Question about Fostex Audio Players & Recorders
Where may i get replacement wires for my fostex headphones
Where can i get firmware for a fostex vf80?
You can find it on the Japanese Fostex site:
http://www2.fostex.jp/user_file/fostex-sh/etc/vf80v2.html
It's on the bottom of the page (v2.08)
Cheers,
Tomas
Sep 17, 2014 | Fostex Vf80ex
I can only hear static through the headphones on my Fostex MR16. The recording sounds fine when I transfer to computer, but I can't hear myself playing.
They make headphone amps that will take a line level and boost it in volume until it can drive headphones. I'd get one of those, and plug it into any available "line out" or "rec out" on the back of your Fostex. Sounds like the D/A converter section that feeds the headphone output has gone bad, and my solution will get you around that.
Nov 27, 2013 | Fostex Mr16hd 16 Track Digital Recorder
How can i get a Fostex PM-1 service manual
The fostex site wouldn't let me save this to my desktop to upload to fix ya because
I'm not trying to sign in but you can if you want or bookmark this page http://www.retrevo.com/support/Fostex-PM-0.5-MKII-Speaker-Systems-manual/id/22921dj685/t/2/
Feb 18, 2011 | Fostex PM-1 MKII 6.5" Active Nearfield...
Hi there . please help me as i love these headphones. the sound from one speaker died. by withdrawing the lead one step back the sound comes through both speakers but its not the same tone as before ,...
You're absolutely right, in case the earth cable (the common one from both headphones) is cut, the sound is mono and less bright than the original. You must locate the point of the cable with the problem, cut the cable at this point and connect it at a new headphones jack. In case you can't use a soldering tool for the connections, I suggest to use another cable with the headphones jack already connected, cut it about 20 cm from the jack and connect these leads at the leads you cut before. About the wiring the common rule is that the black cable goes to the grownd of the jack (it's the common cable) and the other two are for the two rest leads. In order to give more details post me back how you are going to handle it (with soldering tool or just cables) in order to give you more details and schematics. A good idea is to clarify the color of the existing cable leads and if possible the availability of a multimeter.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Feb 05, 2011 | Fostex T20RP Professional Headphones
I get error code 63 when i turn on my Fostex vf160
Jan 18, 2010 | Fostex MR16HD/CD Digital Recorder
Replacement foam for Beyerdynamic DT 531 Consumer Headphones
I have the same problem with a pair of Fostex Headphones. I have taken them apart and I have removed the rubber type ring that the foam fits over.
I am going to order a cheap pair of thin foam Headphone ear covers from Ebay. (They are available in various sizes) and stick the foam to the ring and follow that
by sticking the ring back in. Should work if the foam is thin enough. What do you think?
Eddie
Nov 27, 2008 | Beyerdynamic DT 531 Consumer Headphones
Alternative compact flash cards for fostex mr-8
Fostex has a list of tested and confirmed Compact Flash Cards for the MR-8:
(It is under Support on the Fostex USA main page)
http://www.fostexusa.com/support/pdf/fostex/mr8/mr8_confirmed_media_list.pdf
Looks like they have tested up to 2GB with no problems...
Hope this helps
Nov 19, 2008 | Electronics - Others
FOSTEX mr 8 rECORDER
fostex owners manuals are available at the fostex website for download.
Jul 15, 2008 | Fostex MR16HD/CD Digital Recorder
21 people viewed this question
Top Fostex Audio Players & Recorders Experts
rjivaro
Michael P
Level 1 Expert
Tom Chichester
Are you a Fostex Audio Player and Recorder Expert? Answer questions, earn points and help others
