Question about Dometic Refrigerators
I have two dometic refrigs next to each other in the same compartment on my houseboat in Lake Powell (where there are no repair people) - the RM 2862 works great on AC or gas. My problem - the RM 3863 ! I will start it on gas, hear the gas ignite and then in a few minutes "check" comes on. If I start it with AC from the generator and run it on AC for maybe 15 minutes, then shut off AC, power switches to "gas' and the refrig will work great for maybe 24 hours, then " check " comes on and the refrig is off. Same thing then - won't restart on gas but the AC will start it and then will run for 24 hours on gas. The frig is 6 years old and is used maybe 20 hours a year. Could this be fixed with just re-placing a " board " or so, which I could do>
  • bobandscats Sep 30, 2009
    My houseboat is a 1985 model. I bought these frigs from Camping World and installed them myself.. The problem frig I'm asking about ran great for the first 3 years. I am aware of the "recall" and had the repairs done last spring. This problem I am asking about has been going on for a year but can't find anyone to help me now. Can you?
    So appreciate your quick replys. Yes, I have felt it is a control problem. I do have the schematic in the "Installation and Operation Instructions " book that came with the frig. What do you mean "have I done the preliminaries" ? The boat-frig are at Lake Powell, 170 miles away from my home, and I will be going over there Fri 10/9 for the weekend. Do you want to come or can you tell me what to do to get you more info ?
    President:
  • 1,714 Answers
Your refrigerator is in a 'recall' Go here:
This is way you have problems...
http://www.azrvinc.com/Dometic%20Recall.asp
These refrigerators were installed in certain recreational vehicles as original equipment and sold as aftermarket equipment. A fatigue crack may develop in the boiler tube which may release a sufficient amount of pressurized coolant solution into an area where an ignition source (gas flame) is present. This release of coolant under certain conditions could ignite and result in a fire.
There are potentially 926877 units affected
The vehicle manufacturers will notify owners of recreational vehicles that had the refrigerators installed as original equipment and Dometic will notify the owners of the aftermarket refrigerators. Dometic will install a secondary burner housing free of charge. Owners may contact Dometic at 888-446-5157
Posted on Sep 30, 2009
  • 4 more comments
  • Craig Butler
    Craig Butler Sep 30, 2009
    Yes I can help you but I need more info. It sounds like a compressor control problem. Is there any schematic on the unit? The problem does not seem to be isolated to gas or electric, so I think it's just a general control problem. Is there a control board in it? Have you done the preliminary checks? Terminal connections, visual?
  • Craig Butler
    Do I want to go to Powell, hell ya, but I can't, thanks though! Get me a schematic and send me a copy any way you can. email it to 'protek@bresnan.net' I'll give 'er a look.
  • Craig Butler
    Give everything a good and through looking at, that is a visual inspection. You find many problems right there. Then, tug on all the wires, wiggle stuff, just mess with stuff and see what you see...
  • Craig Butler
    Sound good?
  • Craig Butler
    If you have to, take a close up photo of the schematic and make sure you can read it, then send that to me...
  • Craig Butler
    Also, who is the mfg. of the refrigerator?
Need a manual for a Dometic RM 2610 refrig?
perhaps the RV dealer where you bought it can assist you
Feb 04, 2015 | Dometic Refrigerators
I have a dometic RM 2862 refrigerator and smelled ammonia and then heated up but no signs of leaks, is the cooling unit bad?
Is it still working? If you can smell ammonia, I would say that there is a very small leak. Over time, the fridge will lose its efficiency and take longer and longer to cool down. Eventually, it wont cool at all once all the gas has escaped. From what I remember of Dometic fridges, is that they used to supply exchange refrigeration units. You remove the entire refrigeration system and swap it for a new or rebuilt system. It worked out a lot cheaper than buying a new fridge.
Jun 19, 2014 | Dometic RM2852 Refrigerator
Dometic RM 2862
remove heater element from back board if ok bad heat element if ok disconnect ignitor if ok replace ignitor if not shorted wire or bad board
Jan 13, 2014 | Dometic Americana Plus - 8 cu ft DM2862...
Dometic rm 2862 freezes everything in the refridgerator
move temp sensor to inside of coils if same replace temp sensor
Mar 17, 2013 | Dometic RM2652 Refrigerator
I have a Dometic Rm 2862 2-way about five years old.
Ammonia smell means cooling unit is done. Just double check on dometic site in case of any recalls that may apply. (dometicusa.com)
May 24, 2010 | Dometic RM2852 Refrigerator
Refrig cooling
Sounds like the evaporator fan is not working. Check to see if you can hear the fan running in the freezer. If not running, try removing the panel in the back of the inside freezer and manually spin the fan blade . This sometimes works.
Jul 03, 2009 | Refrigerators
Dometic DM 2862 Too Cold Freezing Everything Running About 26Deg. F In Lower Compartment Just Restarted After Winter Shutdown. Doesn't Matter If Running On Gas Or 110V
don't worry! just switch off your refrigerator for 8hrs than switch it on......place the thermostart at 3 point......i'm sure that your problem will be solved. if not than replace your thermostart..................have a nice day:-)
May 15, 2009 | Refrigerators
Refrigerators Logo
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
