Question about Home Security
I have a dsc 3060 radio on power up the red light flashhes 7 times (loss of dc power) I have a full battery charge and 12v external transforemer Should I go to 16.v transformer
  • 78 Answers
Dsc 3060 radio needs 13.50-14Volts DC
Posted on Oct 11, 2009
Why would my 120 converter not keep my batteries charged while plugged in?
If you are referring to a 12V DC - to -120V AC converter, then the answer is obvious. The converter makes the AC from the DC voltage provided by the batteries. You cannot charge a DC battery with an AC source. Additionally, even if you could, the resulting charge would be less than the draw taken from the battery (physics - loss from heat). Also, there wouldn't be enough power left over to do anything with.
Nov 23, 2014 | Cars & Trucks
Dcs 5501 trouble light
When checking troubles on DSC, *2 brings up the trouble codes and trouble light will flash after pressing *2
1=Service Required (press 1 to get sub codes)
1=Low Battery
2=Bell Circuit
3=System Trouble
4=System Tamper
5=Module Supervision
6=RF Jam Detected
7=PC5204 Low Battery
8=PC5204 AC Failure
2=Loss of AC Power
3=Telephone Line Fault
4=Failure to communicate
5=Sensor (or Zone) Fault --- Press 5 to identify zone/sensor
6=Sensor (or Zone) Tamper --- Press 6 to identify zone/sensor
7=Sensor (or Zone) Low Battery --- Press 7 to identify zone/sensor
8=Loss of Time & Date
Apr 04, 2014 | DSC Home Security
Truck will not start, seems completely dead electronically. There is a red dot on in the upper right quadrant of the dash board.
battery read 12.6v? if not its dead or discharged.
jump start it. or charge it.
if the battery reads correct.
check fusess.
if the dash check engine lamp is not glowing key on,that
is a sure sign the ECU/PCM has no 12v power, at all.
if the head lights are dead, always fix that first.
as head lights are HOT 24/7, all the time.
and prove , total loss of power.
Sep 30, 2013 | 2007 Chrysler Aspen 4x2
How long do i have to charge the stanley j309 300 amp battery booster
Before the first use, the unit must be charged for 24 hours with a connection to an AC outlet (120V). Make sure that all of the switches are off. After that, stop charging when two red and one green LED Battery Status Indicators light.
If you are recharging the unit from a 12V battery, do not charge for more than 6 hours. (Check for a full charge by disconnecting the DC charging adapter and then press the Battery Power Level button.)
The manual for the Stanley J309 battery jump starter is available on the product page here: http://www.baccusglobal.com/stanley/j309.php . The direct link to the manual is http://www.baccusglobal.com/stanley/manuals/JUMPERS/J309%20MANUAL.pdf .
I hope this helps.
Dec 29, 2011 | Garden
We have bought a battery charger HB 1206S DC6V - 12V 6AMP, but it does not state what is the state of charge do the lightes go out when it has reached changed state or light up please help
Product Detail Model No.: HB-1206S
The item is used for charging 6V-12V lead-acid batteries
Max Charging Current: 6A
AC Power Input: 64W
Output: 6/12V DC 3. 52A
Batteries Capacities: 15AHR-80AHR
Unit Packing: Colorful box
Dimension: 18cm x 10cm x 20cm
G. W. / N. W.: 1. 85KG/1. 75KG
Certifications: GS, CE, BS, ROHS, SAA
Main functions:
(1) The HB-1206S battery charger has the features of convenient operations, reliable safety and high performance.
(2) During charging, if turn up overload, the battery charger will keep itself at normal current and normal voltage with its self-automatic protecting function.
(3) If being short circuit, the battery charger will switch off itself, and turn normal after one or two minutes.
(4) The output current of the battery charger is very stationary, so it can protect the battery charger very well. It only costs 3 or 4 hours to fully charge the batteries.
(5) Indication of charging: the battery charger has 6 pilot lamps. The more pilot lamps shining, the less electric quantity is. The charging process finishes when all the pilot lamps go out.
(6) The battery charger can be switched between 6V and 12V, so it can charge for 6V and 12V accumulators. You can select 6V or 12V according to your own needs.
(7)The operations are very convenient: Put the red clip to the positive pole of the accumulator which indicated "+", and put the black clip to the negative pole of the accumulator which indicated "-", then plug in power source, the accumulator will be charged.
Aug 02, 2011 | GPS
Have a 5 year old DSC Power Series 632 Model PC 1555MX. Trouble Light came on with message #1 Any options available to me other than " Call for Service " ? Would replacing back-up Battery possibly cure...
1=Low Battery
2=Bell Circuit
3=System Trouble
4=System Tamper
6=RF Jam Detected
8=PC5204 AC Failure
2=Loss of AC Power
Aug 09, 2010 | DSC Power Supervision Relay For Smoke And...
Will no charge
Same with my SVP DC-12V Bought a new battery, same problem, bought a new charger, same problem.
I guess now I'm regretfully going to agree with the majority of
SVP camera owners and say that they are pieces of **** !
Jun 11, 2010 | SVP DC-12V Digital Camera
Cobra HH 40 charger specs
I have a Cobra HH-40 CB radio and am charging it as I type. The included charger is rated at 16V DC, 100mA. The pattery pack charges 10 AA rechargable batteries (the manual specifies NiCd, but you can also safely use NiHM). The 12V DC car charger included cannot be used to charge the battery pack, but can power the radio.
Mar 25, 2009 | Cobra Radio Communications
Astar portable DVD player
No problem? I can help you find the Astar parts or when to fix.
Any problem of the Astar brand, any models?
Just call 323-767-6030 and I will go through with you.
May 20, 2008 | Astar PD-3010 Portable DVD Player
Home Security Logo
187 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
