Question about Maytag MZD2766GES Side by Side Refrigerator
Firdge won't get cold
For the longest time the freezer door botton leaking water, now fridge won't cool properly? Possibly looking for a new fridge any help?
  • 1 more comment
  • Loubo Dec 22, 2007
    Your soloutions and insite seemed to work, what I found in the freezer section was iced caked in back solid with ice, we emptied fridge & freezer, for 8 hrs, defrosted completely. Turned back on, now freezer is freezing, and fridge seems to be cold, turn up another level, wife mentioned that fridge should be a little colder ...still waiting been 14 hrs and waiting. Leak stopped on freezer botton....been leaking for months on my floor. I guess the issue is now the fridge section to get colder? Thank you for your help.... will check back will you with the final results. Again Thank you. ...Loubo
  • Loubo Dec 29, 2007
    Well, this solution worked for about 4 days, currently the fridge won't cool at all now, neither the fridge or freezer. Had to rent a fridge for a short time. Any solutions would be helpful?
  • keller22 Jan 09, 2008
    the freezer workes but refrigerator is warm
Had the same problem had the maytag guy out today turned out to be a part called the adaptive defrost part went bad shopped around part #61005988 cost about $50.00.
Posted on Jun 04, 2008
  • 833 Answers
Lou, the reason for the leak was probably a bad door gasket allowing condensation out. Now, the leak is so bad that the freezer coils are full of ice. Clean or replace the gasket. Test the seal by running a 2 inch wide piece of typing paper through the gasket area in a couple of places. Resistance must be felt.
Either remove the back panel in the freezer to defrost the ice or wait a full two days for defrosting to take place. While you're at it, clean the condenser coils. Want to see if you have enough refrigerant? Shut unit for at least 15 minutes. Locate the largest tube coming out of the compressor. It must be clean. Start the unit. If will frost and either dry off or become icy after at least 5 minutes. If it stays frosted, you probably need gas.
Posted on Dec 19, 2007
  • Robert Hirst Dec 22, 2007
    Loubo...glad I could help.
  • Robert Hirst Jan 03, 2008
    Loubo, this box might need gas. If it is more than 5 years old, this might be true...up until then you have a warranty. Did you do the look-see that I originally recommended with the compressor? Is the compressor running? As far as the unit chilling...it takes about 24 hours for a fridge to cool to working temperature if it is left closed.
    If the compressor is not running...you may need a defrost timer. It might be possible to see if yours is working. Go to the inside of the fridge section and see if you can find a short stub of a shaft in the back wall. Try to turn it ... probably clockwise about 1/2 way around. Does the compressor come on now? If so, use a marker to mark the shaft. Let the unit run for half an hour. Did it move? If not, the defrost timer is bad. Replacement may fix your problem.
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
Frigh won't get cold enough
check the slot between the freezer and fridge with this model the freezer cools the fridge there a door in the slot make sure it is opening properly
May 26, 2012 | Frigidaire FRT18P5A Top Freezer...
I own a lg ice beam door cooling fridge for the past five years since recently the fridge is not cooling properly when i open the firdge i see the fan inside the frdige is at standstill pls advice also the...
sounds like u have a deforst problem. if it dont automatical defrost then u have to manually do it then u will have to replace the defrost timer and hope your defrost heaters are still good. ok
Feb 12, 2011 | Refrigerators
LG Fridge Icebeam Door Cooling Refrigerator Freezer is leaking water into very bottom of fridge. Fridge is only 6 years old. What could be the cause of this problem ? Many thanks for feedback.
lg ice beam refrigerator which has door cooling also is not cooling properly. the freezer is working there was ice accumulated in the rear corner of the freezer i defrosted but still the fridge is not cooling and there is a pool of water at the bottom most of the time. sometimes i see the fan inside the fridge is not working
Jan 11, 2011 | LG LRTN22310 Top Freezer Refrigerator
My firdge is not getting cold, freezer is ok
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101.
Oct 07, 2010 | Amana ABB2227DE Bottom Freezer...
Water leaks inside fridge from top freezer
check your gasket on the refridge door see if it has any rips or you have a blocked drain in freezer
May 02, 2009 | Refrigerators
Freezer is working but the firdge part is not cooling.
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Samsung Refrigerators
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Mar 14, 2009 | Bosch Refrigerators
Fridge not cold enough
-Did you increase the temperature control knob to the higher number ?
-If not then do so. Increase to higher see what it'll do.
-If you already did to any number but still not cold then a New One
Good luck
Mai
Dec 19, 2017 | Samsung Refrigerators
Maytag MZD2766GES Side by Side Refrigerator Logo
111 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
