About a month ago my remote control failed to display all the options that were previously available on the FORMAT control button, there were about 6 options before and now there are only 2, I can only get WIDWSCREEN or FULLSCREEN. This means that I can not see all of the images or text that is ailable. What can I do about this problem? I have a Philips 26 inch hd tv, the remote came with the set.
  • 11,896 Answers
Either the tv format is off and you may have to go in with manual settings. Or you can buy a replacement factory remote for your tv as well
Posted on Sep 30, 2009
How to reset a password on vizio p42hdtv10a tv i forgot the passwored
Hello
To change password use the number pad and type '0000' or whatever password you have changed it to previously, then press OK.
Actual proceedings are:
[1] Press the MENU button to open the main
On Screen Display (OSD) menu.
[2] Press the [
three times until the Parental Control
menu opens.
[3] Press the [Down] button on the remote control
to highlight Parental Lock Enable. The
"Key-In Access Code" window opens.
[4] Use the number pad to type the default
password (0000) or whatever password
press OK.
[5] Press the [Down] button on the remote control
to highlight Access Code Edit.
[6] Press the [=>] button on the remote control
to enter the submenu. You will need to
use the number pad to type default (or
what you changed to previously) password
first
[7] Use the number pad to type the new
password.
[8] Confirm the new password by retyping it.
[9] Press EXIT button on the remote control immediately to exit the OSD menu
Jul 29, 2011 | Televison & Video
How to adjust color for better picture
Hello there,
For the Best Picture use the HDMI Cable and here are the Settings for the color setup.
Adjusting Your HDTV Settings
Using the On-screen Display (OSD)
The remote control or the control buttons on the side of the TV can control all the function settings. The
OSD allows you to adjust contrast, brightness and other settings. The TV will save changes made to the
settings, even if the TV is turned off.
The OSD consists of several menu options. The main menu options may vary depending on your
selected input source.
Note: Some of the main menu options may have additional submenus, for example, the TV Rating
submenu for Parental Controls.
The remote control or the buttons on the side of the TV can control all the function settings. The HDTV
Settings App allows you to adjust contrast, brightness and other settings. The TV will save changes made
to the settings, even if the TV is turned off.
The HDTV Settings App consists of several menu options. The main menu options may vary depending
on your selected input source.
1. Press the VIA button.
2. Press ? or ? on the remote control to select the HDTV
Settings App, and then press OK. The Main Menu will be
shown on the screen.
3. Press ?, ?, ?, or ? on the remote control to select one of
the menu options:
? Input
? Wide
? CC
? Sleep Timer
? TV Settings
? PIP
? Network
? Bluetooth
? Help
4. Press OK to select the option or feature you want to adjust.
5. Once the menu option is displayed, press ? or ? on the
remote control to select one of the items to adjust.
6. Press OK to select it, and then press ?, ?, ?, or ? to adjust the selection.
7. Press BACK once to return to the previous screen. To return to your program once adjustments
have been completed, you can do one of the following:
a. Press EXIT on the remote control.
b. Press the RED button on the remote control.
c. Highlight and select the RED X in any menu.
i hope this was helpful don't forget to Rate
Jan 26, 2011 | Vizio M550NV 55 in LCD HDTV
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
I've had my Arc wireless mouse (model 1350) for about 5 months now. I have replaced the battery twice since I got it...most recently a day ago. The second battery replacement causes a green light to...
control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot or select properties under driver you can update driver,rollback driver or uninstall
hope this helps
Oct 12, 2010 | Computers & Internet
Sears garage door keypad/remote programming problem
The button you added in your car is an earlier technology that is not compatible with the rolling code technology.
Apr 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Panasonic DMR-EX77 - Error code DVD3
Pan use a version of Linux on the recorder. If you change the hard drive there is a format command in setup to format a new hard drive. Put a DVD in and try selecting and playing both DVD and HHD via the front panel buttons. Sometimes you can get error codes on a unit when the batteries in the remote are low. Try changing them Sometimes the remotes are faulty and not communicating properly. A fix in some cases is to press the number button corresponding to the number shown on the display together with the enter or OK button for at least 2 seconds. Good luck
Jan 21, 2009 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Unlock code for Technika DVD Faw08
The above don't work, half the suggested menu missing. No Set TV Standard option available:-(
Dec 20, 2008 | One For All URC 7740 Remote Control
Region codes for Samsung R155 (UK)
hi give this ago works fine on us or uk
1. Press the Menu button on your remote control
2. Press the 5 button on your remote control
3. Press the 7 button on your remote control
4. Press the 5 button on your remote control
5. Press the 3 button on your remote control
6. Press the 8 button on your remote control
7. The currently selected region will be indicated on the onscreen display
8. Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 9 button for multi-region playback
9. Press the Menu button on your remote control
10. Press the Menu button on your remote control
Tested and Worked on my UK player (Region 2).
also works on r136 and r150
Oct 25, 2007 | Samsung DVD-R155
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
