Question about EliteGroup GeForce 6100SM-M Motherboard
Lan hi.ive instored new windows xp and i carnt get my internet lan goin.ive rebooted modem,and no go.ive looked at my divce manger and can see the bridge drive is in a yellow cap.plz tell me how two fix plz,thank you mate
    Champion:
  • 209 Answers
You need to install the driver of your lan coming from your motherboard cd in order to repair this. after installation you must reboot
Posted on Dec 19, 2007
Hi, Installing Creative DI5655 Internal Card Modem on XP I try using the modem for sending/receiving faxes with WinFax PRO 8.0 When looking for the modem through the Control Panel, the modem is...
Hi Roni,
Let's try doing it the easy way first.
  1. Go to START, SETTINGS, CONTROL-PANEL, SYSTEM, DEVICE MANAGER.
  2. Go to the icon that reads network, expand it by hitting the + symbol.
  3. Locate your modem, right-click the icon and choose UNINSTALL.
  4. Hit the "F5" key. It should redetect the modem and install the drivers again by default. If it doesn't you can check the top menu inside the Device Manger for "Scan for new hardware". If you can't find it, just reboot the computer and Windows will detect the modem and reinstall the driver.
It should move the Com back to 1 or 2.
Let me know if it doesn't.
-- Rescue Tech
Dec 11, 2010 | Creative Labs Digicom DI5655 Modem
My device manger says that the realtec RTL8168C is working properly. However, when I plug and ethernet wire into it, it does not light up, nor does the modem. I have replaced the modem and cables. I have...
You need to go into the BIOS and see if the LAN port had been disabled.
To do this restart your computer and hit the Del key, that will get you into the BIOS, look for On-board Devices and check that the LAN is enabled.
Good luck.
Aug 18, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
Problem with BSNL Broadband with XP 2 Operating System
Of note, XP does not support USB internet connection; so, try out connecting with LAN cable. Hope this helps.
Dec 22, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
My Belkin 4 port router has the same IP as my Modem so my router will not detect my DSL connection. Ive asked Belkin for help but all they send me is gobblygoop!
Hi!
I'm sorry to hear that Belkin did not help you with your problem. Let me help you with your concern instead.
Here's what we need to do:
Start by resetting the router to factory default - you just need to press and hold the rest button on the router for about 30 seconds (with the power on).
1.) Disconnect the Belkin router from your modem , connect a PC to the router (use the LAN port - either port 1 to 4).
2.) Open Internet browser - clear the address bar and type in http://192.168.2.1 , press enter. It will ask you for a password , do not type anything just press Submit. You should be able to access the router's web interface.
The router's web interface should like this (depending on the model #):
3.) Go to LAN settings. Change the router's IP address to 10.10.10.1 (this will be the new IP address of your router) . Apply the changes. Once youapply the changes, you can access the router using the new IP - http://10.10.10.1.
4.) Reconnect your modem - router and computers. Reboot device by switching off the modem , router and PC.
5.) Power up the modem first. Wait for about 2 minutes, power up the router and restart your PC.
The steps I gave is applicable if your modem is not on bridge mode. If your modem is on bridge mode (meaning it requires a username and password from your ISP) - access again the router by going to http://10.10.10.1 and do the following:
Click Internet WAN > Connection Type and select PPPOE. Type the username and password from your ISP. Apply the settings. Reboot the modem and router.
I hope that helps.
Good luck and have a nice day!
Nov 25, 2008 | Belkin Computers & Internet
Static Ip with Speedstream 4200 Modem
I am assuming here with the way you have it set up your getting an internet connection.
what you saying i understsand mostly so i'll see if i can help you
first of all you have speedstreem modem that connects to you isp, this is assign your internet address from the isp if you paid for a static IP it would be in here, if not it's assiged by a dhcp from your isp company so if you if turn it off or have a power loss for anymore than 5-15min your ip changes.
now your modem then connects into your belkin router this as well as your modem it's prob set up as dhcp so it wants to issue each computer with an internal address of 192.168.0.X the reason for this is so it knows where to send the incomming information to what computer.
no matter what computer your using the address that goes over the internet will be the one assigned to modem from internet provider so if this need to be static IP to run your game server you will have contact your internet provider for an address.
but you may be confussing the issue a little, my suggestion to you would be:
1. go to your connections on each computer
2. right click on the lan connection choose properties
3. go to internet protocol (TCP/IP) then click properties
4. then click on obtain ip automatically and obtain dns automatically
this will remove the static windows address you may have put in.
try this and see if you can get you game or game server will work.
btw you may have to reboot your computers after this to get be sure to get the new address.
Oct 09, 2008 | Siemens SpeedStream 4200 (13A4200001)...
My internet keeps disconnecting
Call your isp and schedule a service call. There could be something wrong at the telephone pole or your drop to the house could be faulty, or your modem could be bad.
Sep 02, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
SamsungX05 ınternet problem
Windows XP Latest Drivers Windows XP Previous Drivers Windows 2000 Drivers
May 15, 2008 | Samsung X05 Notebook
Bridge mode
i see,, seems your router is not configured, you can try an alternate way.. if you have windows xp, goto control panel select internet options, goto to connections tab then click set up button a wizard will pop up, click next then select connect to the internet then click next, select set up my connection manually,, select connect using a broadband connection that is always on then finish...
Mar 12, 2008 | Computers & Internet
PPPoE over Edimax BR-6104K without a modem
HI,
  Actually in short  "you NEED A MODEM;"
In order to connect your router you need to connect a modem in "bridge mode'( bridge mode is nothing but a configuration on the modem)..
this is a picture of  rear side of a  router,,, you have to connect the modem into the wan port of the router (above),, and in port number 1,2,3,4 you can connect your computers,
Nov 01, 2007 | Edimax BR-6104K Router (br6104k)
EliteGroup GeForce 6100SM-M Motherboard Logo
95 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
