Question about ASUS P5QL-E Motherboard, LGA775, Intel P43 + ICH10R, Dual DDR2, PCIe x16, SATAII, RAID, eSATA, Gigab
P5QL keeps restarting & it's not a power supply problem
  • james May 11, 2010
    Is it overheating?
  • yadayada
    yadayada May 11, 2010
    more info on this problem please.
Hi i my computer suddenly started to shutdown and turn on again after a fev seconds.some times it goes in to windows but soon after crashes.it has wrked for over a year and this was a home built...
Try these....
Overheating problem in your PROCESSOR!
Check the temp in your BiOS and the setting of your processor!
Check also the power supply and upgrade it to hifgher wattage!
Clean your processor HEAT SiNK, dust and dirt might have acumulated!
Check the HEAT sink position, if its flatly fitted on top of procie, and scrape the old silicon paste between ur proci and heat sink and put a NEW ONE!
Encountered this kind of prob.. the prob is in the PSU unit(Power Supply Unit)!
These might help you!
Nov 07, 2010 | ASUS P5QL PRO Motherboard
Hello there. I have a problem with my motherboard ASUS P5QL/EPU, when i turn on my pc, its turn of and restart, when restart, its make a 3 beeps sound and not present nothing else. Its never begin the...
the beeping sound is the post system searching for your hard drive and other connected devices
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Oct 23, 2010 | ASUS SKT-775 P5QL/EPU S/L 1333FSB...
What is the solution to a restarting system? i've
Does it just keep restarting over and over again? Sounds like it's most likely the power supply dying. You can typically get a new power supply for $30 or $40.
Aug 09, 2010 | Dell Dimension 2400 PC Desktop
No Boot , new P5QL-EM mother board
Check the heat sink ontop of your cpu sounds like bad connection and it will cause it to do as you describe
Aug 04, 2009 | ASUS P5QL-EM - Motherboard - micro ATX -...
I tried to install Windows XP sp2 and the windows boot screen did not show up.
Reinstall and during the install press F6 when it ask if would like to install 3rd party drivers and have the driver disk for your hard drive ready and install those when ask.once it is done it should complete the xp install and restart correctly.
Jun 01, 2009 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
Computer automatically restarts after shuting down
Did you install the drivers for the motherboard already? If so check the connections from the power switch to the board which all should be on the bottom right of your mobo. I switched a + and - one time and it went into a infinite look of turning on and off = / Beyond that ASUS Customer support sucks and I would just try to RMA it and start over.
Feb 20, 2009 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
Restart
try replacing your power supply unit... computer restart is sometimes caused by low voltage output from a faulty power supply.
hope this post helps.
Aug 01, 2008 | ASUS P5PE-VM Motherboard
ASUS P5QL-E Motherboard, LGA775, Intel P43 + ICH10R, Dual DDR2, PCIe x16, SATAII, RAID, eSATA, Gigab Logo
174 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
