Question about Hoover Steam Vac Dual V w/ SpinScrub Vacuum
My front spin brush stopped working but everything else works
  • 333 Answers
You will need to replace the belt. Remove the screws from the bottom of the unit. Then remove the brush roller. You should be able to see the belt, if not you'll need to look on the upright part of the unit and ge tthe belt's "code" usually a letter. You can usually find the belt at walmart or wherever vacuums are sold.
Posted on Sep 30, 2009
Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
I can think of three things that could be wrong.
The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
The internal drive belt is worn, or the nylon bush that it runs on.
The clutch is worn out.
The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    The little brush on the front right stopped spinning around. there is nothing wrapped around it - it's clean so I don't know why it stopped working.
    Not knowing what vacuum you are using, the most common reason the brush roll doesn't turn is because the belt has lost elasticity. Try replacing the belt.
    Mar 07, 2016 | Vacuums
    Eureka 431BX suction stopped working. Roller still goes. Please help! Everything else is working great.
    Even though the brush is spinning, you probably need to replace the belt2_bing.gif because it is stretched. It is probably slipping on the beater bar..
    Jim
    Nov 30, 2009 | Eureka 431BX Bagless Upright Vacuum
    I have a hoover steam vac f5899-100 the brushes doesnt spin...everything else works but tha. we took the brushes apart to clean
    if after you cleaned the brushes and still doesn't work. it will have to be the turbine assembly that the brushes fit into.
    Jul 20, 2009 | Hoover F5899-910 SteamVac Vacuum
    Rotating Floor Brush Isin't spinning
    It appears that the end of the brush is getting jammed with hairs, treads, and/or dust or the belt may be worn. Try taking the brush out and hold it by the ends and try to turn it. It should turn quite easily if it is working good. If not try taking the ends off and clean them out. Also, make sure the belt is good.
    Mar 19, 2009 | Bissell Upright Vacuum - The Pet Hair...
    Roomba keeps saying clean brushes yet are clean!
    Make sure you take off the little cap at the end (the one that spins -- just grab it and pull it straight off) and clean under it too. The rest of the brush may look perfectly clean but what happens is that hair gets stuck under spinning cap and, like a slowly growing washer, it pushes the whole brush toward the gear box. When it gets pushed over enough, the large yellow ring starts to rub against the side of the brush deck making it harder for the motor to turn the brush and you get that "remove and clean brushes" message.
    Jan 30, 2009 | iRobot Roomba 530 Robotic Vacuum
    Brushes won't spin on hoover steam vac ls
    I have the SteamVac Dual and there's a screen on the underside of the unit. It's beneath the brushes and it's red. You have to pull and wiggle it to get it out. With the machine unplugged, lay the unit with the handle on the floor. In the owner's manual ( http://www.hoover.com/pdfs/manuals/F7222900.pdf ) this is shown on page 10 figure 3-2. Clean that screen.
    If they still won't spin, then take the brushes out. Again, with the unit on the floor, you simply grab the unit firmly and pull towards you. It's much easier to remove than the screen. I took the brush unit outside and blasted it with the house. You'll have to pull out whatever fur balls are clogging it but eventually you'll see that the brushes spin freely with the water squirting on them. Plug the brush unit back in and - in my case - they started spinning.
    Jun 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
    Brushes not spinning....
    My status light came on, the vac beeped twice and stopped. I noticed my brushes weren't spinning. I took an eyeglass screwdriver and took off the center screw that holds on the brushes. I cleaned the shaft that the brushes spin on. replaced brushes and it works great! I just did this now and it is still running. my status light problem is fixed my roomba is 4 years old and I am on my 2nd battery. Seems to have fixed the problem. FYI it was wrapped with hair, dirt and it was greasy.
    May 29, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
    Bissell 37602 roller stopped spinning
    If the roller brush as stopped spinneng .and the brush motor still works the brush belt as broken,
    you must replace the brush belt, t
    Sep 05, 2007 | Bissell 37603 Upright Vacuum
    Hoover Steam Vac Dual V w/ SpinScrub Vacuum Logo
    165 people viewed this question
    Top Hoover Vacuums Experts
    Gerry Harvey
    Gerry Harvey
    Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
