Question about Delta 31 - 120 12" Disc Sander
Older 31-125 model. Disc doesn't stick to machine well. Also would like to find a manual for it.
  • 2,176 Answers
Found you a parts breakdown at Dewaltservicenet.com but no online user manual. On the Dewalt site use the - between number for it to come up.
Posted on Oct 02, 2009
Testimonial: "Very good. I am very grateful. This far exceeded my expectations Thanx"
Why is the take up lever sticking
Really not able to provide helpful advice without the brand and model of the machine.
If it is an older model machine (mechanical), a drop of fresh, good quality sewing machine oil where the lever pivots may take care of the problem.
Jul 23, 2016 | Sewing Machines
Where are the oil ports on an old Kenmore 10 sewing machine #12511..thanks
If your older Kenmore is mechanical (not computerized), it probably can use a bit of oiling beyond what the manual recommends. Older machines frequently were pre-oiled at the factory, however, after many years, the oil tends to dry out and cause the mechanical parts to stick (the reason most older machines are frozen). Perhaps this link will be of help:
It was working now it seems to be frozen the needle part wont move
Feb 10, 2016 | Kenmore Sewing Machines
Motor grinds only when the foot plate is lowered down
If it is an older mechanical machine (NOT computerized), it probably needs oiling. The old oil has solidified and is actually sticking the moving parts together enough that the motor is unable to make the machine work. Do not force the motor or it may cause it to burn out. Consult the owner's manual for oiling instructions. Use ONLY fresh good quality oil!
If you need a manual, search the internet for:
Manufacturer + Model + the word "Manual"
Nov 22, 2015 | Sewing Machines
Dvd player will play store bought DVD's but will reject other dvd's saying unknown disc when inserted
some older models wont recognize burnt DVD's
maybe Netflix discs have a macro on that doesn't allow your player to play them.
Sep 06, 2012 | Zenith XBV243 DVD Player/VCR
201-2 singer sewing machine plug wireing diagram
Any of the older Singer manuals will give you this info...here's a PDF for your machine...
http://www.ismacs.net/singer_sewing_machine_company/manuals/singer-model-201-sewing-machine-manual.pdf
If that doesn't help scroll down on this page there's a simple diagram on there.
http://blog.sew-classic.com/2009/11/30/replacing-the-wires-on-a-singer-button-foot-motor-control.aspx
Aug 31, 2012 | Singer Sewing Machines
Why won't a CD-RW disc play in my car CD player?
Some of the older cd players, car or otherwise, just aren't capable of recognizing CD-RW's. The player in my 10 year old Ford Mondeo doesn't, but the updated model player in the newer Mondeo does play CD-RW's.
Aug 25, 2012 | Memorex 700MB CD-RW 80 Media (50-pack...
Front panel on machine just reads ..disc not finalised.what does this mean please?
Are the discs ones that you created (burned), someone else burned, or commercial discs? The message of disc not finalized usually appears when you put a CD or DVD from one unit into anther without closing (finalizing) the disc. The finalization step doesn't matter if the disc is being moved between computers with compatible OS versions (for example: XP through Windows 7). However, any other device will need this procedure completed.
Take the disc back to the unit (computer or other burner) where the disc was burned. If the computer uses Windows, put the disc in the optical drive. Open My Computer (Computer) depending on the OS by double left-clicking on the icon on the desktop. Right click on the optical drive and select Close Session.
If you created the CD on another machine, check the details for that device.
Note: you should double-check that the format that you burned to disc is compatible with this CD player. Not all models support MP3 files. On my own older CD player, I had to burn WAV files without gaps in a Disc At Once format to get the discs to play without skips.
I hope this helps.
(if the discs were commercial discs or have been finalized, I would expect a different error. In that case, I'd suspect a tracking problem and a "No Disc" error.)
Jun 15, 2012 | Marantz Audio Players & Recorders
Cant find transmission dip stick , 5 speed manual.
The 5 speed manual transmission in your Focus doesn't have a Dipstick, the fluid level is checked by going under the car and removing a fill plug on the side of the transmission case, you then stick your pinkie in the hole and if you can just touch the transmission lube the level is correct. No Ford except automatic transmission models has dipsticks, and even those have been eliminated on the latest models.
Jun 13, 2011 | 2001 Ford Focus
Kenmore sewing machine manual for model # 148 12080. (older)
i have a older kenmore sewing machine model #148.19370
Aug 15, 2008 | Sewing Machines
Delta 31 - 120 12" Disc Sander Logo
112 people viewed this question
Top Delta Tools & Hardware - Others Experts
Andrew Taylor
Andrew Taylor
John Trevino
Are you a Delta Tool and Hardware - Other Expert? Answer questions, earn points and help others
