Question about Miele Novotronic T260 Electric Dryer
Miele novotronic t260
Hi, my dryer starts ok, but 3-5 mins into cycle buzzer goes off and dryer stops working, please help
  • 163 Answers
SOURCE: Miele Dryer heater bank
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
heatman101
  • 43501 Answers
SOURCE: miele novotronic T640 about 9/10
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Posted on Aug 29, 2010
  • 177 Answers
SOURCE: where is the reset button for the miele t200
there is no reset button for this unit. if it is not heating you may have blown your thermostat
Posted on Sep 05, 2010
  • 449 Answers
SOURCE: My Miele Novotronic T 1570 C dryer has started
you have to replace the control switch
Posted on Sep 15, 2010
  • 2468 Answers
SOURCE: Miele Novotronic T230C Electric Dryer Dryer is
first check for 240 volts input on the unit if its electrically heated if you have no heat at all,then if you have some heat but it cycles on and off heat wise and the heat isn't as high as it should be,it can be the high-limit thermostat,the cycling thermostat both on the element housing,or it can also be a thermistor sensor on the blower housing if it only acts up on certain settings,you can bypass the 2 components on the element by jumping the wires on the components carefully together temporarily to see if this helps the heating cycle,but not the thermistor,as this is a resistance sensor
Posted on Oct 05, 2010
Just purchased 2nd hand Miele novotronic w310. Does machine automatically stop? Cycle ends, anti crease light on and machine just tumbles clothes makes odd noise, then tumbles again. Is the normal?
NORMALLY WHEN A DRYER COMPLETES IT'S DRYING TIME IT WILL GO THROUGH A COOLING DOWN CYCLE,
DRYER WILL START TURNING WITH FAN ON ONLY FOR A FEW SECONDS THEN STOP, AFTER A SHORT PERIOD IT WILL DO IT AGAIN AND AGAIN UNTIL UNIT HAS COOLED DOWN, HOPE THIS IS WHAT YOU ARE EXPERIENCING
GOOD LUCK
Sep 22, 2016 | Miele Washing Machines
Hi i have a novotronic T560C there is a loud noise that starts after a few mins and moisture on the drum door when I put in dry clothes
Buzzer sounds when the drum turns during the
intermittent anti-crease action period. When the programmable switch is set on the following settings: Normal+, Normal, Hand iron
Refer to page 4 of the user's / owner's manual
Dec 03, 2013 | Dryers
I am rewiring to fit my plug and need to know which wire goes where.
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 03, 2011 | Miele Novotronic T1520 Electric Dryer
How can I disconnect the alarm when the drying is finished?
  • Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. Once the dryer has been unplugged, turn its dial to the "on" setting to make sure the dryer is completely powered down.
  • 2
    Locate the buzzer. The best way to locate the dryer's buzzer is to check the machine's schematic or manual. The buzzer is usually located behind the front panel of the machine. In some cases the buzzer is located behind the dryer's back panel. Dryer buzzers are generally small black boxes that are wired to the timing device.
  • 3
    Pull the buzzer's wires. The most simple way to deal with a buzzer is to pull the wires that run into the buzzer. The wires should pull free with a firm but careful tug. Once you've disconnected the wires from the buzzer simply run a good amount of electrical tape over the ends so that no live wires are exposed. If you want to get the wires out of the way, tape the wrapped wires to the top or side of the dryer panels.
  • 4
    Test the machine. Once you've yanked and taped the buzzer's wires, plug the dryer back in and turn the machine on to test the buzzer. If the machine still buzzes at the end of the cycle then you removed the wrong wires. However, chances are that the machine will finish its drying with a quiet whimper instead of a loud buzz.
  • Feb 17, 2011 | Miele Novotronic T230C Electric Dryer
    Miele novotronic T640 about 9/10 yrs old tumble dryer keeps stoping and the start button flashes when it stops
    heatman101
    Aug 26, 2010 | Miele Dryers
    Miele T230C do no start
    If start LED does not blink, most likely fault is your door lock.
    Jan 04, 2010 | Miele Novotronic T230C Electric Dryer
    Miele Novotronic T260 Electric Dryer Logo
    47 people viewed this question
    Top Miele Dryers Experts
    Tim Whalen
    Dan Webster
    Dan Webster
    Mike
    Are you a Miele Dryer Expert? Answer questions, earn points and help others
