My Daytek tv (HDTV+SRS) got a big problem. I gess the condenser blowed out . During few day, I had difficulty to open it , now its impossible. what can iI do (Excuse my english, i am french speaking : do you have service in french in montreal ?
    President:
  • 1,462 Answers
First you have to check the power supply and the internal fuse..
If you hear the click sound then, It states that your TV has gone into protection mode. This is caused by a short condition in one of the many sections
The most common issues would be blown out capacitor, you have to open the cabinet and check for the bulging and the worn out capaciors..
Very sorry, we dont have service in french
Please leave me comment, if you need further assistance
RNJ VINODKUMAR
Posted on Sep 30, 2009
HOW TO HOOK UP HDTV ATTENA TO DAYTEK 426F SO IT WILL ACCEPT CHANNELS
If your Daytek TV is equipped with a digital tuner, connect your HDTV antenna to the antenna input of the TV.
Feb 05, 2015 | Televison & Video
I have a sony bravia kdl32d3100. Started have thick bars which were transparent. Then it stopped for a few days then started again followed by coloured lines all over the screen then it went back to normal...
Playin xbox on it and ps3 or any video game would do it and when it stop dose it have a green or purple tint to it calse that will never leve and it all comes down to video game and it sucks cakes there so fun but I messed up my dads big falt screan tv like that and it could also be ur aideo coreds as well as ur tv cable other then that if all that is fine bro I ges ur just gona hve to ether deal with that or get anouther tv
Apr 30, 2012 | Sony Televison & Video
Hello all ! My 42 inch Daytek TV is broken. I tried everything to fix it but.... no success. I know which PCB is defective but i cannot find a replacement part for it. Daytek doesn't sell parts anymore...
Hi mojo_686,
If you can't find the exact part for your Daytek TV in a local store or repair center, I recommend to contact the manufacturer directly. If system is still in warranty they will set up a free service and repair for your unit. Please click the link below for the complete contact information of Daytek.
Daytek Contact Info
Hope it helps.
Thank you for using FixYa.
Mar 24, 2011 | Televison & Video
Daytek DT-3220 power problem
I have just fixed the power problem on my Daytek 3220. It looks like the Bentek BP-200AD power supply is used in other cheap brand TV's besides this Daytek : Hyundai HLT 3280, Jwin JV-DTV3212.
At first, my TV would just lose the backlight, while the video and sound would still work fine. Power cycling the tv would correct the issue, but would repeat the problem after shorter periods of time.
More recently, I've started losing the video and audio, shortly after backlight.
I have checked all the caps on the outputs and they all tested ok, using capacity and ESR meter (surprisingly enough) and no bulging either.
This power supply outputs 3 voltages : 5V, 12V and 24V, with a stand-by control pin on the 5V connector (0V for TV on and 5v for tv off).
I have got the readings after the power died:
5v out= 5v--ok
12vout=0.72v not ok
24vout=0.0v not ok
One of the transformers was squealing quite annoying while tv worked, but started modulating the squeal a couple of seconds before power died.
The culprit : one small electrolytic capacitor marked C19 on both sides of the board, with a value of 47uF/35v. I have replaced it a 56uF/50v and the TV started working as new (and of course no more squealing either).
Use a good quality cap when replacing C19. A 50v rated one would be a better choice than the original 35v and make sure it is also rated for 105 degrees Celsius, since it is very close to one of the heatsinks.
As always the DISCLAIMER: take all the precautions to avoid electrocution. Disconnect the TV from power, allow a few minutes for the big 400Volt capacitors to discharge completely, before handling and working on the power supply.
Feb 13, 2010 | Televison & Video
Truck will not start
your fuel tank has water in it and in cold temps it surrounds the filter on the pump and ices over cause gasoline ges way colder than water
Jan 21, 2010 | 1992 GMC Sierra
Dark picture on 62" lcd
how old is the lamp , if is about a year old need a newone
May 12, 2009 | JVC HD-61Z575 61" Rear Projection...
I NEED CODES FOR TV DAYTEK AND HOW TO PROGRAM THIS
we have a 21" daytek hi def tv with no book or control. help?
Oct 31, 2008 | One For All URC-3021 Remote Control
Help...no picture
Good Day;
SRS Audio, = 29 volt regulator. TV has bad SRS Audio Output IC IJ01. Replace IC , also check after replacement, F903 off of T901.FACT!
Good Luck and Day, big Irish. e me mmrkcar@yahoo.com.
Jun 14, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Motorola DVR headphone problem.
are you connecting the headphones to the tv or cable box. Also is there any home theater systems being used in this setup
Mar 12, 2007 | Arris DCT6200 DTV Receiver
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
