Question about Dacor ECS127 Epicure Stainless Steel Electric Single Oven
Faulty oven door
We have a Built-in oven and grill unit (Moffat 95 series) from Parkinson Cowan Ltd - on which the oven door won't close properly. As obviously this oven is quite old, we are wondering if it is possible for the door to be repaired or even replaced.
Are spares still available for this type of oven?
I look forward to hearing from you.
Linda Allen
  • 3 more comments
  • Anonymous May 02, 2008
    our oven door doesn't close properly. Do you know how to repair it.
  • Anonymous Oct 16, 2008
    When I close the oven door it won't stay shut all the way and I don't see an adjustment on the door or in the oven
  • Anonymous Nov 09, 2008
    same problem. How to I fix a sprung door?
  • LIBERTYAH Nov 11, 2008
    OVEN DOOR WILL NOT CLOSE ALL THE WAY
  • lilyofachy Nov 12, 2008
    door will not close all the way.
This IS SO EASY !! I have the DACOR 48...no tools, 5 minutes and you are done! It took me 8 years of frustration and I fixed it TODAY !!
Just open the door, latch the small hook that binds the two hinges together. Next try to slowly close the door until resistance. Just when you think you might break something push up another 2 inches. Now lower the door , unhook the latch to seperate the hinges (latches) nad PRESTO a snug fit !!
Posted on Dec 08, 2008
I have a Bosch wall oven in my unit but no user manual. The number on the door is bosch hbe632uau/03. Is it ok to close the door when using grill function or will the glass blow out?
if the grill section is behind the oven door then the door should be open
if there is a door for the grill section then the oven door can stay closed
to get a user manual ,go google and type in-- user manual for bosch oven model ( type in what you have) --( or leave it out if it doesn't recognize the model)
If a page is available with a pdf version you can down load it
Oct 19, 2015 | Bosch Ovens
My oven gets too hot and won't turn back down
Sounds like a problem with the oven thermostat. You will need to meter check it and see if it is closing at all. If not replace the thermostat.
Nov 08, 2012 | Moffat Ovens
I have a Neff B1432 built in oven and grill. About a week ago the oven stopped working properly, it won't heat up. The grill works fine. Help! thanks.
It can be 1 of 3 things .. 1 burnt of termination to element ( most common ) 2 faulty selector switch ie rotary or digital switch or 3 faulty element .... Requires technician !!
Feb 28, 2011 | Ovens
Hi i cant find a parkinson cowan built in gas cooker
Used or brand new? In which country?
You won't find them new in shops as they're no longer made. But you *might* find a NOS (New, Old Stock) Alto GM60 from an online stockist, but the manufacturer's guarantee will be worthless and some spare parts will already be difficult/impossible to obtain. You'll also need to check before purchase whether it's for natural gas, lpg, butane or propane.
All late (approx. 1990 onwards) Parkinson Cowan models had appalling build quality and frequent electronic faults, so I strongly advise that you look for a current brand.
Aug 02, 2010 | Ovens
How do i remove the glass from my built in moffat oven door as the inside of the inner glass is very dusty,there are no screwws or nuts to undo it or do you know a way of grtting into it to clean it
LOOK FOR VENTS AT TOP OF DOOR SPRAY IN OVEN CLEANER AND LEAVE FOR 20 MIN THEN SPRAY WITH WATER AND TURN OVEN ON TO HOT TO DRY DOOR.
Oct 18, 2009 | Ovens
My grill won't light
Hi
Forgive me for asking this, but you have read the instructions haven't you?
If you have, and it's still not working, then the likelihood is that there is a fault, this could be one of the following:
Faulty solenoid valve to grill (some grills had a safety button fitted to stop you from closing the door if the grill was being used)
Blocked pipe inside unit
Either way you need to get a qualified gas engineer to take a look at it, if it's under warrranty call the manufacturers first!
I hope this helps
Steve :)
Jul 14, 2009 | New World G70m Gas Double Oven
My igniter doesn't work
The battery holder is located under the cooker, on the right handside. It swivels forwards and holds two AA batteries.
Dec 13, 2008 | Stoves Premier 900GRa Gas Double Oven
Dacor ECS127 Epicure Stainless Steel Electric Single Oven Logo
702 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
