Question about Harman Kardon DVD47 DVD A/V Player ETA 4/06
No Audio with my 42 inch Panasonic Plasma TV/ Blue Ray
I have a AVR146 connected to a 1080 42-inch Panasonic Plasma TV/Blue Ray disc player and I can't use the HK146 as a sound source. The FM works OK... I am using HDMI cables for everything.
Setup mentioned something about "S" video cable, but it doesn't tell you where to hook it up (can't see the on-screen menu (146) either. Starting to wonder if I shoun't just return it for a Sony system. What do you think?
SOURCE: HK AVR 645 7.1-Receiver Turns off when sound starts to come through
Hello, I didn't end up fixing the Blu-ray issue, but the TV issue was caused by just inverting the positive and negative cable going into my speaker. Odd enough, instead of just not working, it just flipped the entire system off. I can definitely see that that could be the issue, another one I thought of is, at the time I didn't realize that DVI doesn't play audio, only video and I didn't have a optical cable connected. I decided to avoid the hassle, sell the TV and purchased one that has HDMI. Muuuuch better.
Posted on Aug 08, 2008
Benimur
  • 6966 Answers
SOURCE: creating a surround sound system
Hi and welcome to FixYa,
Offhand should work more than OK. Even if the 520 is only pushing 75watts per channel, you have 2 X for the front KSB-2.1 (left & right) plus another 75 for the Polk Audio center in addition to 250watts built-in amp of the Velodyne CT-150. What would be better is another pair of KSB-2.1 or comparable for the surround (another 2 X 75 and widening the separation).
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 16, 2008
SOURCE: Audio problems using a Playstation 3
First try ensuring that "OPT 1, 2, or 3" function is selected depending which one you are using on the H/K 146 (see manual for selection instructions). Next please ensure that the PS3 audio out set to "optical" (Settings/sound settings/audio output settings/digital out+DD 5.1). That should help.
Posted on Dec 24, 2008
DickCanFixIt
  • 948 Answers
SOURCE: Lost 3.2.1 surround function when I hooked up new plasma
HDMI cables contain both your audio & video in one cable. Remove your optical cable from the box and disable in in the cable box menu and that should fix your problem.
Posted on Dec 29, 2008
SOURCE: no audio
Try this link! It might be in the way your "stereo" settings are right now.
http://www.harmankardon.com/faq/showfaq.aspx?lstProduct=DVD%2047
Posted on Feb 21, 2009
My Panasonic plasma Tv does not have sound. How do I fixed that
Sound no picture on 50 inch samsung plasma ps51d450a2m - HDTV ...
www.tomsguide.com/.../58009-4-sound-picture-inch-samsung-plasma-ps...
Jul 1, 2015 - 4 posts - ‎3 authors
There is sound and no picture on plasma tv, remote works at times but ... My pioneer elilte has this mode, and it is pretty easy to completely turn ... When I connect my Laptop to my TV thru HDMI cable I ...
Feb 22, 2015
Problems with blu ray player and plasma tv - HDTV ...
Nov 16, 2014
I do not have audio out on my tv how do i connect so ...
Dec 18, 2013
All channels on my tv have sound except channel 3 ...
Jun 29, 2010
More results from www.tomsguide.com
No picture or sound in my Panasonic TH-P42UT30A plasma ...
Dec 07, 2015 | Panasonic Viera Th-50px60u 50" Plasma...
Why wont my samsung dvd-vr357 play blu ray disks
Educated guess is you need a blu ray player. I have several very expensive Pioneer Elite DVD players and they cannot play blu ray. Blu ray is a multi level glorified DVD which you need at least a blu ray player to play in almost all cases.
You can play dvds on a blue ray but not the reverse in most cases. If you play a dvd on a blu ray player it kicks the video up to HD for the DVD.
Apr 14, 2014 | Televison & Video
How do I connect the DVD player to a Panasonic High Def Plasma TV?
Choose connections on the Panasonic that match those on the player--
Do you have on the player Component outs(blue,green,red and 2 audio which are red and white? This ought to give you the best picture and sound.
Other inputs to the set must match the ones coming from the player--Most owner manuals have a lot of details here.
