Question about Kitchen Ranges
I have stuck on foil on bottom of oven. Over the years I have put foil on bottom but this one obviously I can't. How can I get it off or can I? Thanks,
  • janekay Sep 30, 2009
    Sounds good, I have tried everything but the oven cleaner, will pick up a putty knife and try it tomorrow.
    Thanks
    Jane
    President:
  • 1,723 Answers
Spray it good with oven cleaner and let it soak for 1 hour. Use a 'putty knife' with a 2" blade and scrape it off.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 30, 2009
Removing Aluminum foil stuck to oven bottom
Make strong solution of washing soda and slosh a lot of it in the bottom of the oven. Cover it with clingfilm. Leave it overnight and it will have dissolved and loosened the foil and you can wash it off. Use gloves as it is a strong degreaser.
Jan 04, 2016 | Ovens
Tin foil stuck to bottom of oven how to remove it
See this link: http://askruth.blogspot.com/2006/07/cleaning-baked-on-foil-in-oven-help.html
"I called Sears and this is what they said to do:
BE CAREFUL, remove as much of the foil as possible Turn oven on to 200 lay an old wet bath towel on top. Use a plastic spatular to remove the foil.
They said it will take some time to remove the foil, in some cases days, and that you can still use the oven but DO NOT use the self cleaning untill all the foil is removed."
If you can remove the bottom drip tray/pan from your oven which the tinfoil is stuck to, than remove it. Ovens with "hidden element" usually have the removable bottom tray/pan. Don't scrape yet!!
Lay the tinfoil laden tray on a flat service where it wont be disturbed for a couple of days.
Now remove any tinfoil you can with a plastic scraper/spatula/pancake flipper.
Once thats done, pour bleach directly onto the drip tray/pan until it covers all the stuck tinfoil.(assuming your oven pan is like mine and has a lip all the way around and is somewhat countersunk).
Leave the bleach in for about 2 days. Now get your plastic scraper again and scrape away. The stuck tinfoil should all be dissolved by the bleach and the scraper should get rid of any residue. Then rinse!
Now this method will probably leave some darkened stains on the oven tray, but not near as ugly or noticeable as that melted tinfoil!!
Good luck!!
May 14, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
How do i get an aluminum foil pan stuck from the
You may be able to get it opff with the oven hot. Whatever is holding it was liquid when hot before, so should at least loosen enough for you to remove it.
Nov 04, 2009 | Kenmore 47783 Electric Single Oven
Aluminum foil stuck to new oven bottom - how to remove
(Wear a professional n95 mask and rubber gloves). Use a straight razor and scrape off as much foil as possible. Get a hold of Mercuric or sulfuric acid. BE CAREFUL not to spill anywhere, work close to a stainless steal sink. Poor a little in a small glass container and bring over stove porcelain surface. Pour the acid onto the foil and wait 3-4 minutes, use paper towel to wipe off the acid, and then a soapy wet rag. Repeat process until all foil is dissolved. Then wash surface thoroughly and repeatedly with a soapy dish towel. Once complete run water in the sink for 5 minutes till any possible remaining accid is flushed from the sink. The foil is gone and the porcelain is preserved. Works great! (Don't breathe the fumes and ventelate the area or move the stove outside)
Jan 20, 2009 | Kenmore 47783 Electric Single Oven
Yes, we were a couple of dummys when we received our brand new LG stove, with convection oven,glass top and very fancy, and we put tin foil to cover the bottom of the stove and of course yesterday when I...
I really don't know what to tell you. During the clean cycyle the metal probably melted and is permantly sealed to the bottom. You are lucky the oven still works. Sometimes using foil will destroy sensors or other things. NEVER use foil in ANY oven!!!!! The only exception is to partially cover the shelf underneath something you know is going to make a mess. Even then don't cover more than about 60% of the rack.(Never do this in a convection oven as the fan will blow the foil ) Also NEVER!!! allow foil to come in contact with a hot burner. It will melt to the smooth top or coil.
Jul 07, 2008 | LG Kitchen Ranges
Melted Tin Foil in bottom of oven
Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. The melted foil will not affect oven operation. You should never place anything on the bottom of a stove that has a hidden element. You will damage the panel. The only option you have is to replace the panel (if replaceable) or the entire oven liner...
Jun 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. You should never place anything on the bottom of a stove that has a hidden element. You WILL damage the panel. The only option you have is to replace the panel or the entire oven liner...
May 20, 2008 | Ovens
Alum stuck in oven
what i suggest to another customer is to get some of that new easy off that's made for self cleaning ovens and soak it in that for awhile the customer never respond back so i didn't know if it worked now as far as getting i cant say only as the foil is not a warranty issue you really don't need it in a self cleaning oven
Jan 17, 2008 | LG LRE30755 Electric Kitchen Range
if not a lot of foil get that easy off thats made for self cleaning ovens soak it let it sit then wipe make sure you get the one that says safe for silf cleaning dont scrape soak then after wipping off run self clean
Dec 27, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Bosch range model #hes236
there is no easy answer to this except elbow grease. however, i often put aluminium foil on base of oven with no problem. did you leave it there during self-clean when temp is very high?
Mar 29, 2007 | Bosch HES436U Electric Kitchen Range
Kitchen Ranges Logo
14 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
