Question about Cameras
My pictures do not automaticly remove when attached to my pc as they used to
    Scholar:
  • 96 Answers
That must be the camera software you loaded, try re-installing it.
Cheers.
Posted on Oct 01, 2009
How can i transfer pictures from Samsung camera to PC if i do not have memory card
these kind of cameras usually come with a usb cable, see if you can find the attachment connection, if you see it then take the cam to a retailer or pc shop and bye that cable, once attached the pc will install software automatically and you can then download your pictures
Dec 12, 2010 | Samsung Digimax S600 Digital Camera
Unable to load the picture in PC. When camara is attached to the pC through data cable for download the picture from camar to PC it is not down.
Consider NOT attaching your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jun 29, 2010 | Kodak EasyShare C913 Digital Camera
Windows picture and fax viewer closes automatically and turns off
the windows picture viewer take the more load to access these pictures.
you can try picasa picture viewer it take very less time to load. you can got it from the Google more products it is about 11.mb download it and install it.your problem remove out most probably.
Apr 23, 2010 | HP Pavilion dv6000z Notebook
I need to delete a number of pictures at once off my SD card and would like to do it via my computer but can't find out how. Failing that how do I delete a number of pictures from the SD card period. I...
First you will need to attach the USB cord to your camera and then attach the other end to your PC. Once you have attached both ends, you will either have a program that automatically loads up when the camera is detected by the PC or you will have an option menu of which to open up.
I personally find using Windows Explorer a better way. To do so, do the following (this is assuming you are running on XP)
Start
Programs
Accessories
Choose Windows Explorer
When that opens click the + on My Computer
Look for Removable Disk (F:) ( NOTE: F can be any letter depending on your system set up)
Click on Removable Disk and choose DCIM
Then choose ###_PANA (it may be named something else)
All your pictures should be here
Now, to delete them you can
A: Delete them all by choosing one picture and then hold down the CTRL key and press A. This will highlight them all. Then hit your DELETE key. Or...
B: To choose certain ones you want to delete: Hold down the CTRL key and left click the pictures you want to delete with your mouse. When you are done choosing the ones you don't want, hit your DELETE key.
This will remove all or your selected pictures from your smart card entirely.
If you are using the program that came with the camera, you can still use the same method using the CTRL key above to delete the pictures you don't want. It functions the same way regardless.
But be warned, try it out on a couple pictures first to see if you understand, because once they are gone, they are gone.
Aug 19, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
I would like to know how to reset the settings on the SPX08 smartparts digital frame. It currently only turns on for approximately 5 seconds and then automatically turns off. Thanks.
I had the same problem with an SPX08E. It turned out that enabling the auto light sensor was the cause!
The way I fixed it was to remove all memory cards and attach the frame via USB to a PC. Then use windows explorer to delete all folders and files on the frame other than the smartpix installer MSI. Then remove the USB and power cycle the frame. It will come up at the main menu and you then have about 15 secs to navigate to the settings page, scroll down to the reset settings tab and reset all settings to defaults. You can then transfer any pictures you want back to internal memory.
Do not turn on the light sensor or you will have to do it all over again!
Dec 07, 2008 | SmartParts SPX8 Digital Picture Frame
Have an Olympus Stylus 850 SW...........How do I down load photos from my Favorites in camera to a computer. Is this even possible? thanx ernie
yes this is possible all you have to do is follow these instructions:
there is two ways to load pictures from your cam to pc:
step 1
youll need a card reader to put in the memory card to a usb port.
A.then the computer will recognize the device as a FLASH DISK/ REMOVABLE DISK.
B.some pc will automatically open once you inserted the card reader to the usb port "click open containing folder". if the pc does not open automatically open my computer and find the "falsh disk/removable disk" and click.
C.once inside find the DCIM folder this contains your pictures taken from your cam.
D. now you can choose a picture you like to be transfered or copy to your PC
E. save picture in a folder that you ca easily remember
step 2
need a usb wire to connect cam to usb port
A. attach wire from your cam to usb port/pc
B. your cam will show options choose storage data. the other options requires a software
C.same as step 1 from B-E
i hope i was able to help you! good luck!
Nov 18, 2008 | Olympus Cameras
Lost software disc
step 1
B.some pc will automatically open once you inserted the card reader to the usb port "click open containing folder". if the pc does not open automatically open my computer and find the "flash disk/removable disk" and click.
step 2
here is the site for version 1.10:
http://drivers.softpedia.com/progDownload/Pentax-Optio-230-110-Download-16224.html
here is the site for version 2.1
http://driverscollection.com/?file_id=29747
Nov 16, 2008 | Pentax Optio 230 Digital Camera
How to use a USB 2.0 Micro drive, memory stick
if you have a card reader, insert your memory stick into the slot, then attach your card reader to the usb port of the pc, it will detect it automatically, then select open the folder option, select the picture folder, press ctrl+c, then paste it into the c: drive or d: drive of your pc
Nov 08, 2008 | Computers & Internet
Help Please
step 1
step 2
i hope i was able to help you with your problem! good luck!
Nov 02, 2008 | Canon PowerShot A80 Digital Camera
Can't get the software for my new Panasonic TZ5 Lumix to load into my iMac! iMac doesn't recognize it as a CD. Urgently need to download my photos to update my website! Help! Patti
step 1
step 2
Nov 01, 2008 | Cameras
Cameras Logo
27 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