If the player has 1080 output hook to a similar input on the set.
Some advice here: make the connections between units with both turned off.
Apr 03, 2012 | Durabrand DVD-1002 DVD Player
I have a Maxent Product Name mx-42HPT51 Model Number P4202YD02 Will it support a Blue Ray DVD player?
Of course you should have not issues, you can either go hdmi or component that particular model has 1080 i technology so you should be fine.
May 30, 2011 | Maxent MX-42HPT51 42 in. Plasma TV
How to connect Blu ray disc player with my Bose 321 system. I have 1080 p samsung LCD TV. How to get the best.
hi,
do the following.
1. connect ur blue rays hdmi out to ur tvs hdmi input.
2. connct blue rays out to any one of the coaxial(aux) input of bose.
3. connect ur tvs optical audio output to optical audio input of bose
4. connect monitor out of ur bose to any one of ur av in of ur tv. connect component video to better quality .
4 . in the blue rays audio setup select audio output priority as optical/coaxial
5 . in bose set aux as digital input.
to see blue ray select hdmi of ur tv, sellect in bose in which the blue rays coaxial is connected(aux) insert disk in blue ray an watch
to see dvd in bose select tvs corresponding input, select bose to dvd . insert dvd and watch
to whach tv program set tv to corresponding mode. set bose to optical audio input mode.
ok
Dec 15, 2010 | Televison & Video
Hi I have a Yamaha yht 292 surround sound system with a model htr 6230 reciever. I have a panasonic (42'') plasma HDTV (model TC P42X1) attached to the receiver by a HDMI cable. I also have a Samsung Blue...
As per HTR-6230 specifications (http://www.yamaha.com/yec/products/productdetail.html?CNTID=5028494&CTID=5000400&ATRID=1020&DETYP=ATTRIBUTE) the HDMI function is only "audio-passthru", which means your receiver is not able to get the audio from HDMI cable, it can only pass it forward to TV. You would need a receiver with "HDMI switch" to be able to listen to audio via HDMI cable. You can find such receiver by looking if it supports TrueHD audio (which can be transferred ONLY via HDMI cable).
With your current receiver, you can connect it to the Blue-ray player via Optical SPDIF cable. I have checked the specs and both receiver and BD player supports optical connection.
Feb 25, 2010 | Yamaha YHT-390 Theater System
Just bought blue ray player I have a hitachi plasma tv model pw1 32pd5000 how can I get blue ray to work with tv theres no hd outlet at the back of tv but it is hd compatible
The TV most likely will have component and a DVI connector on it if it doesn't have a HDMI connector. If the Blu-ray player has component connectors on it use them as they will give you up to a 1080i picture which is all this model of Hitachi supports anyway. If the player doesn't have component connections then you can get a HDMI to DVI converter cable so you can connect it to your TV. You will need a cable that looks like this...
http://www.kmart.com/shc/s/p_10151_10104_25000PCM-2296-06P?vName=Computers%20&%20Electronics=&cName=HomeTheater&Audio=&sName=Accessories&psid=FROOGLE&aff=Y&sid=KAx20061023x272xTier3
Nov 11, 2009 | Hitachi P42A202 42 in. Plasma TV
Panasonic Plasma HDTV 50" Viera--won't turn on. Red light flashes 10 times followed by a 3 sec pause, then repeat 10 flashes. Have solved problem by unplugging it and plugging it back in, but that is not...
Please make sure your connectors are in the proper place.
The HDMI inputs on the rear of the TV are optimized for use with Audio/Video devices, Blu-ray Disc Player, DVD Recorder, etc.
The front or side HDMI inputs only are designated for PC. To use the TV as a PC monitor, advise customers to use only front or side HDMI inputs.
Jun 16, 2009 | Panasonic Viera TH-50PZ800U Plasma TV
Harman Kardon DVD47 DVD A/V Player ETA 4/06 Logo
256 people viewed this question
Top Harman Kardon Televison & Video Experts
Demonic-2011
Demonic-2011
Brett Duxbury
Brett Duxbury
Are you a Harman Kardon Televison and Video Expert? Answer questions, earn points and help others
