Question about Quorum Ceiling Fan - 138880
I have a Quorum ceiling fan model E81964 that is on a three way wall switch. At each setting it runs the same slow speed. I have checked the wall switch and think that is the fan capacitor. I have taken the bottom part off and it all looks hard wired to me. How can I fix this problem?
bigg t
  • 640 Answers
SOURCE: Hampton Bay Ceiling Fan At Slow Speed
is the fan single phase or three phase?in other words does the fan connect to 2 or 3 wires?if it connects to 3 wires just change 1 wire to another.
Posted on Aug 12, 2007
Pranavendra
  • 16 Answers
SOURCE: 42" ceiling fan
1. Try to rotate it by free hand and see it is free machanically. If not, it ball-bearing/bush should require lubrication or replacement.(Note at this satage there should be no electric supply to fan.)
2.If it is free, rotate it fast by hand, then immediately switch it on.
a)If it continue to rotate, then there is fault in capacitor.Replace it.
b)If not, ask me.
Posted on Nov 29, 2007
  • 103 Answers
SOURCE: Quorum ceiling fan
Try this site:
http://lightingbygregory.com/lighting/product/qr-7-1100-04.html?lbgc=biz_184052
Hope this helps, and please rate my answer, good or bad.
Posted on Feb 04, 2008
SOURCE: Remote control ceiling fan
I am changing the remote in hunter fan an i got the wires mixed up coming from the fan what wire goes where?
Posted on Apr 12, 2008
  • 4 Answers
SOURCE: harbor breeze ceiling fan
Your voltage is probably too low, probably a bad wire or source. Let me know if it worked.
Or take a look at the link given here... http://www.ceiling-fan-wizard.com/harbor-breeze-ceiling-fans.html
Posted on Nov 21, 2008
On a E81964 I replaced the fan switch. Why does the fan only run real slow?
motor dragging or switch installed incorrectly wired to the slow speed. .
Jun 05, 2015 | Hampton Bay Dryers
My 3-speed ceiling fan is connected to an on/off wall switch that turns it on and off but the pull chain does not control the speeds. It is stuck on slow speed. I tried replacing the pull chain switch in...
Guess what? A standard dimmer switch will not properly operate a fan motor. In fact, it’s most likely going to damage the fan motor and it could even potentially cause a fire. I’ll admit I even went out and bought a dimmer switch and I sat down to just “make sure” I was doing the right thing when I figured this out.
Standard dimmer switches are designed for the wattage of lights. Fan controls are designed for the amperage of the fan motor. So if you want to control the speed of a ceiling fan make sure you buy a fan speed control that specifically says it works for fans. Fan controls come in quite a few styles. The most common type has been around for quite some time and that is the rotary or dial type. The next most common fan control I found was the toggle that has three pre-set speeds (slow, medium and fast). You can also get a fan control that has a slider control along with a toggle switch.
dimmer+switch.jpgThe type that I want to install is a toggle switch with a small slider switch next to it. I have a feeling I’ll have to order one of these but I’ll check with my electrician tomorrow to find out the scoop. The bottom line is you can’t use a standard dimmer switch to control a ceiling fan. You have to get a fan speed control switch that is specifically designed to operate fan motors.
the short wire leads coming from the switch should be attached to other wires with small wire nuts. Just unscrew the wire nuts, unscrew the finial type cap that holds the switch in place, remove the switch and take it to the store. If your lights are strictly "ON"-"OFF" there should be just two wires from the switch. If your lights are controlled - "One" "TWO" or "THREE" at a time the switch will probably have three wires coming from it.
http://www.ceiling-fans-n-more.com/
Thanks for contacting Fixya.
Jun 14, 2009 | Heritage (5BUW52WZ4HN) 52'' Ceiling Fan
What is the pull switch diagram for 135525
first of all if you bought a switch at a store, just because it looks the same on the outside doesn't mean it's the same on the inside. I can tell you that the black wire usually goes into the L. If you can't find the correct switch contact me at. Fanman9952@aol.com
Sep 05, 2014 | Quorum Monaco 13552595 Ceiling Fan
Is there a Guide for Quorum Ceiling Fan?
Your best option maybe to contact Quorum International directly and provide the details of the problem including model number of your fans.
Quorum International manufacturer of designer coordinated lighting...
Aug 01, 2014 | Quorum Dryers
52" ceiling fan has one speed only:slow;very slow.
Most likely it's the capisitor. Hopefully you kept the original pull chain switch because that need to be put back. Just because the switch looks the same on the outside doesn't mean it's the same on the inside.
Jun 17, 2013 | Dryers
Where can i find parts for Quorum ceiling fans online?
u can type the fan make and model in your computer and get them just about any where.
Oct 03, 2010 | Quorum Ceiling Fan - 138880
On all three settings the fan runs very fast, no slow speed.
If it's a remote fan try completely cutting off the power at the breaker box for a minute or 2 and turn it back on. Mine does that occasionally and that seems to re-set whatever it is in the fan that causes it. Hope it helps.
Oct 01, 2010 | Quorum Ceiling Fan - 138880
HI speed on my Hampton Bay ceiling Fan.
If you are looking to lower your fan speed, I suggest getting an adjustable wall switch that will limit the current to the settings. I have the same situation, I myself didn't do it but I know it is possible. In my bedroom, I have my ceiling fan wired to a turn knob switch, a dimmer so to speak, that limits the elctrical current, thus slowing the rpm's of the fan blades.
Feb 25, 2008 | Dryers
I recently replaced my hampton bay fan for the same reason (slow at all speeds) and discovered scorched and melted capacitors and wiring inside the fan. My suggestion is to stop using fan and replace immediately.
Aug 10, 2007 | Hampton Bay 52 In. White Redington...
Quorum Ceiling Fan - 138880 Logo
984 people viewed this question
Top Quorum Dryers Experts
Dan Webster
Dan Webster
Are you a Quorum Dryer Expert? Answer questions, earn points and help others
