Question about Canon BJC 80 InkJet Printer
Windows vista word 2007
Windows vista home not have the bjc-70 driver and when i use the bjc-80 driver an word 2007, appears cut in the middle of the last line of the page
  • bigarna Jan 09, 2008
    I have two printers, a BJC-70 and a BJC-80, the last one works with vista, but don´t work with word 2007, the problem is when you order the print, takes five minutes in begin print.- I can´t use both printers with vista; and the controller don´t work.-
  • manuelitoe Sep 29, 2009
    windows vista home not have the bjc-70
  • 52 Answers
Hi i am a certified Canonwindows vista word 2007 - 4.gif repair tech for this printer. if you follow the link below this will take you to Canons support site where you can download the software for your printer. hope this helps
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Posted on Jan 09, 2008
Trying to hookup bjc 80 to acer aspire 4730z running vista, don't have disc but am hooked up via usb.
you need the printer driver for vista in order to be able to print out. But Canon does not offer drivers for XP and Vista for bjc-80, however you can manually install the driver for BJC-85 and get the printing function going, but the scanner cartrige does not work through USB.
BR
Bruce
Oct 23, 2009 | Canon BJC 80 InkJet Printer
BJC 80 w/ Vista OS prints 1/2 page and goes to error mode.
Purchase a PCMCIA parallel port card. That's a PC Card parallel port adapter. It provides a native parallel port to laptops that do not have one built in. Works perfectly in ALL cases, even with the scanner cartridge.
Jun 09, 2009 | Canon BJC 80 InkJet Printer
Compatibility with Vista, or are drivers available.
by looking at the table in this link, supposely this printer works fine as plug n play to your vista...no driver installation is needed....
hope this will help ; )
http://support-my.canon-asia.com/index.jsp?fuseaction=support&prod_type=vista_list
May 26, 2009 | Canon BJC 80 InkJet Printer
Is this printer compatible to home edition software and how to find the drivers?
according to canon the drivers for the bjc80 will support windows 95,98, and ME not xp home.
If you need more help let me know.
Mark
May 05, 2009 | Canon BJC 80 InkJet Printer
Cable for USB conversion
YES. THERE ARE SEVERAL USB-PARALELL CABLES CABLES IN THE MARKET. JUST CHECK IN THE WEB OR YOUR HARDWARE STORE. PRICE SHOULD BE AROUND 15 TO 20 US DOLLARS, DEPENDING ON BRAND, QUALITY, ETC.
SOME OF THE (MOST) BRIG A DRIVER CD.
ONE THING YOU SHOULD HAVE IN MIND IS THAT WHEN INSTALLING YOU BJC-80 IT WONT PRINT UNLESS YOU GO TO PRINTER PROPERTIES, PORTS AND UNMARK "BIDERECTIONAL COMPATIBILITY", THE GO TO ADVANCED OPTIONS AND CHECK ON "PRINT DIRECTLY TO THE PRINTER", OR SOMETHING LIKE THAT. (SORRY ALL MY SOFT IS IN SPANISH...) RESTART THA COMPUTER AND ENJOY. I HAVE A BJC-70 AND A BJC-80, USE THEM ON XP SP2 AND VISTA. BOTH WORKING FINE. DO NOT EXPECT SPEED PERFORMANCE. GOOD LUCK
Mar 10, 2009 | Canon BJC 80 InkJet Printer
What does disabling bidirectional support mean
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} USB to Parallel conversion requires translation by XP and Vista's 'hardware interleave' software as well as the USB device manufacturers driver. The software package just doesn't work well with older peripherals that use legacy parallel or serial com ports. Too many sloppy layers.
THE BEST WAY to add an LPT printer port to your laptop is to use a PCMCIA to Parallel adapter card.
The PC Card slot provides access to the laptop's data bus, and the PC Card adapter easily sets up as a native LPT port within almost any OS.
There is no delay, or connection problems as I've seen in so many complaints about USB to Parallel or Legacy Serial adapters. Printing is Instant.
PCMCIA is a mature standard, and works seamlessly with XP and Vista, and almost any other OS.
PARALLEL is the old standard fast data protocol. IEEE 1284 ECP mode up to 1.5 Mbps.
The BJC-80 and the BJC-85 have the same print speed. The BJC-85 just added USB.
INFRARED is ver 1.0 on the BJC-80, and printing is a bit slower at 115.2 kbps. Even the BJC-85 with its higher IRDA transfer rating and a laptop's built-in IR port, the XP print spooler has problems with it, and can hang if printing more than one page, and especially with more than one document. It will not scan.
I use IR for printing single pages only with either the BJC-80 or BJC-85.
USB to IRDA adapters work fine, and are less expensive $5-6 than
PCMCIA to Parallel adapters, $20-25.
I have tested and used several PCMCIA adapters from different manufacturers, and they all work perfectly as a hot-pluggable, instant LPT and/or Legacy Serial port for my laptops.
TIPS:
After installing the PC Card driver, check Device Manager for the LPT port number.
Install the printer manually from the list of printers, and select the proper LPT port.
Most laptops have two PCMCIA slots. If you change slots, the adapter card driver may reinstall, and assign the next available LPT port, LPT2.
To scan with the BJC-80, you must have an LPT port.
The PC Card adapter also allows the use of the IS-12 scanner cartridge within XP or Vista.
Within Vista, set the Canon ISScan software to run in Windows 98 compatibility mode, to allow use of the TWAIN driver.
Jun 12, 2008 | Canon BJC 80 InkJet Printer
Canon BJC 2000 question-1284 to usb
TIPS:
Jun 05, 2008 | Canon BJC 80 InkJet Printer
Slow printing
I'M USING MY BJC 80 ON A PACKARD BELL M35-U-57, VISTA HOME BASIC. CONNECTED THE PRINTER WITH A GENERIC USB-PARALELL CABLE, NO DRIVER. FIRST HAD THOSE 5 TO 7 MINUTES DELAYS FOR PRINTING. WENT TO THE PRINTERS "PROPERTIES", "ADVANCED OPTIONS" AND TICKED "PRINT DIRECTLY", IN THE "PORTS" SECTION I DISABLED "BIDERECTIONAL PORT". IT'S WORKING SWEET. NO MATTER THE QUALITY. ANY COMMENT OR SUGESTION: decoy424@gmail.com
Feb 03, 2008 | Canon BJC 80 InkJet Printer
Canon BJC 80 InkJet Printer Logo
165 people viewed this question
old marine
old marine
