Question about Compaq Presario 700 470024-192 Notebook
Screen is partially blank
About the bottom 3rd of the screen is blacked out. I assume this is a hardware problem, but what would I need to repair it....the entire screen or the LCD inverter? or something else? And tips to do the repair myself????
Thanks
    Novelist:
  • 188 Answers
Yup the LCD has failed. The nice thing is that this series uses the same LCD as a lot of other Hp/compaq products.
The LCD is easy to remove on this series, not a lot of screws and wires.
these screen models should be compatible with your machine:
LTN141X8-L04
UB141X02
Ebay has lots of these available right now.
If you want to match it up exactly and be sure, then pull out the LCD and look at it directly. All the screws are at the corners of the front of the display. You may need a Torx screwdriver (its been a while since i saw this series).
Posted on Dec 19, 2007
My HP Monitor refuses to turn on.. It's on but the screen is black
martineillas, Go here first, and do some reading. http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Then do standard flashlight test to determine "full" or "partial" shutdown mode of the internal power supply. Look at rear of monitor for "date of manufacture" ?? If screen is black and blank, then supply is in full shutdown mode. If not blank, only black, then 5vdc ok, 12vdc in shutdown mode (bad) !!! Do some extensive reading in the fixya profiles of the technicians here on FIXYA. Plenty of repair documentation already been written on this type of lcd monitor repair. Always state "model number" and approximate total "on" hours of use when contacting fixya for help. Good luck with repair. 12fixlouie
Dec 20, 2010 | HP Computers & Internet
Blue flashing power light only
kdavey53, "switch-mode-power-supply" for X193W is probably in shutdown mode due to having detected a FAULT CONDITION with itself or another circuit. Black screen = partial shutdown?? Black and Blank screen = full shutdown??? Which is it? Are you going to repair unit or use warranty? Have you seen video clips at youtube for "LCD monitor disassembly" and "LCD monitor repair" dealing with the most common black screen problem with ALL BRANDS of lcd displays? FYI visit www.ccl-la.com/badcaps.htm or www.badcaps.net or try wikipedia and search "capacitor plague" !!! Read more of my responses to other BLACK/BLANK screen owners for more options that you may have open to you. If not inclined to DIY repair, then have deep pocket$$! Your best shot and what I would do is buy new AND repair X193W to keep as working spare unit. Might only cost $10 in parts on a DIY. But you will need to do the research and understand the problem that you monitor is having. Do you understand what makes your screen "light-up"? Have you any of the new style "curlie-Q screw-in energy saving CFL light bulbs? Same basic principle! Just implemented in different way to produce RAW WHITE LIGHTon reverse side of what you been looking at. Look see only FYI www.ccfldirect.com and then you will know. I'm lmistyrel on aim or 12fixlouie on fixya Hope this was of some use.
Dec 14, 2009 | Acer X193W LCD Monitor
Sony sdm-hs75p runs for 5 odd minutes then screen goes blank?
h_e_l_l_f_i_, Have you performed the flashlight test after the screen goes "BLANK" ?? No!! You will not find the "flashlight" test listed in the OWNERS manual!! The test is a quick evaluation of the STATE of the units "switch-mode-power-supply". Did you repair the power supply to get online to fixya? The more info you tell me about your LCD monitor the better I can assist you. Is the unit really "BLANK" or is it just "BLACK"?? Can you SEE the WIN-desktop when a bright "flashlight" is held 1" from the screen at different angles? If you can see a faint image being displayed it means the SMPS is in partial shutdown and still powering the VGA to LCD interface board. If unit is both BLACK and BLANK, then SMPS is likely in full shutdown mode! I will assume that when you stated "runs" for 5 minutes, that it would display normal text and graphics as usual and NOT be wearing a pair of NIKE's runners footwear? Yes! From your description it would lead me to think that your SONY has a SMPS/INVERTER problem. You failed to state the age and or approximate TOTAL "ON" hours the unit has. (hrs/day x 350days x Years since DOM). It makes a difference in whether I tell you to trade up to a wide screen or have it repaired(refurbished with new SMPS/INVERTER or just rehab the SMPS on your own. hellfi, surely, after reading this you WILL go to YOUTUBE, (just fyi) and view some of the longer video clips of "LCD monitor disassembly" and typical "LCD monitor repair"!! You WILL be impressed at how much you will learn about how "the black screen of death" is dealt with. If this response helps in any way, please rate it on fixya. 12fixlouie lmistyrel @ aim.com Get back to me if further assistance is required asap!!!
Nov 23, 2009 | Sony SDM-HS75P/S 17" LCD Monitor
My phone has a blank screen but still works how do i fix it ?
There might be a Hardware issue with the display you need to walk into the service center to get it repaired.
Thank you fro using Fixya.
Nov 16, 2009 | Sony Ericsson w580i Cellular Phone
Hi i have got an hp pavilion tx2000.3 days ago the screen went blank and is black.the power seems to be ok but screen remains black and cant start n open.
try plugging in another screen using the VGA slot at the back (or side) if this works then there will be a hardware issue with it and it would need to be sent away for repair with HP unfortunatly
Brentwood IT
Sep 25, 2009 | HP Pavilion dv6000z Notebook
Desktop goes black/blank after opening
Can you go to safemode and check if you are able to see the icons.
Did you run a virus scan lately. If not you can try that.
Let me know the results and i can guide you further.
Feb 16, 2009 | Dell Inspiron 1501 Notebook
LCD SCREEN IS DAMAGED IT AS A BLACK CIRCLE IN THE MIDDLE OF THE SCREEN ONE IN THE BOTTOM LEFT HAND CORNER NO IMAGES SHOW UP ON IT IT IS JUST BLANK
there is only one way out, you need to replace the lcd screen (only screen)
there is no chance of repair in your old screen
Nov 11, 2008 | Cameras
Ipod nano 3rd gen 4gb
this seems like a hardware problem, most likely you have to send the ipod in for repairs.
you can try another reset and even attempt a restore from this page
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
reset on the top, restore in the bottom.
heres the apple service assistant
https://selfsolve.apple.com/GetWarranty.do
heres also another place that might be helpful in repairs
http://store.ifixipodsfast.com/
Jun 13, 2008 | Apple iPod nano 3rd Generation
Screen partially black
BAD CAP IN THE VERTICAL SECTION,NOT TO MUCH TO REPAIR.
Dec 15, 2007 | Toshiba 32AF42 32" TV
Partial Screen Display
Problem in the LCD back panel board. check the interface unit or ADC unit, also check the video clock pulse. one section is not working.....
Oct 09, 2007 | Dell E173FP 17" LCD Monitor
Compaq Presario 700 470024-192 Notebook Logo
51 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
