Question about Kohler Cimarron Comfort Height elongated 1.6 gpf toilet with Class Six tech
I just had a Cimarron toilet installed, and it worked great for months. It now appears blocked, and will not flush,even after repeated plunging. It is not likely that there is any obstruction in the system, knowing the limited usage. What do you suggest? TKS Jim V
  • 302 Answers
Try snaking it as this will catch anything that the plunger cannot reach.
I know you said that it has had limited use,but can you be sure that something out of the ordinary did not fall in?
This is why I suggest snaking.
Posted on Oct 06, 2009
Kohler cimarron very noisy when flushed
You probably have one of the newer Cimarron-series toilets that feature what Kohler calls "AquaPiston" technology. These gadgets use the water pressure in your supply lines to pressurize a charge of flush water in the tank, causing the flush water to rush into the bowl at high pressure and velocity. Many Cimarron-series toilets use only 1.28 gpf (gallons per flush), compared to the current industry standard of 1.6 gpf for conventional gravity-flush units. Reducing the gpf rating by 20% requires pressurizing the water in the tank, and the release of pressurized water makes a lot of noise. I'm afraid your toilet will always be noisier than what you may be used to.
Sep 22, 2017 | Kohler Home
Why does my new toilet spurt water?
There's a small clog. Plunge it until it flushes and flows freely.
Oct 12, 2014 | Eljer & Patriot& Elongated Toilet Bowl
When i flush,no water is flushing, nothing happens
I would check to see if the water supply valve is turned on to start.
Is it a new install?
Jun 22, 2014 | Kohler Cimarron 2-PC Elongated Toilet with...
Kohler toilet-Cimarron is having problem with filling tank with water, fill tube is in the canister center but the level in the tank doesn't rise and toilet keeps running, there is not a flapper and no...
i don't know about your toilet but i googled it and found this it's the flapper and flush valve
https://www.plumbingsupply.com/images/kohler-flush-valve-1044458.jpg
and you can go here and see all the parts in it,hope this helps you out.
https://www.plumbingsupply.com/kohlertoiletparts-cimarron.html
Dec 20, 2017 | Kohler Cimarron 2-PC Elongated Toilet with...
We bought a Kohler Cimarron complete solutions 2 pc. toilet about 2 months ago and now it doesn't want to flush properly.The toilet fills half way up with water instead of just wooshing down like it...
Before taking it out you need to go back to Lowe's and purchase a toilet auger....
With this you can crank it down through the trap of the toilet and remove the obstruction...there is something in there that a plunger will not remove...example...a pen or pencil... comb...these are commonly removed when I het the symptoms you are giving...
heatman101
Aug 13, 2010 | Kohler Cimarron Comfort Height elongated...
Kohler Cimarron elongated comfort height toilet not flushing correctly
low water in the bowl is only caused by the float being to high! the gurgles is Usually because of air coming back up through the pipe, check your vent pipe that come out the roof. this will help the draining.
May 30, 2009 | Kohler Cimarron 2-PC Elongated Toilet with...
Kohler Cimarron Comfort Height elongated 1.6 gpf toilet with Class Six tech Logo
289 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
