)
or call your isp
Apr 28, 2010 | 2wire (2701HG-B) Wireless Router
Can't keep on the network have a modem from comcast conneted to the netgear
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Apr 16, 2010 | NetGear RangeMax Dual Band N Router Model...
It is say in make sore wireless router not conneted when it is and can not find connet
Are you trying to install the router.
Then you need to connect the computer to the router ad the modem to the router.
Click Here for step by step by instructions
Jan 12, 2010 | Computers & Internet
I have trouble to connect to internet
I have a Zyxel DSL modem that incorporates router features, but only has a single Ethernet port. When conneted to a Belkin wireless router I have to turn off NAT (in the Belkin) to gain access to the internet.
Dec 08, 2008 | Computers & Internet
Belkin G router
Make sure that the router is connected to the Internet or WAN port of the router. Do you know how to access the router's setup page? Who is your Internet service provider?
Nov 08, 2008 | Belkin (F5D5231-4) Router
Speedstream 4100 does not work with router
you can't.
when the item name as modem/router. it means the main function is modem with added router function.
you can't connect 2 router/modem together. both need access to the internet and IPS for it function correctly.
however, you can connect 1 modem and one router.
Oct 19, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Arris Wireless G Broadband Router (wr850g) Logo
94 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
