Question about Maytag MDB7100AWB Dishwasher
NO WATER IT DOES NOT SPRAY WATER ON TOP OR BOTTOM AND THERE IS NO WATER IN THE TUB
  • 129 Answers
Its more than likely the solenoid is bad, so it doesnt get signal to open, and let water in.
Posted on Oct 01, 2009
I have a Frigidaire dishwasher, PLD4460. Only 4 years old. The dishes on the top rack are not coming clean anymore. Something as simple as left small bits of broccoli do not even get rinsed out of the...
Hi
If the top rack of the dishwasher doesn't get clean, check your appliance to see if you can fix the problem.
First check the spray Arms to make sure the holes in the spray arms are free and clear of debris. Your dishwasher should have several spray arms, including one at the bottom of the tub, one under the top rack, and possibly a third spray arm on the top of the tub. Sometimes food and mineral deposits can block holes in the spray arms, preventing water from spraying effectively. If this occurs, warm some white vinegar and pour it into a spray bottle. Spray the holes with the vinegar and dislodge debris with a toothpick or large safety pin.
Then check to see if your dishwasher has clogged filters. Filters generally cover the drain valve area to catch debris as the water drains from the dishwasher. Many dishwashers have maintenance-free filters, but your dishwasher may have filters that need cleaning. Read your owner's manual before you perform any filter maintenance to avoid damaging your dishwasher.
Check your water temperature to make sure it's hot enough. Water that is under 120 degrees Fahrenheit may not be hot enough to clean dishes effectively. Turn your kitchen hot water tap on and wait until the water warms up completely. Fill a cup and measure the water temperature with a kitchen thermometer. If the water is less than 120 degrees Fahrenheit, turn your water heater up to 120 degrees.
Load the top rack properly. Place cups and bowls upside down in the rack and don't nest dishes because this can prevent water from reaching dishes. Don't overload the top rack. Instead, position each item so the dirty areas of the dishes will receive full contact with water spraying up from the main spray arm located beneath the top rack. Prevent items from hanging below the top rack, which could prevent the spray arm from rotating.
Also check this link for more helpful info:-
http://www.ehow.com/info_7977311_top-dishwasher-not-getting-clean.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 15, 2011 | Dishwashers
Bottom spray arm is not spinning or spraying
How much water is entering into your tub when you press start? the water should come just up to the float valve that is located inside your d/w. if the water is not to that level, then you're not getting enough water. you can manually add water until the water allows the float to rise, then resume operation of your d/w. you can put 4 cups in the top basket (right side up) and see if the cups are full with water after about 2 mins of operation. if the cups are full then you are ok. also, remove the bottom rack to see if any debris is preventing your spray arm to move. sometimes debris is hidden and not seen.
thanks.
Dec 12, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
Not cleaning leaving residue - top sprayer doesn't spin
check spray arm for food residue build-up,if its clean then it may be the water feed conduit from the bottom tub up to the arm on top that leaking by and losing water pressure
Oct 14, 2010 | Maytag 24 in. MDB4000 Built-in Dishwasher
Leaking from bottom middle and right side of door
The center spray arm may not be turning straight and level, causing water to spray over the top of the splash shield. The shield needs to be adjusted to block water as it is sprayed from the center arm.
1. Remove the bottom door seal and reinstall, making sure there is not less than 3/8 inch of seal showing below bottom of internal door panel before closing the door.
2. Check tub seal, at the bottom the tub, seal makes a right angle and points to front of tub. In tub bottom there is a block molded in the tub, the tub seal is to fill this block but not extend over.
3. Select the shortest wash cycle or just use a rinse and hold cycle if available. Run the cycle, making sure the water spray changes from bottom to center not less than twice before making any adjustments.
4. If splash over is found, work only one side at a time. Remove black door seal enough to raise the splash shield up off the bottom of the tub not more than 1/8 inch and reinstall door seal properly. Retry and check for leaks.
5. If leak persists, remove door seal again. This time raise shield an additional 1/16 of an inch, then reinstall tub seal. After the first adjustment of 1/8 inch, any other adjustments will be no more than 1/16 inch at a time.
6. After splash over is stopped on one side go to the opposite side if needed.
May 11, 2010 | Frigidaire PLD2855RFC Dishwasher
F1 bottom drawer locked
F1 means the flood switch has been activated. here is a trouble shooting flow chart.
1. did a flood occure? yes. q-2 or no q-12
2. is the lid sealing on the tub correctly? yes Q-3 no=Answer
3. Is there a high water level in the tub. Yes-q4 no q-6
4. is the water valve leaking? yes=Answer no-Q 5
5. Is the dish drawer priming correctly? yes q-11 no q-6
6. Is the spray arm split. yes=answer, no q-7
7. is the spray arm running freely. yes q-8 no q=answer
8. is the water leaking from a split inlet or drain hose? yes = answer, no q9
9. is the water leaking around the heater plate or o rings. yes=answer, no q10
10. carroy out more testing to locate the source of the leak.
11. drain hose may have been blocked or partially blocked.
12. is there water or condensation around the chassis flood switch pcb.
13. if power fails to the bottom tub, it will cause the top tub to f1
Jan 07, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Whirlpool Calypso Washer: No water fill intermittent
Check the hose from the tub to the pressure switch, make sure its clear and the reservoir on the tub is clean.
Oct 21, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Small plastic top and mid spray arm do not turn, bottom does
decrete, you want to get down to the chopper and screen. If the screen is plugged up with gunk there won't be enough pressure to reach the top spray arms. Check out the posted pics. Remove the lower spray arm. Rotate the rear feed arm to the right until it unsnaps from the tube going up the back. See the 4 torq screws holding the filter on. Remove them. Lift the filter up. Now you will see the chopper inlet cover. 1 torq screw holding it in. Lift it up and there's the chopper and screen. Catriver..post back
Apr 09, 2007 | Whirlpool GU2400XTPS Built-in Dishwasher
Wash cycle
Check first that the filter located inside the machine (on bottom) is clean. In case it clean - The problem is with the pump. It could be a blockage between pump and the tub, or just a defective pump (The pump takes suction from the tub and forces water up through the spray arms, which spray the dishes. The water then simply drops back into the tub for recirculation). Good luck !!
Jul 01, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher leaves residue in top rack only
Most cleaning problems are caused by the dishwasher not getting enough water. It could be cause of the switch level, which control water level in the tub. The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine, but if you will open the rear panel you will find it easily. Be aware you should discoonect the power cable !!! Clear the tube (attached between the switch and the bottom of the washer's outer tub) from any obstruction.In case it will not solve the problem, you should replace the switch. Good luck !
Jun 01, 2006 | Smeg 18 in. DWF410SS Slim-Line...
Maytag MDB7100AWB Dishwasher Logo
78 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
