Question about Biostar GF7050V-M7 nVIDIA GeFORCE 7050 CHIPSET MICRO ATX FORM FACTOR 1xPCI-E/1xPCI-E/2xPCI/... Motherboard
DOESN/T DISPLAY ON MONITOR - Biostar GF7050V-M7 nVIDIA GeFORCE 7050 CHIPSET MICRO ATX FORM FACTOR 1xPCI-E/1xPCI-E/2xPCI/... Motherboard
    President:
  • 1,187 Answers
Does the monitor work on the BIOS setup screen?
If not, reset the mobo: either remove the mobo battery for a few minutes, or "short-out" the two reset pins next to the battery or next to the CMOS BIOS chip.
If you are not using the built-in video interface, then put two monitors on the system and adjust the way you want the monitors to behave.... or disable the built-in vga interface through the BIOS setup.
More info, please....
Posted on Sep 30, 2009
The monitor works ok, but I have to switch it on and off to display anything on the screen. I have changed the graphics card but to no avail. The display info is getting to the monitor but doesn't
Check your cable between the computer and the monitor, It may be a non-sensing cable which will be missing one of the pins so the monitor is not getting the correct data from the computer.
Mar 06, 2012 | ASUS P5VD2-MX SE Motherboard
I am attempting to connect my HP pavilion dv9000 to a HP 2310e monitor, but it doesn't recognize the monitor via the HDMI cable
You must make sure it's configured correctly: make sure the monitor is up and running (not in Sleep) , that the HDMI cable is firmly plugged in (use a new one to be sure), then right click on the desktop, click NVidia Control Panel, under Select a Task expand Display and click Run multiple display wizard . If the monitor isn't picked up then go to Set up multiple displays options and see if the monitor appears in the second setting (Select the displays...) - if it doesn't then click the MY Monitor is not shown in the list option and follow the procedure to force its detection.
If even that fails then the video driver is corrupted, you will have to uninstall it, download the latest one and reinstall it.
Use this one
http://www.nvidia.com/object/geforce_notebook_winxp_179.48_beta.html
Aug 12, 2011 | Computers & Internet
My computer's tower turns on but it doesn't display on the monitor, the monitor shows the normal Self test box so the monitor doesn't seem to be the problem. Also when I press the power off...
Make sure that the cable is connected from your computer to the monitor, and if it is wiggle it and push it in all the way. If it has screws, screw them in. If that does not work, check that your monitor is on the correct input (if it has multiple) then see if anything comes on the monitor. If nothing happens you should buy a new cable from the store. If all of those steps do not work your computer or your monitor might have a more serious problem.
Jul 29, 2011 | Computers & Internet
I have a Acer X203H Monitor. Everything is connected I've checked a million times. When my computer turns on it displays fine on the monitor, but the first or sometimes second time the computer goes to...
I would try this monitor with another PC first to verify that it is not PC problem.
Most common failures in the monitors are due to bad caps in the power supply/inverter board, we want to find out first if it is the monitor or the PC problem.
See examples of failed ACER due to bad caps here:
http://s807.photobucket.com/albums/yy352/budm/ACER/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 24, 2011 | Acer X203H Monitor
Please help.. my monitor has no display and my don't even beep. the LED in the monitor turns back to orange after few seconds. cpu, disk drives and ram are working..
This is one of the serious problem that arises because if you set your monitor with a high resolution with high frequency, then the monitor doesn't display anything as it's frequency is out of the rang or limit of the monitor's actual resolution capacity. Each monitor will have a limit of max frequency that is said to be the Refresh rate (for each and every resolution setting the display is refreshed.) When high resolution is set with high frequency that is not supported by the monitor, it then display a message like "frequency out of range". If you press ESC key within the few seconds of this setting, it will revert back to its initial resolution. But if you continued with the setting of same High resolution with High frequency, the monitor is not going to display anything because its frequency is out of the range. Most of old monitors like CRT's etc doesn't support 1024×768 at a refresh rate greater than 60Hz.
Jun 20, 2011 | Asrock P4I45GV R5 Motherboard
No display on the monitor.
1) Ensure your computer is actually starting up.
2) There is a Fn -Special function combo that will switch the display from your LCD monitor to an external monitor. Try hitting that key combo several times to see if the display has been mistakenly sent to the external monitor.
3) Hook up an external monitor and hit the key combo to send the display to it. If this doesn't work, then you probably have a video/motherboard problem.
May 15, 2011 | Acer Aspire One PC Notebook
I have lg m198wdp monitor tv.problem is white screen
When does it happen?
During Self test? Try this by unplugging the cable that connects to your tower and see if the self test runs. if it does, then your monitor still works. If it doesn't you might need to replace your LCD
During BIOS? If it works then your monitor still works. If it doesn't you might need to replace your LCD
During Windows? then you might need to adjust your display properties or reinstall your video card drivers.
Apr 27, 2011 | LG M198WDP - Flat panel display - TFT -...
After starting, my monitor displays "power saving mode".
Go into the menu and reset the monitor to factory defaults.
Aug 28, 2009 | LG L1915S 19" LCD Monitor
Biostar GF7050V-M7 nVIDIA GeFORCE 7050 CHIPSET MICRO ATX FORM FACTOR 1xPCI-E/1xPCI-E/2xPCI/... Motherboard Logo
225 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
