Question about Brother MFC-7820N Printer
I have an MFC7820 brother printer and need to order a part for it. Where can I get a parts manual to determine the part number I need?
  • providencefe Sep 30, 2009
    I need to replace the left hand door lever as it has broken away from the door.
    President:
  • 2,306 Answers
Let me know what you need and I can get the number, I'm not allowed to distribute the parts list.
Posted on Sep 30, 2009
  • Craig Gillette
    Craig Gillette Oct 01, 2009
    The lever you need is LM4249001, but the reason it's broken is you need to replace the gear, LM4225001, and joint #LM4227001.
    Those are broken when you use a generic toner that is too hard to turn and breaks the gear and locks the door from opening properly.
I have Brother MFC 7820N printer. It has a loud clicking sound on the left rear end and paper will not feed, sometimes the first page will print and no paper message will be shown? Can you please help
It sounds like a displaced drive gear in the gear chain to the fuser. If you remove the covers and the fuser unit you should be able to manually turn the gears to check for jams or slips. Make sure all ther gears are correctly seated and no missing teeth.
May 19, 2014 | Brother MFC7820 ALL IN ONE LASER PRINTER...
Brother MFC7820-N won't connect to ABBYY Finereader Pro for Mac
This is the software brother recommended for your printer...Download the software from the link given below: Download Brother
Feb 15, 2014 | Brother MFC-7820N Printer
Disassemble Brother MFC 240C
I know this issue may have been resolved by you already, since I am now looking at this issue for you, however I am setting up the answer to help others that may have a similar problem in the future. You will need to reference a Brother servicing manual as it will show you how to remove the printer assembly and includes part numbers that you may need to replace. Hope this is helpful! You can find the manual at: ftp://ftp.brother.co.il/fax/MFC845.pdf
Dec 27, 2013 | Brother MFC 240C All-In-One InkJet Printer
Replacement toner cartridge not accepted
I Suggest You To Watch just replaced the toner cartridge and the LCD continues to Brother To Fix Your Brother Printer Issue.In Case You Still Having Problem Then Follow Us For On :
Brother Printer Support
Jun 11, 2012 | Brother Toner Cartridge Tn350 for MFC7420...
Part number brother 9840cdw fuser
Part# LU4103001
About $150
The service manual will be hard if not impossible to find. They only release those to factory authorized service centers. If you just need it for the fuser replacement instructions then often those will be either in the operators manual which is easy to find or the instructions will be in the box that the fuser comes in.
Good Luck and Thank You for using Fixya.
Apr 01, 2010 | Brother MFC-9840CDW Laser Printer
A small white wheel inside the printer that feeds
Hello Sargentjonat,
I have found the service manual of the Brother HL-2070N. Here is a link to the manual:
http://www.megaupload.com/?d=TLIPIA9N
If you can find your gear in the manual then you could find the replacement part number. It's a long document so just Ctrl+F and search for gear.
After that you could try locating a brother service center and calling them. If you go to brother.com and select support there is a service center locator. I have not dealt with brother for replacements before so I don't know their process.
I hope this information can help,
Adam.
Jul 13, 2009 | Brother HL-2070N Laser Printer
Belt slipping on brother SE 350 sewing machine
Hi - if you purchased your machine recently, I recommend that you exchange it. If you can't return or exchange the machine, check the paperwork that came with the machine - a phone number for Brother customer support should be in that paperwork; it might even be in the manual. If your machine is still under warranty, they can tell you where you can have it repaired.
Belts for these machines are not available "off the shelf", and the machines are not designed for consumer repair. However, if you've already taken the covers off and determined that it really is the belt that is the problem, take the belt to a Brother or Babylock dealer and purchase a new one. If you haven't taken the covers off, you can search the web for a service manual to determine the part number you need to order and find the instructions for making the repair - the service manuals are available on Brother's site, but you really need to dig around to find them ( I did it once, but haven't been able to find them since).
Please keep in mind that if your machine is still under warranty, you will void the warranty if you attempt to repair the machine yourself.
Good luck,
Ginny
Jan 30, 2009 | Brother XL-3500
How do i connect the brother intellifax 750 to my computer
http://www.brother.ca/en/products/pdf/manuals/FAX750-UG.pdf
Look on page 141 (151) for Multi-function Link package (Missing Link) this will turn your fax into a printer and scanner for your windows pc. Part number is: PCI-1 and can be ordered directly from Brother.
Jan 22, 2009 | Office Equipment & Supplies
Brother HL-2030 broken exit actuator
It's LM6320001.
Not sure where you can order it...depends where you are I suppose :)
Jan 21, 2009 | Brother HL-2030 Laser Printer
Brother MFC-7820N Printer Logo
81 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
