Question about Apple iPod MA446LL/A MP3 Player
IPOD wont play sound from either jack but charges. Says it is playing but no sound comes out. What can I do to fix it?
    Problem Solver:
  • 12 Answers
Might be ur earphones or an actual hardware error
Posted on Sep 30, 2009
IPod touch 4 sound output problems
Try using a very fine cloth to get into the headphones port and the charging port. If all else fails, you will probably have to take it into the Apple Store :D
Mar 21, 2014 | Apple iPod touch 4th Generation MP3 Player
When I plug my iPhone into the USB it doesn't
ANSWER: The headphone jack will not charge your iPod. Only the USB will charge your iPod. However, the headphone jack will play music, but the USB will not play music from your iPod.
REASON: The headphone jack does not provide any power to charge your iPod. It isnly has enough power to recieve a music signal.
REASON WHY YOU CANNOT PLAY IPOD THROUGH THE USB: The USB is only intended to be used with a flash drive or external hard drive with a folder structure containing either .mp3 or .wma files. The way the USB works on the system is that it reads all the files and folders on the entire device and will say "reading" until it reads all the files and folders. This should only take a few seconds but if there is tons of files it may take longer. Main problem: An iPod contains much more than just music files and folders - it contains an entire operating system. Worse, the operating system which the iPod uses is protected, keeping other devices except for iTunes from reading the music files.
TO PLAY MUSIC FROM USB (NOT IPOD): You will need to use a flash drive or external hard drive with your USB. This device can only contain music, and the music must be organized into folders. Your iPod will not work. However, you can use Auxiliary input using a cable which both ends are 1/4" headphone jacks, one end going to the iPod and other plugged into your stereo.
SOLUTION: To charge your iPod, you need to plug it into USB. However, to play music, you need to plug your iPod into the headphone jack.
Good Luck! - Chris Proia
p.s. Here is the User Manual for your XDM6350 : http://www.dualav.com/support/manuals/xdm6350.pdf
Aug 13, 2009 | Dual Electronics XDM6350 Car CD/ MP3...
Ihome won't play ipod, even after resetting ipod I have de same problem. I got an itouch 2nd generation and docked it on a speaker that supports it. It worked fine for two or three hours, but suddenly it...
Welcome to the wonderful world of the iHome frying the Ipod.
Your iHome, has most likely fried the mainboard on your ipod.
to check plug a usb into the ipod and connect to the computer.
if it comes up disconnect the usb and try a headphones in the jack.
if it doesn;t play sound its fried and you will need a new mainboard.
if it does play through the headphone jack, your lucky and keep it off the dock.
I have fixed at least 30 ipods taken out by ihome docks and other docks.
they are terrible for the ipod. Even Apple sells the docks on their website
that shows how much they care about the product.
If this helps leave a vote on fixya
May 11, 2009 | Apple iPod touch
Wont play through my bose system anymore
the apple ipod are very delicate and it seems that docks are very harsh on the internal workings IE: motherboard of the ipod. it not just the touch, it's all ipods.
My suggestion is to check the headphone jack and if you get sound, don;t play your ipod on the dock at all. Your dock has probably done some damage to the audio circuit on the board.
If you get sound through the headphone jack save your ipods life and just use it through the jack.
I have replaced numerous motherboards on ipods played on docks. they just don;t handle the charging and playing very well whether it's heat or just the wrong voltage I am not sure.
But my first question to a customer is have you played it on a dock.
I would stay away from the dock
Apr 30, 2009 | Apple iPod touch
Ipod Nano 4GB does not deliver sound
Try slowly and carefully twisting the head phone plug in the jack while music is playing. If it starts coming in in a choppy manner, then you may need to a) resawder the jack down or b) get a new ipod. I'd recommend b.
Mar 06, 2009 | Apple Audio Players & Recorders
IPod MA146LL/A no sound
You should check and see if the headphone jack is broke or not. That sometimes accounts for the reason why sound won't come out.
Go here to see about replacing/fixing a broken headphone jack:
http://store.ifixipodsfast.com/ipod-parts-/-installation/ipod-video/ipod-video-headphone-jack-/-hold-switch/prod_69.html
May 10, 2008 | Apple iPod MA446LL/A MP3 Player
My 5th gen. ipod wont play songs
Sounds like there is a problem with the headphone jack on your unit. This is a common problem. Recommend changing out the headphone jack. We offer this service.
Rick
EverGreen Electronics
Mar 14, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod
headphone jack bad?
Jan 22, 2008 | Apple iPod nano
Problems with Headphone and USB plugs
I share the same problem - I'm worried it's due to routine wear-and-tear on the jacks, so the connections are no longer solid. I hate to think I need to get it serviced for this. Usually buying a new cable has worked, but that gets expensive too... Anyone have a fix??
May 06, 2007 | Apple iPod nano
Apple iPod MA446LL/A MP3 Player Logo
143 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
